Old 10-04-2008, 12:55 AM   #1
tx71smallblock
tx71smallblock's Avatar
383 Stroker Build Questions
hey guys
im lookin to pull the old rebuilt 350 out and build a 383 stroker. im just wondering if a 383 short block is the same as taking a 350 and boring it out and putting a stroker kit in it? anybody know how i should go about this?
thanks ahead
cody
p.s. i can still use the 350 topend i have know right? and if you have a 383 this would be the time to show it off!!!
70 Chevy C-10 short step
250/3 on the tree
Owned:
71 longbed Cheyenne
70 swb
tx71smallblock is offline   Reply With Quote
Old 10-04-2008, 05:04 AM   #2
Matshark
Matshark's Avatar
Re: 383 Stroker Build Questions
I have a 383 stroker, not a old 350 but a LT1.
But there shouldn`t be so much difference concerning
the short block.
They had to make sure there is enough room for the crank to turn freely,
so they grinded in the area around the crank, but that
should be all in addition to bore and hone.
Good luck and
1955 2nd series 3100 Pickup, MustangII IFS, Ford 9" with 4 link, 4 wheel wilwood disc brakes, 383 Callaway supernatural, 4L60E
'All people dream, but not equally. Those who dream by night in the dusty recesses of their mind wake in the day to find that it was vanity.
But the dreamers of the day are dangerous people, for they may act their dream with open eyes to make it possible.'
Matshark is offline   Reply With Quote
Old 10-04-2008, 07:44 AM   #3
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
You've got the idea,but make life easy on yourself.There are tons of quality stroker kits out there.It's much easier to use one since balancing can be a big headache on a pieced together stroker.Find a copy of Big Inch smallblocks(I think that's the right title) for reference.Motorbooks should have it if B&N doesn't.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 10-04-2008, 08:19 AM   #4
tx71smallblock
so are you saying buy a 383 short block or buy a 350 block and build it?
250/3 on the tree
Owned:
71 longbed Cheyenne
70 swb
Old 10-04-2008, 08:44 AM   #5
BarryB
BarryB's Avatar
No use a 350 block, but get a stroker kit.Here's one from Summit ESP-B13404L000. It comes with a crank, rods, pistons, and everything else to build the bottom end. Your best bet will to get all partsyour together and take it to the machine shop and let them take care of it for you.There are clearances need to be made on the block.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 10-05-2008, 12:37 AM   #6
tx71smallblock
cool thanks, so i need to get everything together and then take it to the engine or machine shop and let them put it together
250/3 on the tree
Owned:
71 longbed Cheyenne
70 swb
Old 10-05-2008, 01:23 AM   #7
Ricks1971
Ricks1971's Avatar
I went with a 400 ci small block more tork and to me more power! The 400 block to use is the 509 casting number block. I used 5'7 rods in mine and it runs great. Remember that a 383 and a 400 are externally balanced motors that means you need to balance the entire bottom end, dampner crank and flex plate. that's my take
Ricks1971 is offline   Reply With Quote
Old 10-05-2008, 10:40 AM   #8
70 net440
Junior Member
70 net440's Avatar
Most of the 383 kits can be internally balanced so you can reuse your 350 balancer and flywheel or flexplate. We used an Eagle forged crank, Scat rods, and KB pistons in my Son's K-10. You can save some bucks with a cast crank, we went a little overkill.
63 C10
70 Coronet R/T
67 C10
70 Dart Swinger
71 K10
70 net440 is offline   Reply With Quote
Old 10-05-2008, 11:03 AM   #9
prg machine
prg machine's Avatar
definitely consider this . Without the internal balance features you will have to have a 400 flywheel or flex plate to complete the assembly.
In my case, I had a 400, that was cracked, and I used the heads and flywheel and a new balancer and the machine shop purchased the crank, rods etc. for the rotating assembly and fit it all together at the shop. That way everything was done in the bottom end, all of the grinding for clearances etc. and the block was then thorouly cleaned.
talk to your automotive machinist. I would ask around for references as well for the local reccomended "Chevy Builder".
69 K-20 cloned to a 67 with front clip and some other stuff.
383 .040 over
Crane roller cam lifters and rockers ,1.6 intake ratio, Open chamber heads, 9.5-1 compression ratio, 2.02 intake valves , Edelbrock performer Air Gap manifold Carter AFB performer 750cfm, MSD ignition, SM465 NP205 4.10 gears:
prg machine is offline   Reply With Quote
Old 10-05-2008, 11:06 AM   #10
prg machine
correct me if I am wrong, but i believe the 383 is developed by the stroked crank and any boring out is just a standard practise and is not required for the cubic inch factor. So I guess any over bore is a few more inches over the 383.
383 .040 over
Old 10-05-2008, 12:47 PM   #11
mrein3
mrein3's Avatar
A 383 is a 350 with 0.030 overbore and a 400 crankshaft. Back in the day you had to find a 400 and rob the crank out of it. Now you just buy a kit with everything ready to go for your 350 block.
Using a stock 350 block you need to do a little clearance work or the longer stroke would hit the block.
In today's world a guy should probably start with a 1996 - 1999 vortec 350. That way you get the roller cam, one piece rear main, and most importantly the nice flowing vortec heads.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 10-05-2008, 01:30 PM   #12
ERASER5
ERASER5's Avatar
Here are the basic numbers for a 350 to 383. The .030 over bore is just to clean up the normal wear on a rebuilt 350 block. If you have an extremely good original bore, then you would build a 377. There are other options out there, but they get more complicated and more expensive.
Bore Stroke Cu-In
4.000 3.480 349.8
4.000 3.750 377.0
4.030 3.750 382.7
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 10-05-2008, 02:52 PM   #13
70 net440
Junior Member
70 net440's Avatar
Will the 96-99 blocks interface with early transmissions and/or exhaust manifolds or headers?
63 C10
70 Coronet R/T
67 C10
70 Dart Swinger
71 K10
Old 10-05-2008, 03:13 PM   #14
mrein3
mrein3's Avatar
Transmission. Yes.
Exhaust. Yes.
Intake. No. You need to purchase a vortec style intake for your carb set-up.
Somebody correct me if I'm wrong but I believe all 1955 - 1999 engines and transmissions will mate together.
'72 Malibu hard top
Center City, MN
Old 10-05-2008, 07:26 PM   #15
70 net440
Junior Member
70 net440's Avatar
I knew about the intake, I just wasn't sure about the rest. Thanks, now the search is on.
63 C10
70 Coronet R/T
67 C10
70 Dart Swinger
71 K10
Old 10-05-2008, 11:06 PM   #16
Chevymann1968
Chevymann1968's Avatar
On the stroker kit i would go with the 6 inch rods it give you more stroke and more torque!!!
Chevymann1968 is offline   Reply With Quote
Old 10-05-2008, 11:34 PM   #17
hdflstf
hdflstf's Avatar
6" rods will not change the stroke. They will get you to the correct 1.6 rod ratio so more torque will be developed versus the 5.7" rods. Be sure to get the correct deck height pistons since the pistons for the 5.7" rods will not work on the 6" rods.
hdflstf is offline   Reply With Quote
Old 10-05-2008, 11:49 PM   #18
jeremy zander
jeremy zander's Avatar
Cool Re: 383 Stroker Build Questions
I pulled the original engine out of my 72, took it to a machine shop and had a summitt 383 stroked kit installed. it was dynoed at 446 hp and 462tq. she runs sweet and you can sure hear it coming. I rebuilt the stock 3 speed tranny. probally should have went with an overdrive. maybe on the next build..
WTB 1972 CHEVY 3/4 4X4
1971 chevy c30 4x4 NAPCO (project)
1972 chevy 3/4 4x4 350/350 4spd, tach, tow hooks,radio delete,heat delete,hubcaps,lockers
1972 chevy 3/4 4x4 383/350 dads original farm truck tilt,tach,tow hooks,hubcaps,radio delete,heat delete
2006 chevy LBZ crew cab duramax,4 inch,beadlocks
2015 chevy tahoe Z71 my fifth one,love em
2016 chevy 2500HD Z71 LTZ duramax midnite
2018 chevy suburban Z71 midnite
jeremy zander is offline   Reply With Quote
Old 10-06-2008, 10:44 AM   #19
nbroady
nbroady's Avatar
Originally Posted by Matshark View Post
Good luck and
x2
nbroady is offline   Reply With Quote
Old 10-06-2008, 03:57 PM   #20
70rs/ss
70rs/ss's Avatar
I just did the Vortec 383 thing, the 6" rods have little or no effect in a 383 so a basic cast crank stroker kit balanced and ready to drop in with the flexplate and balancer will run $800-1000 depending on where you get it. I found a guy selling the same kit as Summit (Scat or Eagle) for about $200 less, but the assurance from Summit is worth the $200 extra. I used a 99 Vortec motor ($150 complete core) tossed the crank and rods/pistons, reused the block and spent some $$$ on the heads, I am shooting for close 500hp and at least that much torq!
So to answer the question, should you do it, yeah you should!! A complete rebuild on a 350 is only a few hundred (2-300) less than a 383, so why not?? As for the heads, toss the 350 heads and get Vortecs or the Patriot versions, ready to go complete heads for less than $500 for a pair (new guides, valve job, etc will cost almost this much on the 350 heads and the Patriots have screw in studs, guide plates new SS valves, etc, etc and 185 cc runner for a heavier breathing 383!!)
70rs/ss is offline   Reply With Quote
Old 10-06-2008, 05:42 PM   #21
PanelDeland
The 377 mentioned is a 350 crank in a 400 block.It is a RPM motor.The 383 builds it's torque down low in the streetable RPMs the 377 needs more RPMs to build it's power.
Go with a kit and plan ahead to upgrade heads.Even if you use the Patriots you may want more later.
Old 10-06-2008, 05:58 PM   #22
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
I have an old school 383 but if I were to make changes to it for more power, it would be to modernize it with a roller cam and roller rocker setup and some fast burn heads.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 10-07-2008, 09:57 PM   #23
prg machine
mine cost 3k fully assembled. full block I put the intake on and water pump etc. I never saw the engine except the heads, and flywheel I gave them to use. The shop had the block and got the rest for me.
I picked up the roller stuff and dropped it off a few months before it was finished.
I would do it all over again.
Lindvig Machine, Phoenix , Oregon if anyone wonders who did it.
THIS IS NOT AN AD.
383 .040 over
Old 10-09-2008, 03:13 PM   #24
gintaras
what heads?
2004 VW R32 450 HP money pit (faster than a Viper in the 1320 )
2001.5 VW Passat beater
1972 Custom Deluxe Highlander 69k miles and counting, all original, even the paint
gintaras is offline   Reply With Quote
Old 10-09-2008, 03:28 PM   #25
pocketpool
377 is also a standard bore 350 with 400 crank.
bore x bore x stroke x .7854 x 8 = 376.9
pocketpool is offline   Reply With Quote
