My 65 Build
Figured I would quit lurking and add my truck/build. My name is Nick and I reside in Phoenix.
Bought my truck from my grandfather, who bought it brand new. It is a LWB 1/2 ton 283 3 on the tree. Have done disk brakes, 5 lug swap, gas tank out of a 55 chevy car under the bed. HEI 4 barrell, dual flowmasters, turbo 400 swap when 3 speed broke 2nd gear. Its a clean truck and a good plat form to start my cruiser project with. Sorry the first handful of pictures are scans. Didn't have digital cameras 15 years ago. The first pic was taken at G Pa's house circa early 70's I beleive. The rest of the pics are before and after I got the wheels for it. Prime 5 star aluminums 15x8.5 in the rear and 15x7 in the front. |
Wheelin' and Dealin'
Re: My 65 Build
looks likea good solid truck
1965 Chevy c-10 fleetside long bed with 06 gto LS2/T56 inside ![]() Porterbuilt Extreme front and rear 12bolt w/ eaton tru-trac 4:11 gears ![]() ![]() my build thread: ![]() http://67-72chevytrucks.com/vboard/s...=1#post2601700 |
Re: My 65 Build
A few more of the older pictures of it. Then I will bring it up to date.
The first picture is me using it as a work truck. ![]() The second is with my lake hot rod. ![]() |
1 thing at a time is progress.
Re: My 65 Build
Welcome aboard from North Georgia. Nice truck and a great history of it.
Alan
Philippians 2:14-16 |
Re: My 65 Build
So around my birthday this year, when the 110 degree days went to the way side, I decided I was tired of seeing my truck sit(it has been sitting for 3 years) and decided it was time to go to work on it. Not sure of all the pictures I have of the dismantalling process. However I pulled the complete front clip and suspension, cross members out of it. I have had a 355 sitting in the garage waiting to go in it. Out with the 283, and begin the cleaning/degreasing and painting process. When I pulled the front clip in late sept I wasn't sure to which degree I was going to go, however it consumed me.
Re: My 65 Build
So once I got everything out of the way and could see what i had to work with. I started to clean things up. The frame and firewall (removing that factory undercoater is a real m f r).
Re: My 65 Build
So I started cleaning up the firewall and decided it would look super sweet if it was smoothed out. I have to admit alot of peoples trucks on here have given me ideas and motivation.
Re: My 65 Build
This is my first time ever doing any kind of body work. My dad is a welder by trade so I know how to weld a little bit. I can't beleive how much work it took to get the firewall the way I wanted it. Of couse I don't know all the tricks to doing filler work fast. So I basically put it on, sand 98% of it off, repeat. I finally got it all pretty flat and smooth though.
Re: My 65 Build
After I got the firewall almost to where I wanted it. I took a break from it, finished cleaning up the frame and shot some epoxy primer on it. I used ppg DPLF, I know it is pricey, however I am doing this truck in stages, until it is all ready for paint, and my budget allows me to buy the good stuff. So I wanted the blue color primer for things that will not be top coated at the present time.
Re: My 65 Build
Then I shot some color on the frame. Alan I know it is similar colors to yours, however I had the same color scheme in my mind while you were doing your build. Once I saw yours, it assured me it would look good. I don't have any pictures, however I have painted the crossmember with Eastwoods ceramik chassis black, and I will be painting the rest of the suspension components with that paint.
Re: My 65 Build
This last section will bring you up to current on my build for the moment. I finally got the firewall as good as I could get it, without having a solid color to work with and block from. Then I shot some epoxy primer on it.
Next up is finish cleaning and painting the control arms and spindles. Re assemble front end. Send out front clip to be media blasted (save time over me cleaning the stuff ) weld up holes in the fender wells. Start assembling engine and paint it. Hope to be able to drive it next month. |
Re: My 65 Build
wow man, looks good!
very nice work! welcome!
#13 | |
Re: My 65 Build
Alan
chevy only
![]() Join Date: Sep 2006
Re: My 65 Build
welcome, nice work what part of phx are you in?
CHEVY ONLY... Nothin Else ! |
#15 |
Hollister, CA.
Re: My 65 Build
X2 !!
![]() Welcome from California
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
#16 |
Re: My 65 Build
#17 |
283 Drama Queen
![]() Join Date: Dec 2004
Re: My 65 Build
![]() ![]() Welcome from SoCal!
For about 12 years of my adult life I had a severe speech impediment. My ex-wife never let me get a word in edgewise. |
#18 |
Its Deja Vu time again
Re: My 65 Build
Man seeing this stuff really gives me hope I can do mine.
![]() Thats just awesome and thank you for that comment that you've not done that stuff before because it lets people like myself know that heck if he can do it so can I. ![]() |
#19 | |
Re: My 65 Build
The welding was all done with a gasless flux core, harbor freight style welder. Not the welder of choice, however I borrowed it from a friend, and it worked. My dad has a nice mig and tig at his house, but he is an hour a way, no practical way of getting his stuff here or my truck there. The filler work is what took the most amount of time. One tool that saved a load of time with the filler that I aquired, is a pneumatic bar sander. I have a home remodeling and repair company, and I do alot of paint spraying. Though its not exactly the same, some of the basic techniques are the same. 50/50 over lap, keeping the tip perpendicular to the surface... such on and so forth. I learned alot from the different threads on this board. I bought a semi cheap paint spray gun from the Home Depot. Read on how to set it up, messed with it, painting some non useable parts. Its not perfect, but I'm building a cruiser not a trailer queen. I will gladly give you any tips I learned along the way, just ask. ![]() I'm excited to get it back together. I am putting power steering and brakes on it this time, it was all manual before. Its not the most conventional way of restoring a truck, however I don't have a garage to work on it in, and I wanted to be able to drive it while the weather is still cool in the spring, so I opted to just do the front section first. Next I will clean up and spray some paint in the interior. I have an extra set of bed sides, so I can start on the body work on those before removing the bed and doing the rear end. I am not doing any major frame modifications, just a static drop for now. Maybe air ride down the road. Any how enough of my rambling for now. ![]() ![]() |
#20 |
Re: My 65 Build
Very nice...
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi 1961 Impala SS 348/350 4-speed 3:70 Posi 1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed 1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear 1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc 1949 Transitier 3-wheel forklift Crosley 4-Banger 98' FXD 2002 2500HD |
#21 |
Re: My 65 Build
I like what you did to the firewall. I'm going try to clean mine up as good as you did, thanks for the pictures. What's a pneumatic bar sander? This is where I am now.
#22 | |
Re: My 65 Build
Here is a picture of a bar sander. Hooks up to an air compressor, and it moves back and forth. Very helpful in getting the panels flat. Luckily my dad had one, so I just borrowed it. I cut the small raised panel where the blower motor goes through completely out and patched in a piece of 16 ga sheet metal. Once I get the motor put back in. I will then figure out where to run my wires through. I plan on relocating the main wire harness, to where it comes out just under the fender well, and running the wires in a donduit of some sort under the fender well. |
#23 | |
Re: My 65 Build
Alan
#24 |
Tot Roddin'
Re: My 65 Build
Nice looking build, keep up the good work!
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
#25 |
Re: My 65 Build
Made some headway today, while the rain took a bit of a break. Dropped the fenderwells and core support off at the blaster to be media blasted. Sorry no pics of that.
Started stabbing some parts back in. Crossmember, rad. support, core support mounts, power steering box. got the column test fitted (sorry no pics of that) |
