Old 06-30-2008, 01:04 AM   #1
sixtyfour
Zombie Killer
sixtyfour's Avatar
One Wire Alternator???
I'm looking to install a high output alternator in my 64 but I'm unsure whether my truck has a one wire alternator? How do I determine this, looking at my alt I have now, it has one large wire going to the back, but then it also has another wire that plugs into the side? I'm guessing I do not have a one wire alt. I believe the alt I have now came out of a 1984 Camaro.
1964 C10 Long Step
sixtyfour is offline   Reply With Quote
Old 06-30-2008, 01:25 AM   #2
joe231
joe231's Avatar
Re: One Wire Alternator???
nope, not a one wire
a one wire is literally "one" wire
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 06-30-2008, 01:30 AM   #3
sixtyfour
Zombie Killer
sixtyfour's Avatar
That's what I figured....thanks.
1964 C10 Long Step
Old 06-30-2008, 01:54 AM   #4
poorboy
poorboy's Avatar
Here's how you can wire that alt in.
http://67-72chevytrucks.com/vboard/s...d.php?t=119379
63 short fleet Patina build
http://67-72chevytrucks.com/vboard/s...d.php?t=287751 Man I want another one.
poorboy is offline   Reply With Quote
Old 06-30-2008, 09:14 AM   #5
tomlamb
I just installed a 1 wire in my truck this weekend. I got it from e-bay and it did resolve a problem I was having with my TPI hesitating (going into open loop I was told) with the AC on because there was not enough amperage. Easy job, all that is needed is to connect the included heavy gage wire to the output post on the back of the new unit and the battery.
tomlamb is offline   Reply With Quote
Old 07-01-2008, 09:08 AM   #6
Shorty Cox
Here you go,
It is so easy. I did it to my '64, and i would think it would be just as easy on yours.
1.Take the regulator off and throw it as far as you can.
2. It should have had 4 wires connected to it.
3. Using a test light, locate the wire that is hot (12 volts)when the ignition switch is in the "run" position.
4. now, locate the wire that runs from the regulator position to the gen/alt position.
5. splice the wire located in number 3 above to the one located in number 4.
6. now you have a wire at the gen/alt location that is hot (12volts)with the key in the "run" position.
7. forget the other two wires at the regulator position.
8. Now remove the gen/alt and throw it as far as you can(probably can't throw it as far as you did the regulator!!)
9. Should be three wires going to the it. two small wires and one large wire. The large wire is connected to the battery and is hot (12 volts) all the time. (On some vehicles, it may connect to the battery via the horn relay)
10. Go to the parts house and purchase an alternator with an internal regulator and a new "pig tail" (the little thing that plugs onto the two terminals on the side and near the back of the alternator) they are numbered 1 & 2. the pig tail will have a small white wire and a large red wire. The new alternator will also have a large terminal(electrical connection) on the back. It will look like a screw sticking out with a nut on it.
11. Do what it takes to bolt the new alternator into the place of the gen/alt you removed and threw in step 8.
12. Once installed, plug the pig tail onto the terminals mentioned in step 10. attach the large wire from the battery (mentioned in step 9) and the red wire on the pig tail (mentioned in step 10) to the large terminal on the back of the alternator, tighten the nut.
13. Now attach the white wire on the pigtail to the wire identified in steps 4, 5, & 6.
14. Secure all left over wires.
15. Crank her up and you are good to go.
Amp meter should work also. If you have a idot light, i'm not sure.
Shorty
Shorty Cox is offline   Reply With Quote
Old 07-01-2008, 09:24 AM   #7
billydonn
Council of the Elders
billydonn's Avatar
It is probably the 120 amp output that solved your TPI voltage problem... not the "one-wire" factor. There still seems to be a lot of confusion here about what a one-wire alternator really is, let alone how they actually work.
66 C-10 Stepside
350 Tuned Port Injection
Tremec TKO-600
Truck Pictures: http://community.webshots.com/user/billydonn
Truck Video: http://good-times.webshots.com/video...ost=good-times
billydonn is offline   Reply With Quote
Old 07-01-2008, 10:21 AM   #8
2ndGenRR
2ndGenRR's Avatar
check out this site...tons o' info on electrical in general and one-wire alternators in detail.
http://madelectrical.com/index.shtml
The Stable:
1952 GMC 1/2 ton, 5-window...Owned since age 16...that was awhile ago! Torn apart and waiting for my boys to get old enough to help me.
1990 Chevy K5, 5.3L, 4L60E, slowly going back together as my dune truck.
1951 Chevy 1/2 ton, 3-window...building to sell.
Daily Drivers: 1998 3/4 ton Burb with a 6.5 Turbo Diesel and 1994 1/2 ton Silverado.
I grew up in Flint, Michigan so I can't help but to bleed Chevy!
2ndGenRR is offline   Reply With Quote
Old 07-01-2008, 12:20 PM   #9
billydonn
billydonn's Avatar
Yep. My truck is wired using the "new system" described in those articles by Mark Hamilton. I went to some length to avoid getting a one-wire alternator myself, though everyone seems to want to sell you one and they are easy to wire and will work okay for many people.
66 C-10 Stepside
Tremec TKO-600
Old 07-01-2008, 01:32 PM   #10
tomlamb
I would agree, I went with a 1 wire for the price as the guy wass local to me and he had it in stock.
Old 07-02-2008, 11:58 AM   #11
sixtyfour
Zombie Killer
sixtyfour's Avatar
I ordered a one wire before you guys posted about three wire alt...damn! I'll probably just go with the one wire now.
Looking at my alt now, it is the three wire with internal regulator. Anyone know what i would need to do with the 2 extra wires on my 3 wire system?
1964 C10 Long Step
Old 07-02-2008, 12:17 PM   #12
Tim64
Tim64's Avatar
I got the one wire from Summit back last fall sometime. It's no big deal, and it didn't require a bunch of wiring. Works great! Kept things charged and going all winter long. I think you'll be happy with it.
Tim64 is offline   Reply With Quote
Old 07-02-2008, 02:51 PM   #13
rickf
rickf's Avatar
I put a one-wire on my 64 a decade ago.
I mounted the alt itself in the usual way.
I connected the big red wire (that was already on the truck) to where the big red wire goes on the alt.
I zip-tied the remaining two-wire-with-connector to the wire bundle on the fender well.
The voltage regulator is still on the rad support where it always was.
In essence, I connected the one wire that was needed and changed nothing else. It has worked fine for 10+ years.
rickf is offline   Reply With Quote
Old 07-02-2008, 03:13 PM   #14
Tim64
Tim64's Avatar
That is just how I did mine. The only other thing I did was hook up a volt meter inside since the light would no longer work with the regulator disconected.
Old 07-02-2008, 03:38 PM   #15
billydonn
billydonn's Avatar
Wink Re: One Wire Alternator???
It's really amazing that GM never thought of this one-wire alternator thing for their millions of vehicles! Their electrical engineers must be real dopes.
66 C-10 Stepside
Tremec TKO-600
Old 07-02-2008, 04:44 PM   #16
Anthony Fremont
Anthony Fremont's Avatar
Actually, they were pretty clever. "One wire" alternators have been around for a long time. They are great in farm equipment and that kind of thing, but they leave a little to be desired in an automobile. They can't turn on a light bulb to tell you when they aren't working. They sense the voltage at the same place in the system that they supply power. This doesn't work ideally in our old trucks, since the electrical system was designed to have the voltage sense point a pretty good distance from the alternator. I've read that you might have to rev them up a little to make them "wake up" upon starting the engine. I'm not saying they're bad or that they don't work, I'm just sayin'......
'66 GMC Custom Fenderside LWB
'90 IROC - L98
'97 1200C Sportster
Anthony Fremont is offline   Reply With Quote
Old 07-02-2008, 06:22 PM   #17
billydonn
billydonn's Avatar
10-4... I believe we are on the same page. I wasn't thinking of a tractor as a vehicle, but ....
66 C-10 Stepside
Tremec TKO-600
Old 07-03-2008, 05:10 PM   #18
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
shorty cox- that was a perfect description, that helped me bypass the regulator and go with the internally regulated alt.
thanks!
now- not to hijack...
but since this one looks like it was figured out...
Can someone help me convert points to hei?
descripion?
Old 07-03-2008, 06:53 PM   #19
scotts62
One day...
scotts62's Avatar
thanks!
descripion?
MSD thats how
Your just wanting to change distributors? Just about wiring the hei?
Scott
93 crew cab build
Project 62
Old 07-03-2008, 08:58 PM   #20
jonzcustomshop
1961 crewcab
Just rewiring my old points system to the hei that I have now.
Old 07-03-2008, 09:09 PM   #21
poorboy
poorboy's Avatar
Just drop in the dist and run a wire from the extra ign terminal on the fuse box to the dist and you're done.
Old 07-03-2008, 10:45 PM   #22
TimE
Hey Y'all!!
TimE's Avatar
Make sure it is a heavy gauge wire too.
TimE is offline   Reply With Quote
Old 07-03-2008, 11:00 PM   #23
greg64
greg64's Avatar
Hey Billy, about the 1 wire and GM engineers thing, there is a reason why they did what they did. There's the idiot light that Anthony mentioned that they got for "free", but there's another reason too. With 1 wire alts, there can't be much of a voltage drop between the alternator and the battery/dash/fuse box (this is because the alt can't compensate for the drop). How do we accomplish this? With a heavy gauge wire, which is what 1 wire systems will recommend. But, for GM, that would mean that they would have to run 8 gauge wire for main power feeds, and that is a lot of copper. Instead, they used puny 12 gauge for the feed, but then ran another, EVEN PUNIER 18 gauge wire in parallel to sense the voltage (one of those 2 extra wires on the 3 wire alt. Now, when there is high current draw and an appreciable voltage drop on the 12 gauge, the sensing wire "notices" and pumps up the alternator voltage to compensate. So, you get 15v at the alt and 14v at the dash which is what is was supposed to be in the first place. So, now GM saved a few bucks in copper wire for every truck, and $2 times 1,000,000 trucks a year = more money then I have in my wallet!
There's the other aspect too, that 1 wire alts need to be "blipped" up to a few thousand RPM before they will self-energize. If you start and idle, you've got nothin.
Greg
64 GMC Suburban - 283, NV3500, 14 bolt
77 C10 swb - 292, SM465, 12 bolt
greg64 is offline   Reply With Quote
Old 07-04-2008, 08:45 AM   #24
jonzcustomshop
1961 crewcab
poorboy- on my fuse block there are 2 plugs that say "ign unfused " are those the ones you are talking about?
Old 07-05-2008, 04:07 AM   #25
rickf
rickf's Avatar
(Not to speak for poorboy, but...) Yep, that is what I used (with an inline fuse).
