Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 03-06-2008, 08:32 PM   #1
shifty
Questionable
shifty's Avatar
Question Easy way to remove tires from wheels?
You know, I have these four rims I need to refurb, and they have tires on em.
Any suggestions on how to easily remove a tire from a wheel in less than 2-3 minutes?
I tried using two tire irons to break the bead and wedge over the rim like I'd done in the past, but they were cheap tires and came off easy.
The tires are going off to recycle, so I don't care if I gotta cut em off. I gave up after 15 minutes of putzing around and figured I'd come here and ask before proceeding.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 03-06-2008, 08:35 PM   #2
get me on the road
No Matter What.
get me on the road's Avatar
Re: Easy way to remove tires from wheels?
If the air is out get a razor and cut both sidewalls and beads. That should give the tire enough flex to get it off the rim.
Currently own:
89 Chevy Silverado
Previously Owned:Starting with my first vehicle
86 Mercury Cougar /89 Olds 88 /88 Chevy S-10 /84 Pontiac Firebird(I miss it) /91 Chevy S-10
get me on the road is offline   Reply With Quote
Old 03-06-2008, 08:41 PM   #3
shifty
Questionable
shifty's Avatar
That's part of the problem - the bead is steel belted, and so is the sidewall. It was tough enough that I'd have needed a grinder to cut through it, and I'm not going to make that kinda mess in my yard
Old 03-06-2008, 09:16 PM   #4
olblue60@aol.com
member
I have the same problem. I have maybe 12 tires that i would like to strip from the rims.
1967 C/K10 Chevy Panel
1968 C/K20 Chevy Pickup
1968 C/K10 Chevy Suburban
1941 Chevy Sedan Delivery
1960 Chevy Sedan Delivery
1972 Camaro SS 396 #s matching
1971 Harley FX Superglide
olblue60@aol.com is offline   Reply With Quote
Old 03-06-2008, 09:20 PM   #5
Blue'72
Skinned knuckles
Blue'72's Avatar
I've used my skill saw to cut the sidewall around the bead before and then a hammer and chisel or prybar to break the bead, but still not fun. Once the bead is left, you could cut through it with a grinding wheel..
Still messy and smokey!
'72 C-10 longbox soon to be short step!
'72 Chevelle (sold in January)
'07 Sebring
'01 Ranger (I've gotta long commute..)
If you try to fail, and succeed, which have you done?
My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=276904
Blue'72 is offline   Reply With Quote
Old 03-06-2008, 09:27 PM   #6
bigblock73
yeller
bigblock73's Avatar
Tire shops don't charge much at all for dismount...why not just bring them there? Shouldn't cost more than $10 for all four.
Sounds like the easiest approach to me.
bigblock73 is offline   Reply With Quote
Old 03-06-2008, 09:33 PM   #7
Shane
Shane's Avatar
i'm with bigblock ... going rate around here is $5 a tire to dismount
Shane is offline   Reply With Quote
Old 03-06-2008, 09:44 PM   #8
shifty
Questionable
shifty's Avatar
I thought about that. I just hoped there was some way I could do it myself. Trying to stuff four big ass wheels and tires in the back of my VW is a bear.
Old 03-06-2008, 09:49 PM   #9
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Sawsall!
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 03-06-2008, 09:56 PM   #10
full foot notch
sawzall, or maybe see if you can find a mobile tire truck person, usually the people who do the semis have a machine on the truck
full foot notch is offline   Reply With Quote
Old 03-06-2008, 10:04 PM   #11
Blue'72
Skinned knuckles
Blue'72's Avatar
A sawsall doesn't work. It just vibrates the sidewall back and forth. That's why I had to switch to my trusty skill saw. Just harder to corner with it..
'07 Sebring
Old 03-06-2008, 10:32 PM   #12
Phuloi68
I have used a Metabo angle grinder with cut off wheel and it worked great.
Phuloi68
Indy survivor
Norwood survivor
Big Sandy survivor
for those who fight for it...
F R E E D O M
has a price the protected
will never know.
Phuloi68 is offline   Reply With Quote
Old 03-06-2008, 10:35 PM   #13
shifty
here was my solution
http://www.harborfreight.com/cpi/cta...emnumber=34542
Once secured it does really well, especially for the price. But if you don't see your self doing it much, I'd go have someone dismount them for you.
Old 03-06-2008, 10:43 PM   #14
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
Shifty, If you were local I'd be happy to do them on my tire machine, but your not! Cheap or expensive, your tires should come off with tire irons. Are you standing on it to make sure that the bead is down in the drop center? If not, the bead will not come over the rim. Stand on one side of the tire to smash it down, and pry the opposite side up with your iron. Then go over a couple of inches and get a bite with your second iron. I've cut tires off of rims before and it is TONS more work than breaking them down.
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 03-06-2008, 10:59 PM   #15
shifty
Questionable
shifty's Avatar
Thanks, Bill, I'll give that a shot. Here's the catch - I jumped all 180lbs of my ass up and down on that joker and it just would NOT come off the bead. Maybe that's where I went wrong. It's been so long since I tried that I just couldn't remember how I did it the last time.
Old 03-06-2008, 11:04 PM   #16
Bus Ted Knuckle
Son of a gun
OhHHH, so you can't get the bead broke! Here is what you do:
Put the tire under your heaviest truck's bumper, and put a jack between the bumper and the side wall. Jack away until you have lots of pressure on the side wall. If it doesn't break loose, get a BFH and hit the side wall close to the jack until it comes loose.
I do have a couple more tricks up my sleeve for breaking beads, I'll post if you will need em.
they do make a duck billed hammer that is super dandy at breaking beads, but you probably won't want to buy on for a couple of tires.
BEATERS ARE NEATER
Old 03-06-2008, 11:05 PM   #17
shifty
Questionable
shifty's Avatar
Will give it a shot when I get home today. Wife is out of town, so I got all night to get dirty and putz with some tires
Old 03-06-2008, 11:08 PM   #18
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
dont use a shot gun
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 03-06-2008, 11:20 PM   #19
shifty
Questionable
shifty's Avatar
Great, ruin my fun, why doncha?
Old 03-07-2008, 12:54 AM   #20
panhandler62
Java Mechanic
panhandler62's Avatar
I had a buddy who used to get tires off using the bucket of a little Kabota tractor.
Keith
11 Lincoln MKT -- Momma's wagon
13 G37xS -- middle age crazy car
68 C20 Fleetside -- RIP
Decorating the whole town up at a cost of $27 ....
panhandler62 is offline   Reply With Quote
Old 03-07-2008, 01:13 AM   #21
Bus Ted Knuckle
Son of a gun
I'll break the tough ones down with the 3 point on my farmall
BEATERS ARE NEATER
Old 03-07-2008, 01:14 AM   #22
shifty
Questionable
shifty's Avatar
Oh damn, I totally forgot, I have one of those under my bed. I'll have my dog pull it out after work.
Old 03-07-2008, 01:33 AM   #23
slug
slug's Avatar
Iv Jacked My Truck Up And Put The Tire Under My Brake Drum, Set The Truck Down On It And Hit It With A Hammer. Just Make Sure You Jerk The Valve Stem Out
slug is offline   Reply With Quote
Old 03-07-2008, 01:34 AM   #24
cableguy0
As stated the easiest way is to use a tire machine. You will save yourself a lot of headache just taking them to a tire store.its a fight to get them off by hand especially on tires that dont have a lot of sidewall. either cut the tire or just take two trips to the tire store. its worth the drive
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 03-07-2008, 01:35 AM   #25
shifty
Questionable
shifty's Avatar
Oh, I try to jerk my valve stem regularly.
Seriously though, I cut the valve stem out already. That was initiative #1.
The crappy part about this is, if the tires were on the truck and it was rolling, I could de-bead them in a heartbeat on a backroad Alas!
