Old 12-16-2008, 04:41 PM   #1
cppursell
cppursell's Avatar
Quiet down my cab
Hi,
I want to quiet down the cab in my '67 Chevy C10. Right now it's bare metal all around (except for this tar-like insulation on the floor). I'm planning on putting in a new rubber floormat on the floor, but I thought putting some reflective insulation from Home Depot under the floormat would quiet things down even more. I also thought of putting some more insulation behind the door panels...
Are there any other tips you guys have to quieting down my cab, so I can think while driving on the freeway? Thanks!
cppursell is offline   Reply With Quote
Old 12-16-2008, 04:56 PM   #2
nightmare
nightmare's Avatar
Re: Quiet down my cab
invest in the Dynamat stuff. It works great as a sound deadener, and as a heat shield. Also, if you haven't done it already, make sure your door seals are good. i replaced mine with the ones from an early '90's suburban, and they just pushed right on to the pinch weld. no gluing. good luck with it, and post some pics when you get a chance.
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is offline   Reply With Quote
Old 12-16-2008, 05:11 PM   #3
AK72K10
AK72K10's Avatar
Dynamat...period, end of story.
AK
______________________________
1972 K10 Custom Deluxe 350/350
2008 Suburban LTZ White Diamond
1972 F100 302
"Why Build It If You Can't Drive It?"
AK72K10 is offline   Reply With Quote
Old 12-16-2008, 05:37 PM   #4
69sixpackbee
I used this stuff from McMaster-Carr:
#9709T39
Sound and Vibration Damping Sheet EVA Mastic, .079" Thick, 32" X 54"
In stock at $16.62 Each
And topped it with this:
#9367K65
Foil-Faced Bubble Wrap Insulation 36" Wide, 25 ft Roll Length
In stock at $46.53 Each
...which I glued on with 3M spray adhesive on top of the sound deadener sheets. I put it inside the WHOLE cab top (under the headliner) and bottom, front to back, inside the doors and under the dash. Far cheaper than Dynamat and my truck is so quiet it literally sounds like a Caddy when driving. Not to mention all of my door rubbers and window seals are fairly new as well.
Save some bucks..Dynamat is too expensive (at least for me).
Good luck,
Bud
69sixpackbee is offline   Reply With Quote
Old 12-16-2008, 07:44 PM   #5
bigguy69
dazed and confused
bigguy69's Avatar
i noticed you said in stock. Where did you get it at? im not cheap just broke!
bigguy69 is offline   Reply With Quote
Old 12-16-2008, 07:47 PM   #6
69sixpackbee
http://www.mcmaster.com/
Old 12-16-2008, 07:53 PM   #7
jorgensensc
jorgensensc's Avatar
I wrote a thread about this same subject not too long ago. it seems that everyone has an opinion. After all of my research I decided to go with RAAM MAT. I found that you are paying a lot of money for the name Dynamat, when other products are just as comparable. I found that the butyl sound deadener is the best, but also the most expensive. Second skin got great reveiws, but is extremely expensive. I ended up getting RAAM Mat because it had the best cost/ quality factor for me. I haven't done a complete install in the burb yet, but I have noticed a big difference by just installing it in the cargo area walls. i have nothing in the burb except the front seat and middle seat. No carpet, or door panels. It is a 402 BBC with Dual Dynomax exhaust. Needless to say it was load, and still is fairly loud inside, but it has went down significantly. JMHO.
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 12-16-2008, 08:28 PM   #8
AK72K10
AK72K10's Avatar
Hmmm, how about Rhino Lining? Anyone ever use this inside their cab and notice if it helped reduce the road noise? I am assuming it would, the stuff in my old truck bed was almost 1/4" thick, heck I bet if someone did a frame-off and Rhino'd both the inside AND the bottom it would really work well, not to mention helping to keep your rig from rusting out...any thoughts on this?
AK
1972 F100 302
Old 12-16-2008, 08:39 PM   #9
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Rhino and other bed liners have been used in street rods for several years.It does cut road noise and makes a cab seem more solid.I have not had one done but rode in one and it seemed way more solid than others I've been in.It might also have been the build,but I tend to think the Rhino was what quieted it.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 12-16-2008, 08:41 PM   #10
69sixpackbee
I would agree about the RHino too for sure but I think the poster is looking for a more cost-effective solution to his dilemma. After all, Rhino=$$$
Old 12-16-2008, 09:59 PM   #11
big_al_71
big_al_71's Avatar
Talk about quiet,,, this is what I did.....Cool-it & material called jute.....
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 12-16-2008, 10:47 PM   #12
ETsC10
Hand Crafted C-10
ETsC10's Avatar
I invested in Second skin...note the word INVESTED...because it was pricey.
I did research it throughly at the SoundDeadenerShowdown site plus visiting many other sites.
I am convinced the $ is going to prove well spent; not for the results especially (though they should prove top-drawer), but also the longevity of the product. I will probably always own the truck and don't want to mess with a failed product installed after my cab is reassembled.
Also, consider the fact that just patches of any sound deadener can reduce the noise in the cab.
...sympathetic noises can be slowed with sound deadening.
If you check out some sites related to sound transmission in duct work (household), you can better get a grasp of the mechanics of how weird noises can travel.
PS--for a deal, look on the board, CL or eBay for your final choice
..and there is my .02 worth
ETsC10 is offline   Reply With Quote
Old 12-16-2008, 11:50 PM   #13
Gray Ghost
Gray Ghost's Avatar
If you are on a budget, go to Home Depot and get what I did....basically foil bubble wrap on a roll....25' x2' for about $10. Got some 3m spray adhesive and locked it down under the carpet...easy and QUIET!
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
Old 12-17-2008, 12:32 AM   #14
moon
moon's Avatar
I bought 2 rolls of this stuff and will hopefully install it over the Christmas weekend.
http://cgi.ebay.com/ebaymotors/Autom...spagenameZWDVW
This price is good and the seller's reviews are excellent.
I'll posting for some install tips and advise next week...
moon is offline   Reply With Quote
Old 12-17-2008, 01:06 AM   #15
LuckyHenriksen
LuckyHenriksen's Avatar
If you have loud dual exhaust, add an X pipe. It did wonders for my pile
1968 Yenko Chevy LWB
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
LuckyHenriksen is offline   Reply With Quote
Old 12-17-2008, 01:17 AM   #16
Texasbigblock
Texasbigblock's Avatar
i used the do it yourself roll on bedliner called herculiner. I applied to both the bottom of the cab as well as the floor on the inside. After that i installed a carpet insulation under the carpet and it is pretty darn quiet inside. I also used the bedliner for the bottom side of the bed and the wheelwells, looks good and is very durable
-Scott-
1970 C10 shortbed 396
1969 C30 dually flatbed "Vidalia"
Texasbigblock is offline   Reply With Quote
Old 12-17-2008, 02:00 AM   #17
cppursell
cppursell's Avatar
Thumbs up Re: Quiet down my cab
Thanks for your great responses.
Yes, I am on the cheap. I think I'll get this stuff (if that's a good idea):
http://www.homedepot.com/webapp/wcs/...3+90401+527383
Old 12-17-2008, 02:06 AM   #18
Senator350
Senator350's Avatar
Also did the DIY liner on the entire floor of my '70. can't say it really quietted down much, but i didn't put carpet down either. i was pretty much in it for the durability... and i like the small block sound.
RN U OVR
Senator350 is offline   Reply With Quote
Old 12-17-2008, 12:01 PM   #19
68K30
I did my cab floor, kick panels and the tops of the rockers with Herculiner , two full coats took two quarts. It was on sale at Napa when I bought it and it was less than $50.00 for for the two quarts. It came out real nice and the floor definitly seems stiffer, this stuff seems real tough, if you drag your knuckles across it you will draw blood. This is the third cab floor replacement I have done in the 34 years I have owned this truck and I came to the conclusion that in Pennsylvania carpet, floor mats and sound deadeners can also be called floor rotters.
Hope this helps
68K30 is offline   Reply With Quote
Old 12-17-2008, 12:15 PM   #20
OLDIRON69
I did the same thing as Kelly and it worked wonders!
05 2500HD 6.0 excab
69 LWB-Gone but not forgotten!
68 Dodge Charger 383/727
69 Dodge Charger-440/4spd
OLDIRON69 is offline   Reply With Quote
Old 12-17-2008, 06:39 PM   #21
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Vortex is what I have on/in my bed, and it's gonna go on the cab floor and behind the gas tank when the body work is done and it's time to do it.
Member Nr. 2770
Old 12-17-2008, 08:56 PM   #22
BHRS
BHRS's Avatar
That is the same stuff I am thinking about using in mine. When you install it could you take some pictures and let us know how well it works? I am a little concerned about the thickness of it when installing it.
Thanks-
1972 Cheyenne C10
Unrestored Original-3 Owner-RUST FREE Texas Truck
Big Block-TH400-PS-PB-AC-AM/FM Radio
BHRS is offline   Reply With Quote
Old 12-17-2008, 09:29 PM   #23
cppursell
cppursell's Avatar
Thanks-
I went to Home Depot and they didn't have that stuff, the closest to it was pipe insulator in 12"x15' rolls. I later looked on Amazon and there's this great looking stuff, actually made for what we want to use it for:
Amazon.com: CSI 25070 Heat Shield Insulation: 4... Amazon.com: CSI 25070 Heat Shield Insulation: 4...
I'm buying this tonight, and will let you guys know how it turned out once I install it.
Old 12-17-2008, 09:58 PM   #24
v8blaze
For a cheap DIY sound deadener its either home depot or lowes sells a product called peal and seal. its an asphault type base with adhesive on one side and a foil liner on the other. On my s10 blazer my mufflers are very close to the floor and i put one layer in the rear passenger area and it helped alot. I have no experience with other "pricey" deadener but for 10 bucks a roll it made my truck bearable and kept my floor way cooler
v8blaze is offline   Reply With Quote
Old 12-21-2008, 02:15 AM   #25
cppursell
cppursell's Avatar
Okay! I'm all done! I bought the insulation from Amazon, it is great stuff. After it was in, I put in a rubber floor mat that I purchased earlier. Take a look:
Thanks for your advice, you steered me in the right direction.
