Dropmember Rear 63-72 Spy Pic
Well... the rear Dropmember for the 63-72 chassis will be available shortly. Here's a spy pic.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
Re: Dropmember Rear 63-72 Spy Pic
You outdo yourself again. Incredible work as usual, I'm excited to see the finished product.
When and how much? And whats included in the dropmember?
Nice!
On a side note..... I attempted to slide the LSx into the truck tonight. Using some plates that have been scribed w/the typical 'LS to sbc' mount orientation, the drivetrain is pretty close. The 4l80e required removing more of the trans tunnel than I had hoped & I'm thinking I might need to get a f-body oil pan for better bottom end clearance for servicing entrance/exit. It's a good thing these motors don't have distibutors @ the back of the manifold. The fit is tighter than my wallet ![]()
3DrDwn--the 'burb not the band
hmm. that look's vaguely familiar
![]() ![]() Josh
Slo and Lo that is the tempo. '72 burb build page here: http://67-72chevytrucks.com/vboard/s...d.php?t=259256 '89 GMC Dually crew build page coming soon. 88 ![]() duallys past/present pics here: http://67-72chevytrucks.com/vboard/s...46#post4001246 89 1 ton Dually rear flip kit install here: http://67-72chevytrucks.com/vboard/s...d.php?t=354327 |
#6 | |
67-72 parts collector,…
![]() Join Date: Nov 2002
Very Nice!
Tot Roddin'
Wow... maybe I need to changes the plans for my truck, or... even better, buy another one!
![]() Nice work Nate!
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
cool! what kind of link setup will come with it?
On the fast track to nowhere..
Looks awesome
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting |
It will use the stock trailing arms, IIRC.
Looks awesome, Nate.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
///Relaxed Atmosphere
looks good can't wait till this is released to be ordered.
jeff
72 Suburban 64 Chevy short fleet 04 Chevy Colorado Sport Reg Cab 2012 Chevy Avalanche 2003 Chevy S10 Blazer Xtreme http://www.hubgarage.com/mygarage/RA_Jeff 64 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=295915 |
I would imagine the rear link set up will be like the 73-87 kits Porterbuilt makes. pics of the 73-87 kit are on the attached link.
http://67-72chevytrucks.com/vboard/s...d.php?t=274729
#14 | |
A guy with a truck
Lookin' good! 'Bout time
![]() Quote:
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
#15 |
![]() Join Date: Aug 2005
So it's a bolt-in notch/bridge?
#16 | |
I made 'adapter' plates that are bolted to the LS block & prepped them for both the 'stock' sbc location as well as the 1" set back. After my initial attempt last night, the sbc holes in the plate were very close. The issue I did run into was between the height of the truck intake & the depth of the truck pans sump it was very difficult to get a confirmation that adapter plates will work. From info I found via the net, the f-body pan is 3" more shallow vs. the truck pan. What I'm trying to confirm @ this time is specifics on the Caddy CTSv pan. It's very similar to the f-body pan dimensionally & apparently uses the same windage tray as the trucks (which means less stuff to buy/mess with).
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 06-03-2008 at 02:23 PM. |
#17 |
wow! nuff said
1947 International KB-1 1957 Chevy Bel-Air riding low 1962 swb fleetside 2002 Chevrolet Silverado 7-inch lift on 35 Daily driver 2016 Chevy Tahoe Better halves ride |
#18 | |
#19 |
This configuration was originally destined for trailing arms... BUT it looks like a four-link makes a lot more sense.
#20 | |||
A guy with a truck
#21 |
Frizzle-
It is a bolt-on... 100% just like the 73-87 kit. This pic is not of a finished piece. Just a teazer shot. Nate
#22 | |
How much farther forward are the LSx motor-mount tower tabs on the c.member vs. the sbc tabs?
#23 |
Does this mean the final configuration is TBD?
#24 |
WTB this ad
#25 | |
A guy with a truck
