Old 08-23-2008, 06:07 PM   #1
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
What is this??
On the left side of my chassis, near the firewall, I have a loop attached to the frame. A good friend, who has worked on many of these trucks and scrapped a good number of them (before they were valuable) said he'd never seen one.
So, what it is and what it is used for? There are no marks to indicate anything ran beneath it or was attached to it.
So.....
Member Nr. 2770
Old 08-23-2008, 06:17 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: What is this??
Is there one on the other side? Maybe a tie down while being shipped??
68gmsee is offline   Reply With Quote
Old 08-23-2008, 06:20 PM   #3
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: What is this??
Nope....just the one.
Good 'un, huh?
Member Nr. 2770
Old 08-23-2008, 06:27 PM   #4
Arad68
Trucks N Tranzams
Arad68's Avatar
Re: What is this??
It appears to be a bracket for engine torque strap. (In case the motor mount failed or was broken.)
Don
'68 Chevy LB 383 TH400/GV/373 posi
'56 Chevy 4WD SWB
'64 Chevy short stepside
'79 Trans Am 455/TH2004R/12blt/4whldisc
95 Kia (Wifes car)
2002 S-10 extended cab pickup
"God punishes small sins immediately"
Arad68 is offline   Reply With Quote
Old 08-23-2008, 06:29 PM   #5
68gmsee
Active Member
68gmsee's Avatar
Re: What is this??
Re: torque strap.... Yeah but why only on one side.
If there were two, I'd say something to lift the frame up with in the factory.
Old 08-23-2008, 06:34 PM   #6
67_C-30
I have a radical idea!
67_C-30's Avatar
Re: What is this??
The torque straps were dealer installed, so maybe they took a shortcut?
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 08-23-2008, 06:43 PM   #7
too much stuff
Roadtrip!
too much stuff's Avatar
Re: What is this??
Factory engine hold downs. If the motor mount broke, that would hold it in place. Didn't need to be on both sides as the torque from the engine would only lift it one way...
I have seen most of these on 67-68 models.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 08-23-2008, 06:52 PM   #8
too much stuff
Roadtrip!
Re: What is this??
Forgot to add that there would be a cable that ran under the loop and both ends would bolt to the engine...
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 08-23-2008, 06:59 PM   #9
67_C-30
67_C-30's Avatar
Re: What is this??
I've had several cars from that era that had the straps, but I've never seen them on a truck. I just went out and looked, and of the 13 I have here at home, none of them have it.
My trucks
Old 08-23-2008, 07:51 PM   #10
MrBeast
high-Tech Red Neck
MrBeast's Avatar
Re: What is this??
You must be out of breath. have a cold one on me.
"He used to be a pretty nice feller, now he's a welder!"
MrBeast is offline   Reply With Quote
Old 08-23-2008, 08:38 PM   #11
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: What is this??
recall dated may of 72
As found in the glove box of my first longhorn
It specificly says 10 - 30 series trucks on the recall, and it is for the motor mounts.
I have only seen one truck (was a 71 or 72 GMC in a new orleans junk yard) that had the recall retrofit straps, but it had the loop like your photo shows, and still had the cable looping around the exhaust manifold.
Old 08-23-2008, 11:27 PM   #12
RaceAGMC
RaceAGMC's Avatar
Re: What is this??
My 70 HAD one of these, when i put in the 6.0, i noticed that it was not needed and it was tossed by the wayside!
70 CST, 6.0/ 4L80E in the works.
*Custom harness by 68 Short Step*
RaceAGMC is offline   Reply With Quote
Old 08-23-2008, 11:45 PM   #13
Husker
Husker's Avatar
Re: What is this??
I Have a complete setup from a 70 Chevy. They were suppose to be on both sides.
Ron
Member #111
68 C-10 Daily Driver
70 4x4 Project
76 Jeep CJ-5
Help Support the Board:
http://67-72chevytrucks.com/vboard/payments.php
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors.
Thomas Jefferson
Husker is offline   Reply With Quote
Old 08-24-2008, 08:35 AM   #14
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: What is this??
Ron
I looked at the right side of the frame and no holes are drilled. So, mine only had the one. Since it has headers, my guess is that removing the original exhaust manifolds also lead to removing the strap.
If this is the true purpose (and what else could it be for?), then why don't we see more of them?
Thanks for answering the mystery question.
Member Nr. 2770
Old 08-24-2008, 08:56 AM   #15
68gmsee
Active Member
68gmsee's Avatar
Re: What is this??
Originally Posted by ChevLoRay View Post
.............If this is the true purpose (and what else could it be for?), then why don't we see more of them? ................
You have a point. Hard to believe that only a handful got that warning the Longhorn Man posted. Or worse, nobody took their trucks in to have restraints put in. Maybe they didn't want to part with their trucks for even a day or two.
It sure sounds like a bandaid for a potentially dangerous situation. Times have changed....
Old 08-24-2008, 09:33 AM   #16
Husker
Husker's Avatar
Re: What is this??
The Passenger side did mount to the Exhaust Manifold and the drivers side mounted to the block, If I remeber correctly.
Ron
Member #111
70 4x4 Project
76 Jeep CJ-5
Thomas Jefferson
Old 08-24-2008, 10:22 AM   #17
Old Chevy Mech
Keepin it runnin!
Old Chevy Mech's Avatar
Re: What is this??
What can also happen if the engine were to torque enough is the clutch linkage could possibly pop out, leaving you SOL without a clutch and the engine throttle stuck at a high RPM. My 70 Jimmy had this exact event occur when I was 16, making a left hand turn (thankfully) into an empty parking lot. I came out on the clutch just hard enough and was giving enough gas that the shifter also got messed up at the same moment. The truck had the 3 on the tree and the driver side motor mount ripped in 2 pieces. So it was hang on and Holy Pooooo!!! When it happened it made alot of noise as the fan was grinding on the shroud. Clutch linkage pieces were in the street, it was night, no flashlight, and being stuck in 1st gear! Had to start the truck in 2nd gear and use the key to slow down at stop signs, luckily it was night and zero traffic! I did finally make it home, safe. I'll never forget that event and as a result I change motor mounts every time I think theres too much play in the motor mounts. I always wondered why they didnt make a better mount, or maybe there is and I dont know about it.
Frank
1970 K-5 4X4 Blazer
1970 K-20 4X4 Long Bed
"Liberty Means Responsibility, that is why most men dread it"
Old Chevy Mech is offline   Reply With Quote
Old 08-24-2008, 10:53 AM   #18
Arad68
Trucks N Tranzams
Arad68's Avatar
Re: What is this??
GM changed the mounts starting in 73 becuase of this problem.
Don
'56 Chevy 4WD SWB
95 Kia (Wifes car)
Old 08-24-2008, 12:05 PM   #19
chrislehr
Engine n00b
chrislehr's Avatar
Re: What is this??
You REALLY need to scan that whole thing. I will provide web hosting for it if need be.
chrislehr is offline   Reply With Quote
Old 08-24-2008, 02:54 PM   #20
therealcurtis
Re: What is this??
I'll bet why not many people have seen these is that the new design motor mounts were put on ones that came in for the recall later, or if the owner was religious about taking the truck to the dealer. whenever one came in with straps, it got the new motor mounts.
68 Chevy LWB stepside (currently hauling $#!* out of my backyard)
94 CVPI R.I.P. was fun until the tranny died, and the brake line rusted thru and the dashboard lights were blinking codes at me.
93 Exploder
09 Scion XB
01 Indian Scout
therealcurtis is offline   Reply With Quote
Old 08-24-2008, 02:58 PM   #21
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: What is this??
I still have both sides on my '68. Even when the PO swapped a 350 in for the 327, he reinstalled both straps.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 08-24-2008, 03:35 PM   #22
drivethechevy
drivethechevy's Avatar
Re: What is this??
i never really paid any attention to it but i have the driverside strap on a 70 gmc 2500 i have, when i got the truck the guy who i got it from told me he had to bring it in to a dealer to have that installed but he didnt tell me what it was for just that it was there
Trial and Error, its expensive but its a mistake i most likely wont make again
1971 chevy k10 custom deluxe
http://67-72chevytrucks.com/vboard/s...d.php?t=341257
1968 chevy k/10 fleet
http://67-72chevytrucks.com/vboard/s...d.php?t=334731
1948 desoto custom coupe fluid drive(family heirloom)
drivethechevy is offline   Reply With Quote
Old 08-24-2008, 09:25 PM   #23
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: What is this??
I remember the the "concern" that existed at that time with Chevy motor mounts, but don't recall the fix...specifically. I do remember seeing some cable straps on some cars that came in to "the World's Largest Department Store" auto shop when I was working there in '76.
What I also recall was a '72 Plymouth that a customer brought in because they couldn't get the oil filter off of the 318. When I put it on the rack, it became obvious. The motor mount was broken, and the engine had turned in its mounting just enough that the oil filter, when unscrewed, came into contact with the chassis. They were right. Neither they, nor we, could remove the oil filter....until it got some new motor mounts. I didn't fix it, and I don't know if they did or not. I'm gonna guess it don't even matter now.
Member Nr. 2770
Old 08-24-2008, 09:37 PM   #24
msgross
msgross's Avatar
Re: What is this??
makes me wish I bought those Prothane mounts and not the "made in India" ones now.!
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 08-25-2008, 01:56 AM   #25
cameeks
Long Fleet Club
cameeks's Avatar
Re: What is this??
http://www.performanceonline.com/sto...96&cat=0&page=
Has anyone used these? Also can you just go to your local parts store and get new mounts for these or do you have to call them back up?
Chris Meeks
'69 Chevy Custom/10 Long Bed <-- Thread of the work I did before selling.
Truck is now finished to the new owners design and running around.
I was shown some pictures of the finished product. At least it survived the junk yard.
FAQ Index by Krue Site Vendors Subscribe Here Forum Rules
cameeks is offline   Reply With Quote
