Old 08-19-2008, 09:51 PM   #1
Bentblazer
Bentblazer's Avatar
Another Stupid PO
While removing several pounds of filler on pass side I discovered a patch over the wheel arch. The patch did not have the small crease around the edge of the opening. They used that patch and filled the original crease with filler to make it look the same. My question is where or what would that patch be from? Going to try to borrow a pic from AJs72K5 from last Stupid PO. The crease is the small indent around wheel opening.
Bentblazer is offline   Reply With Quote
Old 08-19-2008, 09:58 PM   #2
Bentblazer
Bentblazer's Avatar
Re: Another Stupid PO
Sorry AJ hope this isn't a copy right infringement, with pic if so come get Blazer you would save me lots of $
Old 08-19-2008, 10:12 PM   #3
AJs72K5
AJs72K5's Avatar
No worries. I opened the thread and was like, "Hey! That's me!"
- AJ
Gray Matter Build - 1972 K5 with some stuff
AJs72K5 is offline   Reply With Quote
Old 08-20-2008, 07:27 AM   #4
vtblazer
vtblazer's Avatar
Are you talking about the lower rear wheel arch?
This part maybe?
vtblazer is offline   Reply With Quote
Old 08-20-2008, 07:39 AM   #5
Bentblazer
Bentblazer's Avatar
Yes, There is a small crease all along the edge of the opening just before turning into the inner wheel house on the rear and before the inner fender on front. The patch didn't have that small profile like the original. Wondering where it came from.
Old 08-20-2008, 08:12 AM   #6
vtblazer
vtblazer's Avatar
Those are present only on stock/factory fenders, no repro part maker has ever managed to design them into their parts.
(if I'm understanding you correctly that is)
Old 08-20-2008, 05:41 PM   #7
Bentblazer
Bentblazer's Avatar
Hope this will clear up what I am trying to explain, the profile on the original is circled in red. Hard to tell with pics but looking close you might be able to tell where patch starts without profile. The original (darker shade) is about where the splash guard is, above and below that is the patch without profile.
"85" Monte Carlo SS
"71" K5 (SOLD)
"64" Chevelle
1930 Chevy two door rat
Old 08-20-2008, 07:07 PM   #8
vtblazer
vtblazer's Avatar
Yep, nothing reproduced like that.
Put a WTB thread up in the classified section looking for a patch area from an "original" fender and you'll find yourself one.
Gotta be a subscribed member though...
Old 08-20-2008, 10:51 PM   #9
AJs72K5
AJs72K5's Avatar
That's really weird. Because my PO told me both front fenders had been replaced when he was making it over due to rust. I assumed aftermarket (LMC) but could be wrong.
- AJ
Old 08-20-2008, 11:05 PM   #10
69-72
69-72's Avatar
Actually no, some patch panels do come with the detailed lip, only the really cheap stuff doesn't have it.
69-72 is offline   Reply With Quote
Old 08-21-2008, 07:15 AM   #11
vtblazer
vtblazer's Avatar
Who's has it?
Which repro manufacture does the indent?
No pics, no proof.
Old 08-21-2008, 07:18 AM   #12
vtblazer
vtblazer's Avatar
So yours has the indent detail?
I'm smellin' a learning curve here...
Old 08-21-2008, 07:47 AM   #13
Bentblazer
Bentblazer's Avatar
Early this spring I bought a swb bed side (drivers) that I cut to replace original and it had that indent on it. I got it from Manes. Does a LWB wheel arch measure the same? I have a LWB bedside that I could cut for patch if needed, but wanted to check for new first. Would hate to have to fill indent on new side If I could repair original since forth fronts and driver look same.
"85" Monte Carlo SS
"71" K5 (SOLD)
"64" Chevelle
Old 08-21-2008, 09:08 AM   #14
69-72
69-72's Avatar
They make a patch for the rear wheel arch with the indent in it. And yes the LWB arch would be the same.
MOST Tri-plus panels have the detail but you may get a bad one, depends who you buy from it seems. Another brand I came across with it was Tabco.
Anyone that wants picture proof of the detail on the rear arch I will PM the pics.
Oh yah and I have GMC repro front fenders that have the indents also.
Old 08-22-2008, 10:01 PM   #15
Bentblazer
Bentblazer's Avatar
So do you think it would be better to cut a patch out of the LWB or look for a repop patch?
"85" Monte Carlo SS
"71" K5 (SOLD)
"64" Chevelle
Old 08-22-2008, 10:23 PM   #16
msgross
msgross's Avatar
isn't the rear arch of a SWB and LWB different? I thought that the SWB "swept" out more in the rear of the arch. Not sure what your blazers do but be sure to check...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 08-23-2008, 08:56 AM   #17
69-72
69-72's Avatar
Orignal metal is always better IF you can find it, but when I was matching up the creases from the repop panel to the orginal it was pretty darn close. The rear arches on LWB, SWB and Blazers are all the same.
Old 08-23-2008, 11:50 PM   #18
abebummy26
abebummy26's Avatar
Uh I have to disagree with you on that one check out the 3rd post down on this page. http://www.67-72chevytrucks.com/vboa...223158&page=41
-Lincoln
1987 GMC S15 (soon to be a chevy clone)
2.5l, 4 speed, no ps, no pb, no ac
Silence is golden, but duct tape is silver.
Spoken by Cletus the hillbilly
I like stickers... a whole bunch.
abebummy26 is offline   Reply With Quote
Old 08-24-2008, 08:57 AM   #19
Bentblazer
Bentblazer's Avatar
I can see the difference in the photos, the patch I need will run from near the moulding on the front around to the rear to the bottom, Think that would work?
"85" Monte Carlo SS
"71" K5 (SOLD)
"64" Chevelle
Old 08-24-2008, 11:41 AM   #20
69-72
69-72's Avatar
I am referring to the upper piece, the actual arch area.
Old 08-24-2008, 03:04 PM   #21
Bentblazer
Bentblazer's Avatar
The pic you have shown is what I have to replace, but would like to continue on to the rear bottom as a small patch wa placed there also. The idea was to replace two patches with one. It does look like that the forward bottom looks different however I don't need to go that far down,
"85" Monte Carlo SS
"71" K5 (SOLD)
"64" Chevelle
Old 08-24-2008, 10:28 PM   #22
Rokcrln
Rokcrln's Avatar
Yes from the front belt line molding up around to the rear arch bottom they are all the same. The differance is in the lower front corner of a LWB to a SWB/Blazer. So it should work fine depending on your skills.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 08-24-2008, 10:56 PM   #23
Old Chevy Mech
Keepin it runnin!
Old Chevy Mech's Avatar
Tabco's panels (the ones THEY make) have that detail perfectly. I ordered the patch panel for the area forward of the wheel well on the rear qtr panel and it came with the detail (very crisp) and a nice heavy galvaniel gage steel! I suggest calling before ordering and specifying that you want their parts only, because they do sell some inferior parts too. I'll try to get some pics....
Frank
1970 K-5 4X4 Blazer
1970 K-20 4X4 Long Bed
"Liberty Means Responsibility, that is why most men dread it"
Old Chevy Mech is offline   Reply With Quote
Old 09-04-2008, 09:01 PM   #24
Bentblazer
Bentblazer's Avatar
Located a patch panel with indent from a board vendor last week. On vacation this week and due to Gustav remnants I was confined to the spousal avoidance center and try my luck at installing. I'm not much of a welder so those who are my hat is off to ya. The small patch with green was off of a donor lwb bed, the black patch was the repop. The last is next to replace just had to show how much filler was used, nearly a half inch thick. Feel free to give advise it is appreciated. On a lighter note I took picture of a lake that I had dug in July, yesterday this lake had only a foot of water in it and thanks to Gustav twelve hrs later and 6.5" of rain its more than full.
"85" Monte Carlo SS
"71" K5 (SOLD)
"64" Chevelle
Old 09-05-2008, 09:58 AM   #25
raggedjim
raggedjim's Avatar
Looks good. How are things in Rolla since B&S left? I hated that, a lot of good guys worked there...
Rg
raggedjim is offline   Reply With Quote
