Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 07-01-2008, 10:28 PM   #1
69trk
69trk's Avatar
post latest 1/4 and 1/8 mile times and 60ft.
I haven't been to the track in a while, waiting until i get on a chassis dyno and thinking i'm going to change over to e85. Anyway Post you're best times so far this year.
11.37 at 115.81
7.18 1/8 mile
1.58 60ft.
69trk is offline   Reply With Quote
Old 07-01-2008, 10:49 PM   #2
Couch
Daily Driver
Couch's Avatar
Re: post latest 1/4 and 1/8 mile times and 60ft.
12.12 @ 106.34 1/4
7.64 @89.43 1/8
1.77 60ft
nitrous...the equal opportunity destroyer.
Couch is offline   Reply With Quote
Old 07-01-2008, 11:40 PM   #3
bigjimzlll
bigjimzlll's Avatar
1.32
6.02 @ 116.7
9.45 @ 141.4
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
http://67-72chevytrucks.com/vboard/payments.php
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 07-02-2008, 09:22 AM   #4
Super73
Super73's Avatar
Updated 7/16/08
How is this for a "67-72 Trucks ET list"
Sortable Excel Version
http://73-ls1.com/67trucksetlist/67_...t_7_16_08.xlsx
If you can provide this info, I will try and stay on top of it at least once a week if not more.
Name
Date
60'
330'
1/8 ET
1/8 MPH
1000'
1/4 ET
1/4 MPH
Year
Weight
Engine Platform (Cubic inches and SBC, BBC, BBF, LS-series, Hemi)
Transmission
Stall converter
Power adder 1
Power adder 2
Power adder 3
Rear Gear
Rear Tire
Comments
Either way mine is:
1.669
7.114 @ 96.178
11.282 @ 115.322
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 07-02-2008, 01:05 PM   #5
RatPwrd72
RatPwrd72's Avatar
So far, I have this.....
1.49 60'
6.80 @ 99 MPH
10.87 @ 122 MPH
Going to try out the new 468 motor this weekend
1972 Chevy Cheyenne Super- Pump gas 496,TH-400, TCI Stall, 3.73's,Ochre & White two-tone w/Olive
Interior
1967 Chevy Short Step Drag Truck-Iron Headed 468 Making Memories
My momma took me off the bottle years ago.....
RatPwrd72 is offline   Reply With Quote
Old 07-02-2008, 02:32 PM   #6
Marv D
Registered Truck Offender
Marv D's Avatar
Just changed short blocks and haven't been to the track with the truck in a while (too busy playing with the car and Camino) But don't expect the change to a lighter better rotator to make any significant changes,,,,, 12.03 @ 107,. Typically mid 1.6 sixty's but have seen a couple of 1.60's on a good tight track, with a n/a pump gas small block.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 07-02-2008, 03:28 PM   #7
nxtruck
nxtruck's Avatar
7.27 @ 94 with a 1.55 60' in the 1/8. No quarter mile tracks close to me, so 1/8 mi. is all I've ran. This was ran on pump gas w/o n2o.
Chris
1966 Chevy C10 LWB, 434 sbc, TH350, 12-bolt, factory suspension, pump gas
7.02 @ 95.8, 1.45 60'
1965 Chevy C10 LWB, 355 sbc, TH350, daily driver
nxtruck is online now   Reply With Quote
Old 07-02-2008, 05:45 PM   #8
regan wilson
regan wilson's Avatar
8.93 @ 151.00
5.71 @ 123.00
only a 1.32 60ft
10.90 @ 149.00 in s/st
I'm hoping to better this after I freshen the motor and change the cam .
NHRA Super Street 469C
It only runs 10.90 at 156 mph
I was Dragtruck when Dragtruck wasn't Cool!
regan wilson is offline   Reply With Quote
Old 07-03-2008, 11:26 PM   #9
383 Stroker
383 Stroker's Avatar
7.35 @93mph
1.67 60ft
Video's of my Truck Racing
1967 C-10, 383ci Sbc, TH350, 3200 stall, 3.73 gear
383 Stroker is offline   Reply With Quote
Old 07-14-2008, 10:11 PM   #10
Super73
Super73's Avatar
Updated 7/14/08...
Now, I know there are more trucks that belong on this list.. DJ???
Old 07-14-2008, 10:29 PM   #11
djracer
djracer's Avatar
mine are in my sig. These were run on pass time and should air any day now! The episodes from montgomery started airing tonight!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 07-14-2008, 11:50 PM   #12
Super73
Super73's Avatar
Kevin, to help me out and not have to go through 30 pages on your truck can you give me some of the bullit points on you combo..
Old 07-15-2008, 01:39 AM   #13
Couch
Daily Driver
Couch's Avatar
hey shaun. on my slow turd its a 69 not 67. but its all good cause everyone thinks it is a 67 cause its got the 67 front end.so i guess you can call it either, but its a 350 stock bottom end, TH-350, 3,000 stall, N20 adder, 4.10 rear gear, with a 325/50r15 MT street DR. comment=daily driven
Old 07-15-2008, 07:41 AM   #14
djracer
djracer's Avatar
old combo since I blew it up and will be moving towards a much larger motor!
14 to 1 60 over 454 with Brodix aluminum heads. Dominator, Speedtech plate with 250 jets in it. Glide with ultra bell, ultra case and 1.80 straight cut gear set. Trailing arm rear with coilovers and an anti roll bar! 9 inch Ford rear with 4.30 pro gears. 35 spline gun drilled moser axles and a spool.
Kevin
P.S. We are gonna add almost 100 cubic inches to this combo.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 07-15-2008, 09:49 AM   #15
regan wilson
Sounds like a 555 or 565 is in your future . That oughta fly !
Old 07-15-2008, 10:14 AM   #16
djracer
djracer's Avatar
565
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 07-15-2008, 11:40 AM   #17
71Dragtruck
71Dragtruck's Avatar
I've been eying this up, thinking next summer or fall maybe. Run N/A on pump gas for bracket racing, and leave my N2O on for fun.
http://www.ultrastreet.net/engines/632_classic.asp
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
Old 07-16-2008, 01:07 PM   #18
RADDRACINTRK
Talking Re: post latest 1/4 and 1/8 mile times and 60ft.
newbie 6.81 1/8 @ 91.88
1.43 60ft
first and only pass
hit 3rd lost traction
RADDRACINTRK is offline   Reply With Quote
Old 07-16-2008, 01:51 PM   #19
djracer
djracer's Avatar
1.43 60ft
first and only pass
WELCOME to the zoo that's pretty quick.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 07-16-2008, 02:20 PM   #20
Super73
Super73's Avatar
Ok.. Updated with DJ's stuff and Raddracintrk..
I split the sheet so the there are 1/8 times and 1/4 times. I did this as some have only made 1/8 passes and I don't want to take away from how fast their trucks are moving setting them at the bottom of a 1/4 mile list.
Couch, sorry.. I forgot to add your additional info. I added it to the sheet and it will be on the next update.
Old 07-16-2008, 03:03 PM   #21
71Dragtruck
Well I was hoping to have a better time for you to post up with my new setup, but a major head wind was effecting everyones times untill the evening when it cooled off and the wind died causing alot of breakouts, unfortunately I was in the trailer by then.
last years best was a 10.77 @124mph with a 1.56 60'.
I have ran 1.53 60's but was bracket racing and had to let off so I didn't breakout, pretty sure I would have been in the high 10.6's that Sat.
Old setup when the run was made:
489 BBC
150 shot
4128lbs. without driver
Turbo 350
4500 stall
4.10 gears
29x14.5 tire
New changes:
4003lbs. without driver
4.30 gear
31x16.5 tire
Sponsored by:
Hard Candy Customs
Old 07-16-2008, 03:56 PM   #22
djracer
djracer's Avatar
I wish I could lose 120 lbs. I am on a diet but I can't lose that much I'd weigh less than 100 lbs.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 07-16-2008, 05:20 PM   #23
69trk
69trk's Avatar
1.43 60ft
first and only pass
Welcome, hopefully i can pull those 60ft when i go in a couple weeks.
Old 07-17-2008, 12:48 AM   #24
Super73
Super73's Avatar
DJ what's your truck weigh?
Old 07-17-2008, 02:04 AM   #25
djracer
djracer's Avatar
3222 with me in it!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
