Old 11-24-2008, 04:56 PM   #1
stunna
2 piston brake calipers
Are there any 2 piston calipers from other GM vehicles we can use on our trucks when doing a brake disc swap?
stunna is offline   Reply With Quote
Old 11-24-2008, 06:56 PM   #2
ak's-r-us
Re: 2 piston brake calipers
deleted
ak's-r-us is offline   Reply With Quote
Old 11-24-2008, 07:29 PM   #3
stunna
Originally Posted by ak's-r-us View Post
im using 2 pot super duty calipers on a smooth pumpkin D70 in the rear of my wood truck. i am looking at running newer dodge 13"/4pot stuff on the front D60 after i wear out this set of tires.... so i can go up to 17/18" wheels for caliper clearance.
edit... nevermind, your talkin 2wd stuff. baer has all the good stuff.
yeah i am taliking 2wd stuff, you had me going there, thanks for input anyway.
Old 11-24-2008, 08:42 PM   #4
stunna
Anybody??? Gotta be somebody who has looked into this.
Old 11-24-2008, 08:43 PM   #5
Painter D
Painter D's Avatar
I'd like to know as well.
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs)
'63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs)
http://67-72chevytrucks.com/vboard/s...=528853&page=5
Painter D is offline   Reply With Quote
Old 11-24-2008, 09:20 PM   #6
danman987123
danman987123's Avatar
camaro calipers, chevelle rotors if you want 5x4.75 bolt pattern. it all works, camaro calipers i had on mine but soon im going to get the 13'' big brake from mcgaughys....
danman987123 is offline   Reply With Quote
Old 11-24-2008, 09:21 PM   #7
danman987123
oops....sorry i believe camaro calipers are not dual piston....sorry....the parts i was talkin bout is from 68 camaro calipers. 71 chevelle rotors. sorry i believe its a single piston though
Old 11-24-2008, 09:22 PM   #8
Chevy1TonFun
Grease Monkey
Chevy1TonFun's Avatar
Early Classics Enterprises in Fresno,CA has an awesome setup. 559-291-1611
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax
Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053
Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs
FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12
Chevy1TonFun is offline   Reply With Quote
Old 11-25-2008, 01:23 AM   #9
stunna
i checked their site and only saw 1 piston calipers. Maybe i missed something. I am trying to build a kit using 73-87 parts but with dual piston calipers from another vehicle. I thought for sure there was something out there. I guess we will see as more responses to this thread come in.
Old 11-25-2008, 01:39 AM   #10
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Actually the only "bolt on" dual pistion calipers I have seen for the GM D52 mount (i.e. the stock single piston ones until the "metric" style came into play) are made by Howe Racing and Stainless Steel Brake Company. Someone on the board tried them out and the only issue they found was where the pins ride in the caliper, they are not machined to use the "o-rings" so they have a little play in them. I haven't seen anyone using the SSBC ones but haven't searched that hard.
Most "big brake" kits require modifying the spindle by cutting the caliper ears off, drilling and tapping a couple holes and using a bolt on bracket that allows GM style PBR dual pistion calipers. This is mainly what Baer brakes does on a number of GM applications.
Good luck on your search and share what info you find.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 11-25-2008, 04:17 AM   #11
Brad
Out of the carpool lane.
Brad's Avatar
Ackattack did this and had a thread recently.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 11-25-2008, 08:54 AM   #12
stunna
yeah your right, thats what i've been finding. If i could find out what model year caliper they are using i could probably have a bracket made or if someone had a bracket, that would be great.
Old 11-25-2008, 01:46 PM   #13
stunna
anybody got a link to this thread?
Old 11-25-2008, 03:30 PM   #14
Ackattack
Ackattack's Avatar
There is some info about them in my build thread, and then this thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=307288
Basically, I think I'm going to get some delrin bushings made that will press fit into the calipers. I haven't gotten around to figuring out the specs for the machine shop to make them for me.
Ackattack is offline   Reply With Quote
Old 11-25-2008, 11:15 PM   #15
stunna
Thanks for the info man! In your opinion are those calipers worth the hassle? I have seen some used ones for sale on ebay for about 80 bucks.
Old 11-26-2008, 12:15 AM   #16
Ackattack
Ackattack's Avatar
I haven't driven my truck (ever!) so I can't say. But honestly, probably not.
I really think a lot of improvements can be made by simply upgrading to a good brake pad. In addition to the Howe calipers, I'm also using some Hawk HPS pads, and that's probably where a majority of braking improvement will come from.
Old 11-26-2008, 12:36 AM   #17
stunna
Thanks for the info man, thats probably what i will do. I thought someone made a bracket or something to use a later model GM 2 piston caliper, similar to what mcgaughys did on their big brake kit. I may just end up doing that if i get the money.
Old 11-26-2008, 12:44 AM   #18
Ackattack
Ackattack's Avatar
There was some info about Kore3 offering a big brake kit that uses a corvette caliper. It also used a corvette rotor, a bracket, and a special hub to allow you to use the corvette rotor. Last time I checked it wasn't available yet.
Old 11-26-2008, 01:07 AM   #19
danman987123
i thought i was going to have that trouble with the big brake kit. but the 13'' rotors come with new loaded calipers as well as spindles all the bearings and even brake hoses and all the bolts you need. mcgaughy's the spindle and everything else just goes on to stock ball joints. http://www.mcgaughys.com/newproducts.html scroll towards bottom.
i havent ordered the kit yet. but when i do come to that point, thats the route im going.
Old 11-26-2008, 09:17 AM   #20
stunna
im kinda leaning that way too. Not many choices regarding this unless you want to spend a ton of money on Baer. Mcgaughys seems to be the choice. I haven,t heard from anyone who has installed the kit yet.
Old 11-27-2008, 01:25 AM   #21
danman987123
ya im sure baer is really great, and works awesome but a couple grand for brakes... even if you just paid like 12 hundred for front and another 12 for back...thats 2400 for 4 wheel disc baer brakes....ALOT OF MONEY. MAYBE ITS WORTH IT BUT I WILL NEVER KNOW I JUST CANT AFFORD TO SPEND A COUPLE GRAND ON BRAKES. MCGAUGHY'S DOES SEEM TO BE GOOD THOUGH....ABOUT 700. I BELIEVE STUNNA SAID YOU CAN GET THEM FOR ABOUT 500 FROM GODFATHER CUSTOMS....HAVENT CALLED YET..
Old 11-27-2008, 07:48 PM   #22
stunna
I called Godfathers on tuesday and Stan said the kit is $619.00 for the front with free shipping to most locations. Still a great deal! I still haven't heard from anyone who has this kit installed. Anybody??
Old 11-28-2008, 11:36 PM   #23
stunna
Anybody install mcgaughys big brake kit??
Old 11-28-2008, 11:36 PM   #24
stunna
bump, bump
Old 12-08-2008, 09:30 PM   #25
stunna
just an update on this. I found out today that performance online has a 2 piston aluminum caliper for 71-87 trucks. You have to trim about 1/4 off your spindle, but no special brackets! The price is $184.00 a pair and 95.00 more for polished. They are not the Howe calipers that they were selling ( i asked) They don't have it on their website yet but they are available NOW There is a picture of the single piston version in the Dec issue of CCT. Finally something affordable!
