Old 08-28-2008, 11:53 AM   #1
kizer
Its Deja Vu time again
kizer's Avatar
Kizer and his 65 here
Heres the Craigslist Ad.
65 chevy 1/2 ton, 250 6 -cyl 3 on the tree. pretty straight, good tires, collecter plates. drive it to hell and back...15-18 mpg. trade for motorbike.
I traded it for $400 because I don't own a motorbike.
Welp its not pretty, but its mine. a buddy of mine came with me and gave me the thumbs up. He actually drove it home since the front brakes are shot and I've never driven a 3 on the tree before. He took off on one side street up a hill and well I couldn't catch him if I tried in his Jeep.
Looking around there is some work ahead of me. I think looking it over in the drive way after we brought it home I don't think there is one piece of sheet metal that doesn't have a dent or a hole in it. Looks like I'm going to learn how to weld if I like it or not. If Rust is a Cancer this thing is for sure on the Terminally Ill list.
Here are some shots. It was with my camera phone so yes they suck, but its what I have for now. Hopefully I can make some room in the garage and I'll start tearing it apart as time allows.
What I do know:
Looks like a straight 6
3speed on the column and shifts well
Smokes at start up, but doesn't seem to when you get on it.
Windows rollup and down pretty easily
Lights work, however some of the running lights and blinkers seem to have a mind of their own
Horn works
Wood bed
Doors don't squeak or crack when you open and close them
Engine has a leak on top
Windshield wipers work
Starts right up after a few cranks
Clutch appears to engage high up near the top - Adjustable? We will see
Brakes are shot up front. Grind, Grind when you use them.
Frame appears to be straight because it doesn't looks sideways going down the road from behind.
All in all its going to be a project truck. I'm going to learn how to weld, paint and I'm sure I'm going to learn the proper way to fill in holes using the proper amount of bondo. I know most will not use it, but I don't have an endless supply of liquid Metal laying around.
I still have access to another truck so there will be some part stealing. Like the hood and a few other parts. Its going to be a who has the better of the two for starters.
kizer is offline   Reply With Quote
Old 08-28-2008, 12:07 PM   #2
283 Man
283 Man's Avatar
Cool Re: Kizer and his 65 here
Welcome to the forum!!It needs work but its not bad at all Ive seen lot worse.Your 65 has a lot of potential.nice 65..
283 Man is offline   Reply With Quote
Old 08-28-2008, 12:29 PM   #3
steverino66
For 4 bills, you definitely scored.
steverino66 is offline   Reply With Quote
Old 08-28-2008, 12:31 PM   #4
kizer
kizer's Avatar
Yeah I know it needs some work. Probably a lot more than others, but I figure I'm only 37 and hopefully it will be done before the little guy in the seat is old enough to drive it. I hope nobody minds, but I'm kind of a photo freak. I probably take way to many and document way to much. The last transfercase I did for a buddy looked like this. http://www.iamkizer.net/kevin/ I did finish the build, but some how I miss placed the second half of the photos so I'm kinda bummed.
Here is well a photo shoot of everything above the frame. I haven't put it up on stands yet to look under. I do plan on doing a complete frame up clean up. I can't say for sure if its going to be show quality, but I can say its going to be painted head light to tail light with something.
http://s398.photobucket.com/albums/p..._chevy/02_rot/
The wife kicked me out side last night because I was annoying her and I think I had cabin fever and wanted to do something on the truck. Well I figured why not start at the top and work my way down and back. I have tons of cans of flat black because its my favorite so I just tackled the air cleaner
I will have tons of questions simply because I do for instance.
I currently have a 3 on the tree and I have access to another 65 C10 or atleast it says it is and it has a 4speed and a transfercase. Does that seem right? I thought the K series was the 4wheel drive.
Anyways can I bolt the 4speed up and remove the 3speed? I don't know where to look to see if the gear ratios would match and or if the outputs would work. Seeing it has a transfercase that might put me into looking for some other adapter.
Also I was told the motor is a 250, but I can't find any markings that identify it as so other than this tag I found on the side and what I've read didn't the 250's come out in 1966?
Old 08-28-2008, 12:33 PM   #5
kizer
kizer's Avatar
Yeah I almost landed another one that was maybe a hair in better shape, but this one actually had an engine and well started right up and drove home. I did have to plug the blinker flasher/relay thing in because it was in the glove box, but other than that no problems.
Old 08-28-2008, 12:47 PM   #6
jchav62
1962 C-10
jchav62's Avatar
That looks like a great deal of $400! Nice...
Welcome!!
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 08-28-2008, 01:37 PM   #7
GMC65Guy
My clutch dosnt engage until towards the top as well. Maybe it's normal on the 3 speeds?
GMC65Guy is offline   Reply With Quote
Old 08-28-2008, 01:48 PM   #8
kizer
kizer's Avatar
Sounds like mine just as well. Its like the total oposite of my Jeep. My Jeep is a few inches off the the floor and this one is nearly at the top.
I wonder if thats adjustable because honestly its kinda annoying, but then again it is 43years old.
Old 08-28-2008, 02:21 PM   #9
drjenkins
drjenkins's Avatar
Great deal man!! Good luck on the project!
65 Stepside SWB
drjenkins is offline   Reply With Quote
Old 08-28-2008, 07:32 PM   #10
63sbssbbw
UCA63
63sbssbbw's Avatar
Looks like a a great start
400!!!definitely score of the week
Welcome
T
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline   Reply With Quote
Old 08-28-2008, 10:17 PM   #11
64Magoo
When I got my '64 the clutch would engage at the top because the clutch was totally shot.
64Magoo is offline   Reply With Quote
Old 08-28-2008, 10:40 PM   #12
kizer
kizer's Avatar
Thanks for the info on the clutch. A buddy of mine pretty much confimed the samething.
I was plnning on pulling the body off to start cleaning up the frame and suspension. So I might as well address the clutch and any other flaws I notice when I can see it all.
Is there a prefered brand of clutch? I'm not planning on building a hot rod out of the 230 so I'm sure some crazy centerforce clutch is probably overkill, just a street beater for now. Heck I hardly know enough about this thing to even order parts.
Old 08-29-2008, 06:39 AM   #13
62 short step
62 short step's Avatar
Welcome!! Don't worry about being a photo freak, we love pics!!!
www.louisianaclassictruckclub.com
1965 c-10
86 chevy c/k 20
62 short step is offline   Reply With Quote
Old 08-29-2008, 07:24 AM   #14
scotts62
One day...
scotts62's Avatar
from OKC! nice truck! you got a steal for that price
Scott
93 crew cab build
Project 62
Old 08-29-2008, 08:25 AM   #15
Iron-Butt
454 club
Iron-Butt's Avatar
Nice truck, you will not find one here for that price.
David
1965 Chevrolet c-10 454 automatic Custom bbw swb.
1965 Chevrolet C-10 swb (Sold)
1963 Chevrolet C-10 6 Cyl automatic with dual exhaust, pb, ps and 17's.
R.I.P "I will miss you.
1967 Chevrolet C-10 6 Cyl Custom lwb
1939 Chevrolet Coupe, 350 v8 automatic.
1935 Chevrolet 2 Dr Standard in the works.
2015 Harley Davidson Street Glide.
2023 Chevrolet Stingray Z51 Convertible.
I never want to grow up.
Iron-Butt is offline   Reply With Quote
Old 09-05-2008, 04:24 PM   #16
kizer
kizer's Avatar
Well the wife said she wouldn't be home for lunch so I took the hour to tear into the bed some. Found rust in the usual places and luckly there are patches for them. Im not sure about the middle bed stakes thou. I hope I can find them somewhere or figure something else out. I found a really old school hub cap, which is probably one of the originals shown below on the left. As well I found some change so I have a few more cents towards the project.
Old 09-15-2008, 01:58 AM   #17
kizer
kizer's Avatar
Got start somewhere so I did. The wife kicked my outside and said we where leaving in 15minutes. So I took a little dead blow hammer and beat up some rotten wood. Sure I'm sure I have tons more I could be working on, but hey I want to take the bed off and start working in the rear down to the frame and then I'll start working forward.
Needless to say I have a lot of little metal strips that need to be pulled out because they are rusted beyond repair, but the bed supports are fine along with the main bed sections.
Now I just have to break out the PB blaster and start working on all the fittings so I can get things apart. Man its going to be a pain in the ass, but I think it will be fun at the same time
Its not pretty but its mine to figure out.
The build / The Photos / Build Diary
Old 09-15-2008, 02:11 AM   #18
Slmd92DIME
Slmd92DIME's Avatar
Long bed FTW. Looking good. You def. got a good score for only 400. I have a lot more than that in mine and it was worse than yours.
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=269019
Petitioning *No Regrets* MD/WV
Slmd92DIME is offline   Reply With Quote
Old 09-15-2008, 10:26 AM   #19
kizer
kizer's Avatar
Bought it for 400, but by no means is it even close to being done.
Its got rust in all the usual places and having zero body work experience its going to be a long road a head of me. Like I told the wife one day at a time. Her biggest fear was seeing the money pit pulling into the garage knowing that I'm gunho and won't stop until its done. I told her its 40years old and it took 40years to get into the shape its in and all I plan on doing is reversing time.
So basically little time here and a little time there to get it back to what its supposed to be. So don't be surprised if this isn't a 5year old thread when I get it finally painted.
Old 09-15-2008, 10:28 AM   #20
kizer
kizer's Avatar
I know I'm going to look silly, but what does FTW mean? "Fear The Wood"? hahahaha
Old 09-15-2008, 04:03 PM   #21
19GMC63
19GMC63's Avatar
For The Win.... opposite is FTL or For the Loss... i.e. Ford FTL.
19GMC63 is offline   Reply With Quote
Old 09-15-2008, 06:27 PM   #22
kizer
kizer's Avatar
Thanks. I'm pretty hip with the lingo, but I thought heck it could be a Chevy forum thing.
Old 09-15-2008, 09:43 PM   #23
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Wow... nice score on the '65!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 09-18-2008, 11:20 AM   #24
kizer
kizer's Avatar
No big updates, but started pulling more of the bed out. Man I had no idea the bed was a giant erector set. 8 bazillion bolts, but hey I'm having fun so far. Used my new Saw Zaw in the middle just because I could Just pulled out the bed strips and hit the bed with some Rustoleum spray paint just to hold it over until I can start stripping, which hopefully will be in the new few months. But I'm going to try and tackle the frame and suspension components some before playing with body panels.
Told you guys I was a photo freak.
Old 09-18-2008, 11:24 AM   #25
4dranch
Shloooooong bed member #2
4dranch's Avatar
looking good
David,
Daughters 66 truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=484601
Learning to drive a 3 on the tree:
http://www.youtube.com/watch?v=CcCMvRgBo1Q
4dranch is offline   Reply With Quote
