Old 01-25-2003, 11:47 PM   #1
Dan72cst
Dan72cst's Avatar
3/4ton with 1 ton axels
Over the years I have seen many trucks advertised this way. What exactly does this mean?
Marysville, WA (Dan72cst@hotmail.com)
72 4wd Blazer CST 350/350
72 4wd Chevy LWB 350/350
68 2wd Chevy LWB 327/400
Dan72cst is offline   Reply With Quote
Old 01-26-2003, 12:16 AM   #2
mikep
Used to have a truck
mikep's Avatar
It doesnt really apply to our trucks but post 73 trucks and especially post 82's often had 3/4 ton running gear with 6 lug lighter duty axles. The GVW actually reflecting what a 3/4 ton payload would be unlike our where a 3/4 ton rating truck would haul more like 3000 lbs. . A heavy 3/4 ton would be a 3/4 ton with 1 ton running gear ie 8 lug axle and suspension.
No truck :-(
mikep is offline   Reply With Quote
Old 01-26-2003, 12:22 AM   #3
da-burb
"Ochre Ogre"
da-burb's Avatar
I have also heard a lot of people describe the corp/eaton rearend as the "1 ton axle".
Just like the people who might call their 67-70 C-10's a "heavy half" because it came with 6 lugs.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 01-26-2003, 12:48 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
What Da-burb said is what I usually see.
Old 01-26-2003, 02:50 AM   #5
u2slow
Web Wheeler
u2slow's Avatar
6-lug 3/4-tons didn't show up until '88.
"One ton axles" on a 4x4 usually means a 14-bolt full-floater (or the big Eaton) and a Dana 60 front.
'66 C10 longstep - Clifford equiped
'84 C20 Suburban 6.2L - awaiting 4x4 conversion
'91 V3500 Crewcab - awaiting diesel swap
u2slow is offline   Reply With Quote
Old 01-26-2003, 09:32 PM   #6
rustedchevy
and dana 60 front was only available under the K30's. all other series under that got the dana 44 or the 10 bolt 8.5" Corp axle so...
rustedchevy is offline   Reply With Quote
Old 01-26-2003, 11:47 PM   #7
roger0080
I've always understood the "heavy half" as a 1/2T PU with a 3/4T Rear axle setup. My memory says that with a heavy half, the front would sit lower than the rear (at least after 20 years anyways!).
-Roger
72 Chev C-10 90% restored (former AZ truck) ...
71 Chev K-20 Cheyenne my vacation crusier...
72 Chev C-10 Now retired and striped after many faithful miles...
72 GMC 1500 Retired to the junk yard after bought new in '71...
roger0080 is offline   Reply With Quote
Old 01-27-2003, 12:18 AM   #8
Fred T
Cantankerous Geezer
Fred T's Avatar
Roger's right, but with a six lug setup on the 3/4 ton axle. If you go to the older trucks, the 3/4 and 1 ton used the same rear axle. When I was looking at 14 bolt floaters for my 52, I was told the housings were the same design, differences were in housing and axle length, drums and brakes being bigger for the 1 ton.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 01-27-2003, 01:32 AM   #9
u2slow
Web Wheeler
u2slow's Avatar
Very true! And 77-91 inclusive I might add.
Often when ads say "1-ton axles" on a 1/2 or 3/4-ton, they mean the 1-ton axles have been swapped in.
If it was "1-ton rear axle" it probably means it has a full-floating rear (original or swapped). Most 3/4-tons after '80 had semi-floating rears.
Old 01-27-2003, 10:55 PM   #10
Bowed
My 1967 C20 has an 8 lug / 14 bolt rear , with each out side hub having 8 cap bolts and a removeable cover to allow the axles to pull out . I understood this was a one ton full floater and It appears to be original to the truck . Did any one ton FF come on 67 C20'S ?
Bowed is offline   Reply With Quote
Old 01-27-2003, 10:59 PM   #11
mikep
mikep's Avatar
GM didnt even start making 14 bolt rear ends until 73. Yours was swapped in later.
No truck :-(
Old 01-27-2003, 11:15 PM   #12
Bowed
Who ever did mine did an excellent job with the pan hard bar mount appearing to be unchanged and factory welded with even the brake line passing thru the small hole in the mount and no sign of other changes like the later shock mounts being removed or things like that .
Old 01-27-2003, 11:18 PM   #13
mikep
mikep's Avatar
This might be a dumb question but are you sure its not a Dana 60 because those did come on coil sprung C20's .
No truck :-(
Old 01-27-2003, 11:18 PM   #14
Bowed
What is a 14 bolt FF worth ?
Old 01-27-2003, 11:24 PM   #15
Bowed
It's not a dumb question , Actualy I do not know how to identify a dana 60 . It is 14 bolt with the end hubs that unbolt for axle removal .
Old 01-27-2003, 11:27 PM   #16
mikep
mikep's Avatar
Oh . How many bolts does the cover have ?
No truck :-(
Old 01-27-2003, 11:34 PM   #17
Bowed
Ok my stupid , I just went and counted them again and the cover has 10 bolts and each end hub has 8 cap bolts to hold on the hub covers .
Old 01-27-2003, 11:34 PM   #18
mikep
mikep's Avatar
does it look like this?
No truck :-(
Old 01-27-2003, 11:35 PM   #19
mikep
mikep's Avatar
You have a Dana 60. Welcome to the club.
No truck :-(
Old 01-27-2003, 11:40 PM   #20
Bowed
The picture did not show clearly on my computer , but I trust your judgement that it is a 60 . Sorry I made it so tough by not remembering the right bolt count on the cover . Thanks .
Old 01-27-2003, 11:47 PM   #21
mikep
mikep's Avatar
Do you have coils in back. I assume you do as you said you had a panhard bar. Yours is pretty rare then. Mine has coils too but I have only seen a few that do although there are some on this board who swear that none of them did. Theyr'e quite wrong . Do you know what the gearing in yours is?
No truck :-(
Old 01-28-2003, 12:00 AM   #22
HotRod929
HotRod929's Avatar
Location: Bondurant, IA but in Worcester, MA for school
Heres a better pic of a Dana 60
1970 Chevy C-20
350 V-8
Turbo 350 w/ shift kit
Dana 60 w/ 4.10 gears AND Powr-Loc POSI
New Additions:
Summit Headers
135amp alternator
Proform HEI
Edelbrock 1406 600cfm carb
Sunpro Tach
Powr-Loc POSI
Edelbrock Performer RPM Intake
MSD 6A Ignition Box
AIM: HotRod929
Visit My Site: http://1970chevy.netfirms.com/
HotRod929 is offline   Reply With Quote
Old 01-28-2003, 12:01 AM   #23
HotRod929
HotRod929's Avatar
One more...
HotRod
1970 Chevy C-20
350 V-8
New Additions:
Summit Headers
135amp alternator
Proform HEI
Sunpro Tach
Powr-Loc POSI
MSD 6A Ignition Box
AIM: HotRod929
Old 01-28-2003, 01:23 AM   #24
Bowed
Thanks for the pic's hotrod but that is not it , , mine is rounder on the back side ( without the chunky reinforced areas ) but on the drive shaft side it has large horizontal and vertical ribs for reinforcement . On mine the axle tubes become very large at the pumpkin , instead of the chunky metal areas where the tubes meet the pumpkin in your pictures .
MikeP , yes it is a coil rear .
Old 01-28-2003, 01:27 AM   #25
mikep
mikep's Avatar
Do you have a series or studs with nuts around the perimeter on the side of the rear end that faces towards the transmission. It sounds like you have an Eaton if so .
HA HA HA ... I have the only coil sprung Dana 60 here then.... Muhaha !
No truck :-(
