It'd be alot cooler if you did
Arnott valves?
Well, I'm not getting much of an answer on another forum...
I found this on ebay what do you guys think? Looks pretty slick. Any body have any experience with this company, or even hear of them? and yes, I realize it says 3-5 second rise time. I'm so sick of jarring my head on the roof with my 1/2 valves and line. I want something nice, easy, and classy. http://cgi.ebay.com/ebaymotors/NEW-4...QQcmdZViewItem |
Re: Arnott valves?
Funny you should ask, I've been looking at hand control they make, It shows bag and tank pressure on the LCD.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
Re: Arnott valves?
Also, for $815, this looks like a sweet setup. Not sure how I would like 1/4 line, but with enough air, it might be an option for my truck.
<edit> I was going to run 2 tanks and 2 compressors.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 Last edited by jimmydean; 05-09-2008 at 07:18 AM. |
Re: Arnott valves?
I am a fan of 1/4" line myself. Very controlled.
I remember checking into that set-up before... it looked pretty decent.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
Re: Arnott valves?
I definitely want a much more controlled slower system then the one I've had. I currently have 1/2 valves and half inch line.
What would I use to hard line 1/4" line? What valves would you recommend? |
#6 | |
Re: Arnott valves?
I wish I could see the valves, guess I will when they arrive. Nate, have you used 2-way valves? That's what it looks like these are.
Re: Arnott valves?
smashingchuck, I also have 1/2" valves and got tired of the neck jarring effect of them. I install 1/4" lines coming out of my valves and it is perfect now. Accu Air has a new system coming out that will adjust your system as you drive, always keeping it at the same suspension travel. There system requires smaller valves, we installed the system on a tahoe we did a few years ago with 1/2 valves. We also switched the lines out to 1/4" lines. His system works sweet now!
It would be worth it to try 1/4 line out of the valves. |
Re: Arnott valves?
i was gonna go with 3/8 line but this thread is making me second guess that. Anybody have experience between 1/4 and 3/8?
Re: Arnott valves?
i checked them out before i went with something else. what really caught my attention was the controller, but i didn't like the fact that they only had six valves, maybe they changed that now. i also have 1/2 line and valves, but if it is too fast i will add some speed control valves for both fill and discharge
My truck spends more than my wife, is that normal? |
Re: Arnott valves?
Yeah I've thought about just keeping the stuff I've got and using flow controls... but I'd really like something that a little cleaner.
wow is that AccuaAir expensive! It would be cool, but I have bigger fish to fry right now! JimmyDean- where can I buy that Viar valve block? |
Re: Arnott valves?
The only other block I am aware of that is worth a damn is the Air Ride Technology "Big Red" and it's $750.
There is also the Asco 3/8 manifold I've seen for $400. Last time, I just used a bunch of brass fittings from Suicide Doors and made individual units for each bag. It worked very well, but wasn't the cleanest install. I am looking to go a lot cleaner this time. Unless the Arnott system totally sucks, it should work for me. If it turns out to be crap, I'll just swap out the manifold and controller with the Big Red system and run the same 7 switch setup I had last time.
Re: Arnott valves?
The Asco unit is basically the same thing as the "big red" for a lot less. It is supposed to be a quality piece. It has gotten good review over at s10forum.com
If I didnt already have all my valves, I would probably go with that. |
#13 | |
Re: Arnott valves?
I hope to get some crap ordered in the next few weeks. Having 2 projects is hard on the wallet.
Re: Arnott valves?
Accu air is coming out with a less expensive version that will do it all. Call them up and ask for Reno. He will help you out!
#15 |
Re: Arnott valves?
ASCO / Parker is same company.
#16 |
Re: Arnott valves?
I am ordering the Arnott system I posted earlier and adding a second tank/compressor. So dual ViAir 380's and dual 2.5 gallon tanks.
Should be quick to fill compared to the painful process of trying to fill a single 7 gallon with one Thomas compressor last time ![]()
#17 | |
PorterBuilt Man Crush
![]() Join Date: Jul 2007
Re: Arnott valves?
Is this going to be different then what they show on their site? I really like there valve pack with the circuit board to eleminate the wires. http://www.accuaircs.com/index.html
The 72 will live again |
#18 |
![]() Join Date: Aug 2005
Re: Arnott valves?
I can tell you this: I had 1/2" and went to a 3/8" neck down with a 1/8" orafices on the vents. I think the drop rate is perfect now but I'm going to replace all my line with 1/4" hardline. 3/8" fill is still too fast for me. My tank runs at 175#
#19 | |
Re: Arnott valves?
<edit> I am looking to run hard lines with this setup if I can.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 Last edited by jimmydean; 05-09-2008 at 10:51 PM. |
#20 |
Re: Arnott valves?
can valve blocks be serviced , or do you have to replace the whole thing if you have a problem with one valve ?
1970 Gmc6500 1951 chevy gasser 1986 crew cab dually 1956 Gmc extended soon to be ? |
#21 |
Re: Arnott valves?
It looks to me like the actuators are screwed in, so you could replace that. The manifold is in pairs, so you could unbolt the block and replace a pair. Other then the 1:2 manifold:actuator association, it's straight forward.
#22 |
Re: Arnott valves?
ART also sells a smaller version of the Big Red Valves that are 1/4". They do not list them on their site, nor in their catalogue, but I know you can get them. They are the manifold/valve assembly of my preference. The manifold style assemblies are much cleaner and easier to plumb. They are a lot slower than the 1/2 parkers... but I think that's a good thing. I have used, and will continue to use 1/4 line on my own projects... it's very smooth and controlled. If the goal is to have a smooth ride, and dump the truck at a show or while parked, there is no need for anything larger than 1/4. It's a lot easier to run 1/4 line, and a lot less expensive if hardlining the system.
I haven't used the asco valves... so I don't have any input. I have always used the ART valves and have ZERO negative feedback.
#23 |
Re: Arnott valves?
They are serviceable... I have had to replace an o-ring in one of the solenoids before. Very simple.
#24 |
Re: Arnott valves?
I figure if the valves suck, the rest of the system is still usable and swapping out to the ART system would be simple enough. Good to hear you can get 1/4 ART blocks.
#25 | |
![]() Join Date: Apr 2004
Re: Arnott valves?
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
