Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 10-27-2008, 12:26 PM   #1
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
68 GMC 4x4 Suburban build up
UPADTE SOLD
Well I am going to start a build thread for my Suburban now that I seem to have a little free time to get started on it. Help track the progress and all that.
Here is the thread with a back story on the burb
http://67-72chevytrucks.com/vboard/s...d.php?t=300128
First I am updating the suspension I have a diy4x4 4" shackle flip for the back the there B52 front kit to run 52" leaf springs in the front for 4" of lift. I have an 81 or so Jimmy parts truck which will be donated the rear leaf springs for the B52 kit along with the steering box and probably front axle for now.
I am going to check to see if Jimmy has 3:73 gears this week, hopefully it does because that would make my life a lot easier. If not I have a dana 44 14bff combo which will eventually go in to the Suburban but I want to fully rebuild those first and that will take more time.
68SWB4x4 is offline   Reply With Quote
Old 10-27-2008, 12:37 PM   #2
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Re: 68 GMC 4x4 Suburban build up
The build might be pretty slow on this as between work,school and training I am pretty busy. Plus the truck is an hour away at my moms ranch. I'll mainly be working on it on the weekends. After I get the suspension done I will take it down to my house and progress will be faster. I started on the rear shackle flip yesterday and got the gas tank out. and started grinding the rivet heads off. Had to cut it short as I got a late start.
I also pulled the carpet out. Found a little rust in the floor and kick panel but nothing major at all. Going to clean up the floor and rust bullet the whole thing for now.
I'll take some pics when the shackle flip is done.
Old 10-27-2008, 10:34 PM   #3
1956cameo
1956cameo's Avatar
Looks like it will be a nice project. I just picked up a 72 chevy suburban myself. Let us know if the quad fits in the back, that will be interesting if it will. I also feel your pain on trying to work on a project that is an hour away. Right now I am working on a 70 swb chevy that is in my dads shop roughly an hour from my house. Keep us posted.
1956cameo is offline   Reply With Quote
Old 10-28-2008, 06:56 PM   #4
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Thanks man. It SHOULD fit, I did all the measurements. I have long travel suspension on my quad so its a bit lower than stock which the height would be the real problem most of the time I think. To find that I need to get the quad running to, lol.
Was near the truck during work so figure I'd get some work done on it during lunch but I guess my air chisel broke from sitting around..... I have another one at my house which I'll grab tomorrow.
Old 10-29-2008, 08:32 PM   #5
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Good luck with the Burb project Kalle. It looks like a great start.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 10-30-2008, 04:27 PM   #6
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Thanks man.
We'll I started getting the rivets out and after quickly removing two with the air chisel my compressor wouldn't turn on...... what a POS craftsmen 6hp..... Ive had it for about 3 years and used it for little more than filling up tires. I guess that was all it was good for..... I'll probably be pretty hung over this weekend but I'll try to get it done this weekend.....
Old 06-26-2009, 06:17 PM   #7
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
haha how is that for time between updates? I took some extended time off to focus on other things but did get the rear shackle flip done, along with some custom rear shackles from diy4x for a 67-68 with the wider rear springs.
before
after
Old 06-26-2009, 06:29 PM   #8
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
here is the shackle flip and the custom cross tied shackle diy4x made up for the wider 68 springs.
Hopefully going to tear into the front this weekend.
Old 06-26-2009, 09:37 PM   #9
84 400
Sb 400 club
84 400's Avatar
nice work i went with DIY4x stuff to flip my rear shackel too.
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 06-26-2009, 09:55 PM   #10
Liz
Catchy title goes here..
Liz's Avatar
at least its not as "extended" as last time... bout time you did something
Liz is offline   Reply With Quote
Old 06-27-2009, 12:04 PM   #11
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Thanks. Liz, LOL. I was doing stuff while I was gone
I have to go to work in a couple hours but hopefully I can at least get the front up on jacks and ready to be torn out today.
Old 06-27-2009, 12:51 PM   #12
Yukon Jack
Yukon Jack's Avatar
Good to see you working on it!
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 06-27-2009, 10:16 PM   #13
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Thanks Jack I agree!
Got more done today than I thought I would. got the front end up on jacks. and unbolted the leaf springs and everything else needed to pull the front end out with the leaf springs attached. I would have went and pulled it out today but I didn't have a 15/16 wrench/socket here for the tie rod bolt. Not sure if I'll be at my truck tomorrow but I am going to try so I can get the axle out and remove the spring hangers for the B52 kit.
Old 06-29-2009, 09:19 PM   #14
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Front suspension and POS closed knuckle front end removed. Hell yea
bye bye pos
Lifted the axle for fun a few times. wasn't heavy just with the pumpkin on the pass side off center made it odd. I'll do some real lifts with the 12 bolt when I pull it.
Painted the parts for my B52 kit from DIY4x semi gloss black to keep it low key and easy to retouch it up. hopefully late this week or weekend I will cut all the rivets out for the stock leaf spring hangers and clean up the front frame rails and spray it with paint. than I got to rebuild my 3/4 dana 44 and pull the rear leaf springs out of my 84 jimmy parts truck
Old 06-29-2009, 09:46 PM   #15
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
axle lift, haha
Old 07-03-2009, 11:00 PM   #16
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
wacked all the rivets off with my air chisel today and wire brushed most of the gunk away from the front frame rails for paint. removed the steering box and ran into a little issue. one of the nuts was stripped real bad so I got my air chisel and was going to just bust through the nut but it ended up cutting a grove in it and backing it loose so I sat there holding a wrench in one hand while hitting the nut with the air chisel in the other slowly but surely until it came off. Holy crap I couldn't close my hand after this. Serious arm pump reminded me of my motocross days!
Also started to put a new HEI, plugs and wires in my 75 jimmy which was going well until I realized I ordered plug wires for a points dizzy nfing clue how I did that..... WHOOPS!
Old 07-08-2009, 09:35 PM   #17
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
got all the stock shackles and frame hangers off FINALLY today. Damn I hate rivets and my **** craftsmen compressor. But its all done so the easy stuff now. Hopefully I'll clean the front frame up paint and put all the diy4x b52 stuff on this weekend.
Old 07-09-2009, 02:00 PM   #18
70rs/ss
70rs/ss's Avatar
Picts man, we need picts!! I have loved this burb since you bought it way back when, glad to see you are still workin on it!
70rs/ss is offline   Reply With Quote
Old 07-12-2009, 05:43 PM   #19
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Thanka man. I've been having a lot of fun working on it lately!
Cleaned up the front frame rails and spray painted them semi gloss black yesterday.
Bolted up the diy4x front shackle hangers today. Drilled out the frame for the bolt holes for the bottom of the frame rail.
Thought I was done with rivets!! I forgot the fb52 kit uses the front body mount holes for the back two bolts on the rear shackle hanger so I chiseled the drivers side out. My plaguing problem of my POS compressor of course stalls the project at every corner as it only likes to cycle on 1-2 times a day! I'll get the pass side out tomorrow than I have to hole saw the frame for the new location. Not looking forward to that. I assume its a bad idea to not weld up the old hole right?
do you use every one of these three holes?
Got to pull the rear springs off my parts blazer and start rebuilding the 3/4 dana 44 and get all the parts for crossover steering.....
Is there any reason to run a HI steer crossover steering kit if I'm not going to wheel hard? Instead of a standard crossover steering?
Old 07-13-2009, 09:12 PM   #20
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Drilled the extra bolt holes for the rear hanger mounts. Damn this kit makes it easy with the included STEEL template. No guess work here! Went to drill the 2" hole for the hanger bushing. Guess a 5 dollar harbor freight hole saw won't work here. LOL pilot bit snapped RIGHT AWAY. Just went and picked up a GOOD hole saw so this should hopefully get done later in the week!
Old 07-17-2009, 06:30 PM   #21
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Running into problems with my stupid drill....... Drilled the first 2" hole easy no problem. Now the 2nd one is taking forever! the hole saw bit being more worn down is probably some of it. And my batteries for my newish 19.2 volt lithium ion drill are draining out very very fast. DON'T BUY ONE OF THESE! My friend bought one and the motor burnt up on him. lol...
Should be done by now.... Oh well
Also. Noticed the same owner I bought my suburban from for 1500 had a 70 k10 stepside 4x4 with a 4 sale sign in it. I went to check it out and it was in a lot rougher shape than my burb, bare bones with a 292 manual everything and it was listed for 3500?
Old 07-19-2009, 10:41 PM   #22
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
nothing done on the suburban got done this weekend I got a little side tracked and bought this
Well at least it came with an extra msd pro billet, wires, 6al box and edelbrock performer manifold which will find its way onto the burb
Old 07-19-2009, 10:47 PM   #23
Rack Man
AHH...First Gen Camaro....NICE!....Without Doubt, My First Love!
So what do you got hiding under the hood of that 68?
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=309288
Rack Man is offline   Reply With Quote
Old 07-20-2009, 03:08 PM   #24
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Thanks man its a blast
ZZ3 383 crate motor and a Richmond 5 speed. i put a thread up in general discussion about it.
Old 07-25-2009, 09:01 PM   #25
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Got both the 2" holes drilled for the rear shackle hangers finnally!
52" springs from the rear of an 84 K5. Got those removed today. Damn u bolts where hell to remove by hand. Forearms getting huge wrenching on trucks again. haha.
I assume its probably best to take the add a leafs/ overloads out right?
