Old 11-19-2008, 11:19 PM   #1
Hazieview
Building Dreams out of Dimes!
Let see some custom EXTENDED CABS!!!
I never see any extended cab square bodies. EVER!!! Let see some!!!
Hazieview is offline   Reply With Quote
Old 11-19-2008, 11:33 PM   #2
toomanytoyz
Luv the Crewcabs
toomanytoyz's Avatar
Re: Let see some custom EXTENDED CABS!!!
Here You Are............
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
toomanytoyz is offline   Reply With Quote
Old 11-19-2008, 11:40 PM   #3
toomanytoyz
Luv the Crewcabs
A Few More..............
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
Old 11-20-2008, 12:53 AM   #4
joe231
joe231's Avatar
the proportions on this one look 'right' to me
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 11-20-2008, 06:47 AM   #5
Ds86C10
2WD 4 Life
Ds86C10's Avatar
hmmm i was think of extending the cab of my truck only instead the normal way of doing it, i want to do it by adding length to the cab and the doors... the only costly issue i see is the door glass. anyone done it like this before?
Big D
1969 c10
1960 cadillac
1978 king cobra
Ds86C10 is offline   Reply With Quote
Old 11-20-2008, 08:16 AM   #6
logan91k
logan91k's Avatar
that green dually on the top looks kinda cool! :P
logan91k is offline   Reply With Quote
Old 11-20-2008, 08:39 AM   #7
bigblock73
yeller
bigblock73's Avatar
I saw a 67-72 done like that before, it was in a ton of magazines and what not...this was several years ago. It did look pretty cool, but a LOT of work.
As far as 73-87 extended cabs, I have yet to see one that looks decent TO ME. Every one I have seen just didn't have the proportions or styling quite right. The red one woth the 3 spoke wheels is close, but there is still something about it I can't grip.
bigblock73 is offline   Reply With Quote
Old 11-20-2008, 10:30 AM   #8
evenmadderdawg
I feel like the window in the extended cab portion is never the right size, but that last one that joe231 commented on looks close...
evenmadderdawg is offline   Reply With Quote
Old 11-20-2008, 01:47 PM   #9
D13
D13's Avatar
OK, let's have fun with math.
Measure a front fender, a door, and a bed side. The ratios will come out to be alomost exactly multiples of 1/2.
So to make the extended cab look "right" it should also be a multiple of 1/2.
And these are BIG trucks, they want to taper front to back.
So: The green one needs just a little more window. The blue one has too much window plus the stepside looks odd. The white 2wd is too small and add (might look OK if it's a short bed, but need it to stop hiding behind the tree). The red dually has the right proportions with the added section but is too cluttered and the addition is odd looking. The white 4wd looks wrong because of the no glass look. The orange one has the cab right but really needs more bed and tire.
So take a dually bed and tires from the green, the cab from the orange, and the white paint and pinstripe from the 2wd, and...
One of you photoshop guys chime in here.....
To build it, take a 4 door dually and take 1/2 out of the rear door.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 11-20-2008, 02:46 PM   #10
Damien
Damien's Avatar
I think the rear section of the cab and rear windows need to be tapered like a blazer.
I can still count my vehicles on two... wait three hands.
Damien is offline   Reply With Quote
Old 11-20-2008, 03:44 PM   #11
ChaseDale3and8
ChaseDale3and8's Avatar
That purple 4x4 was here in Springfield Mo. at the 4-Wheel Jamboree. I had the opportunity to talk to the owner. He hand fabricated his cab extension by cutting a crew cab down and used Dodge Dakota side windows if I remember correctly.
He did a great job on it, but the rear windows that he used just aren't proportionate in height with the front windows which make them look out of place in my opinion. If he could have cut the windows down to the same height as the front windows, I think he'd have nailed the look perfectly. ...Joe
I'm not speedin'! I'm qualifyin'!
ChaseDale3and8 is offline   Reply With Quote
Old 11-20-2008, 03:49 PM   #12
evenmadderdawg
What if one used the back of a suburban, with half of the back window/forward leaning rear portion as the extended part. I realize it wouldn't be as straight up and down as the back of most cabs, but with some clever pie cuts, maybe it could be made close. I'm speaking as someone who has no experience with this level of graft, but perhaps its plausible...
Old 11-20-2008, 05:29 PM   #13
Pyrotechnic
Pyrotechnic's Avatar
I agree, it's all about the shape of the rear cab, the length, and most importantly, the window styling.
I would take a look at the glass opening on the rear doors of a suburban or crew cab, then go from there. By shrinking the length of the window but maintaining the height and general shape of the opening, you could really maintain proper styling. You could even sacrifice a set of suburban rear doors to get the metal for your window openings.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 11-20-2008, 06:51 PM   #14
toomanytoyz
Luv the Crewcabs
A Couple More i have saved.............
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
Old 11-21-2008, 07:12 AM   #15
D13
D13's Avatar
Look at the difference in the D pillar (sheet metal behind the window) on the orance to the new white one. The orange truck has the same amoutn of metal all the way around, the white on has a bigger pillar that looks "clunky".
I think Pyrotechnic hit it rignt, you really want to use 'door' sections not 'body' sections so the glass shape and inset flow with the front door.
If only I had a dually and didn't have 7 projects already...
1987 2 ton
Old 11-21-2008, 10:03 AM   #16
seanconnery
IMO, the 2 duallies look particularly evil. Especially the 2 tone bronze/white one with the front rollpan and updated Blazer nose. The wheels on that one look really interesting. Almost like the centercaps were custom machined. The shortbed looks better than the traditional longbed dually setups too.
G to the M to the C......fool!
RIP Jerry Reed "The Snowman"
seanconnery is offline   Reply With Quote
Old 09-29-2009, 08:03 AM   #17
bobs84
my 84
bobs84 is offline   Reply With Quote
Old 09-29-2009, 10:05 AM   #18
thirdstreettito
Resident of Here
thirdstreettito's Avatar
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 09-29-2009, 10:11 AM   #19
thirdstreettito
Resident of Here
~Bradley~
Miss having a truck
Old 09-29-2009, 10:18 AM   #20
thirdstreettito
Resident of Here
~Bradley~
Miss having a truck
Old 10-03-2009, 09:46 PM   #21
rare86
Extended cab fanatic
rare86's Avatar
A few more. The first two are mine, the black truck is one on Ebay right now
rare86 is offline   Reply With Quote
Old 10-03-2009, 10:18 PM   #22
Scootin 81 C20
3/4 Ton Rodder
Scootin 81 C20's Avatar
Okay, after seeing these, it makes me think, "Are there any extended cab 67-72's out there?"
1981 Chevy Scottsdale C20 "Orange Crush": SOLD
1989 Chevy Silverado K2500: All Stock (For Now), 350 TBI/700R4. DD/Light Duty Toy.
Scootin 81 C20 is offline   Reply With Quote
Old 10-04-2009, 01:43 PM   #23
ghettoluxury
ghettoluxury's Avatar
This crew has the best exicution of the extended cab that I have seen
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 10-05-2009, 06:37 PM   #24
rare86
rare86's Avatar
More coming your way.
If it has a motor, it has my attention.
Old 10-05-2009, 07:25 PM   #25
Pyrotechnic
That one looks really good to me. The slope of the cab toward the rear is just like the 88-88 trucks and seems to be what a lot of them are missing. Only thing that would be the icing on the cake is to extend the frame and use a regular short bed on it.
