07-23-2008, 08:23 PM | #1 |
What do ya'll think?
ok guys, i've got an 85 shortbed in primer black......
i have an idea for a set of rally wheels painted the same black primer with the chrome trim rings and chrome center/chrome lugnuts. what do ya'll think? here is a pic of a truck just like mine minus the wheels/tires..... do ya'll think it'll look pretty decent? oh i'll go with 15x8's with a 275-60-15 tire. looking to do this possibly in the next few weeks. |
07-23-2008, 08:35 PM | #2 | |
It followed me home?
Re: What do ya'll think?
I like it the way it is, not much of a fan of black wheels
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually Last edited by cochino12; 07-23-2008 at 08:41 PM. |
07-23-2008, 08:39 PM | #3 |
i think when you go with the other size tries it will look real nice
07-23-2008, 08:41 PM | #4 |
well the wheels and tires that are on that truck are not the ones that are on mine..again, that is not my truck, just one that is almost identical to mine with the exception to the wheels/tires...mine have something diferent but the rest of the truck is the same.
if i can take some old 15x8 rally's, invest in some trim rings, lugs, center cap and it look decent i might go that way. just curious what ya'll thought. |
07-23-2008, 08:43 PM | #5 | |
Georgia Boy
07-23-2008, 08:46 PM | #6 |
that is true also. now should i try and find a set of the rally's at a junk yard off an old truck (they were 15x8 right?) or should i just buy a new set and start from there?
07-23-2008, 08:50 PM | #7 |
Georgia Boy
I'd use the rallys off an old truck.. sandblast them(the best way to start) or use some scotchbrite to clean them up real good.. I'd just use a good spray on filler primer to prime them up then paint. I plan on doing the same when I repaint my truck.. to whatever color I end up with.
07-23-2008, 08:53 PM | #8 |
i guess i can get the trim rings and centers from any wheel/tire dealer right?
07-23-2008, 09:36 PM | #9 |
I don't think these pills work
I've Done My Lwb Like That Sorry For Bad Pic Ill Try To Get A Better One In A Day Or Two
SQUARE84 90 SUBURBAN |
07-23-2008, 09:39 PM | #10 |
Georgia Boy
07-23-2008, 10:33 PM | #11 |
Truck Nut
If you paint you're wheels a bright contrasting color, they will really pop! My truck is black with bright red rallys. I know thats a popular color combo but it looks good.
Tony Kee Texas Square Bodies |
07-23-2008, 11:11 PM | #12 |
Paint the rallys silver not black
2001 silverado 2wd 2003 silverado 4wd 1975 scottsdale c10 (project) |
07-23-2008, 11:30 PM | #13 |
i was thinking that if i painted them a darker color then silver that might make the chrome rings,cap,lugs stand out more. then once i paint the truck white - i was going to paint the rally's white.....
07-24-2008, 11:08 AM | #14 |
It'd be alot cooler if you did
I'd put the time and money into lowering the back of the truck some more.
07-24-2008, 11:35 AM | #15 |
I would go with silver, but that's just me. I just finished painting 5 rallys last week. I sandblasted them down to bare metal, painted the back and rim section black and the faces silver. I used Case-IH tractor paint for both the black and the silver and it looks damn good. Just my 2 cents worth.
Most decent salvage yards should have a complete set of rallys. The yard I use gets $25 for a rim with ring and center cap. Be aware that most vans use the 6.5" rally and occasionally you will run accross the 7" version as well. Last edited by dswancutt; 07-24-2008 at 11:41 AM. |
07-24-2008, 01:59 PM | #16 |
6.0 powered square
I would get the streer stars they give it a drag truck pro street look, I have the same wheels on mine
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 Last edited by flamingbig10; 07-24-2008 at 02:05 PM. |
07-24-2008, 02:00 PM | #17 |
Dark Heart Motorsports
I love the rake on your truck... those rims would really set it off out here in charleston SC... for some reason that seems to be the current trend out here... old school with colored rims.
How Deep Can YOU Bleed..? 1985 Chevy Blazer K5- 6.2 N/A, 400 turbo trans CUCV, 12v converted... a new chapter 2005 GMC Sierra Crew Cab 6.0 powwwaa!!! custom jumpseat install w/ captain seats, Hypertech tuner, MSD Blaster Coils, CB and twin antenna's, all electric interior, touch screen in dash. custom center console, with jump seat replacing original console. 1500 HD! |
07-24-2008, 02:15 PM | #18 |
I think it will look great, of course.
I've been thinking with my 87 GMC: Truck=Primer black/semi gloss GLOSS black rallies 91 gmc grille with the trim gloss also instead of semi--just to add a little contrast
Joseph 87 Turbo Buick 92 5.0 Mustang coupe 87 GMC Sierra SWB 82 Chevy K5 Blazer 2wd |
07-24-2008, 02:28 PM | #19 |
I've seen them painted gun metal gray before, which also looks good.
1977 GMC Sierra Grande |
07-24-2008, 03:23 PM | #20 |
Im not a fan of the flat black but i do like the satin finish. In my experiance black looks better with larger diameter rims. Ever think about powdercoating them?
side note: what drop is that? Last edited by Cherub; 07-24-2008 at 03:23 PM. |
07-24-2008, 06:27 PM | #21 |
what do you guys think about the american racing torque thrust and the torqlites? i really like the torqlites cause i've always loved the look of the telstars and the prostars but they are so dang pricey. and the street stars look good but i can't find them in a 5x5 lug pattern online.......looking to do something wheel wise this next week. i want to stay around 4-5 hundred bucks for the wheels.
07-24-2008, 10:48 PM | #22 |
I have some cragar street stars, I think thats what they are called. They look just like the ones on the black truck.
Here These: They need to be polished up and you should replace one because it is bent. They are still available new from summit. I'd let em go real cheap. Pm me if you are interested.
07-24-2008, 11:05 PM | #23 |
heck yes........pm sent.
07-24-2008, 11:15 PM | #24 |
heres a better pic of mine
07-24-2008, 11:17 PM | #25 |
see thats what i was talking about
might get me a cheap set of those and have two diferent sets to run on the truck depending on how i want it to look....i like to polished wheel look and i also like the vintage style look. |
