01-02-2009, 01:31 AM | #1 |
"La Veija"
Quick summary:
1968 C10, 454 BB I bought my truck around late Sept 2008. I bought an addtional frame to start the bag work. Then I started replacing part: Conversion kits, cab corners, shaving fenders and so. Took about 3/4 of an inch bondo from roof and rear middle cab. Then Decided to buy an original, no body work done cab. Puchased a Dropmember.... So here it goes. Last edited by C10Sim; 01-02-2009 at 01:32 AM. |
01-02-2009, 01:35 AM | #2 |
Re: Project "Dirty D"
Started to shave fenders and gas hole
01-02-2009, 01:37 AM | #3 |
Replaced the cab corner, which it went pretty smooth.
01-02-2009, 01:40 AM | #4 |
Nice progress
01-02-2009, 01:40 AM | #5 |
I discovered that my grill had a thick layer of bondo, so I cut the center stip that was bent and replaced with another.
01-02-2009, 01:46 AM | #6 |
Well I purchased this frame for $100 at a swap meet and water blasted it. It is only temporally, once frame gets bagged, it will be sent out for power coat.
Installed a 6 lug conversion kit. I purchased a Dropmember from Nate. This means all new springs, spindles, ball joints were pointless Last edited by C10Sim; 01-02-2009 at 01:47 AM. |
01-02-2009, 01:55 AM | #7 |
Well on New Years of 2009 I installed my dropmember, and 2 weeks before that I purchased a another cab because my truck cab had bad deep dents that had been badly work and it had to much streched metal. I decidedto buy a cab that had original paint job, that way I knew exactly what I was getting into. The good thing is that the cab corners dont need replacement but the rockers do (It ok because I was going to replace them on the other truck aswell). The floor need replacement but only a small place on driver side. Roof is in excellent condition
I am not done cutting the frame for the rack and pinion. I wanted to confirm it with Nate before anyrhing. I will try to keep posting. |
01-02-2009, 11:06 AM | #8 |
Resident of Here
Lookin good! Keep up the good work! What kind of welder do you use?
~Bradley~ 2004 Black GTO LS2/T56 too much to list Miss having a truck Last edited by thirdstreettito; 01-02-2009 at 11:07 AM. |
01-02-2009, 11:46 AM | #9 |
Its a Millermatic 130 XP. It works great but I am starting lean over the lincoln 135-140 it sound beatiful compared to my Miller (Maybe its just my machine). I will be getting a Lincoln today.
1968 Chevy Pickup http://67-72chevytrucks.com/vboard/s...d.php?t=321717 1959 Chevy Apache 3100 SWB Big Window http://67-72chevytrucks.com/vboard/s...d.php?t=597069 |
01-04-2009, 06:51 PM | #10 |
kool
nickle and dime |
01-15-2009, 03:19 AM | #11 |
Well I finally cut the frame to get clearence for therack and pinion.
01-15-2009, 03:23 AM | #12 |
Since I had the welder out, I went ahead and shaved the gas hole.
Phillip13 Donated the gas delete panel, Thank You!
01-15-2009, 03:26 AM | #13 |
This is the cab that I purchased for $50. Needs work but looking forward to it.
This just some of the rust that needs replacement. I will update as I finish a section.
1968 Chevy Pickup http://67-72chevytrucks.com/vboard/s...d.php?t=321717 1959 Chevy Apache 3100 SWB Big Window http://67-72chevytrucks.com/vboard/s...d.php?t=597069 Last edited by C10Sim; 01-15-2009 at 03:28 AM. |
01-15-2009, 03:31 AM | #14 |
I have started to shave the drip rail and replacing the rockers and pillars.
01-15-2009, 07:53 AM | #15 |
man thats looking good
01-15-2009, 09:20 AM | #16 |
Resident of Here
Lookin good! Keep it up!
~Bradley~ 2004 Black GTO LS2/T56 too much to list Miss having a truck |
01-17-2009, 10:25 AM | #17 |
THE DAMN YANKEE
Very nice, you do good work! Is that a DAMN YANKEE cab fuel tank delete panel?? LOL Phipp
01-17-2009, 12:59 PM | #18 |
Looking good Im watching this one....gotta love those stepsides lol.
03-29-2009, 11:38 PM | #19 |
Here goes an update March 29, 2009!
Well my business has increased, so my time is short now. I decided to get a cab that needed less work. I bought a cab off a board member and it was in real good condition. It only needs inner and outer rockers and cab corners plus my little extra areas that I want to shave. I fab'd in new inners and coated them with por-15. Then I installed the new outer rockers. I also bought a new raditor support, It's not as tough as the orginial but cost effective due to the work my orginial needed.
1968 Chevy Pickup http://67-72chevytrucks.com/vboard/s...d.php?t=321717 1959 Chevy Apache 3100 SWB Big Window http://67-72chevytrucks.com/vboard/s...d.php?t=597069 Last edited by C10Sim; 03-29-2009 at 11:40 PM. |
03-30-2009, 12:35 AM | #20 |
Went ahead and replced tthe passengers cab corner and coat the inside with por-15 aswell.
03-30-2009, 12:40 AM | #21 |
I really didnt want to shave the drip rails on this cab because they were in perfect condition but that's a different project.
03-30-2009, 12:48 AM | #22 |
I bought a short fleetside bed that had been garaged for 11 years and has no rust or body filler. The only defect is has is two door dings and a missing floor. The tail gate does need some work, but I will worry about that later.
I also bought 2 new doors from a friend that decided to go a different route (traded them for a new brakebooster) KYB shocks and lower bag plates. Installed a new power rack and pinion Here is another picture of the new raditior support. New items that are in thier way: -wiring hardness -step notch (porterbuilt) -2 inch steel cowl hood -euro headlights with trim -new door hinges
1968 Chevy Pickup http://67-72chevytrucks.com/vboard/s...d.php?t=321717 1959 Chevy Apache 3100 SWB Big Window http://67-72chevytrucks.com/vboard/s...d.php?t=597069 Last edited by C10Sim; 03-30-2009 at 12:52 AM. |
03-30-2009, 12:55 AM | #23 |
I went ahead and took my motor apart and will head to the machine shop within a couple of days.
1968 Chevy Pickup http://67-72chevytrucks.com/vboard/s...d.php?t=321717 1959 Chevy Apache 3100 SWB Big Window http://67-72chevytrucks.com/vboard/s...d.php?t=597069 Last edited by C10Sim; 03-30-2009 at 12:55 AM. |
03-30-2009, 07:30 AM | #24 |
VA72C10
Looking good...that's going to be a sweet ride when done..Dropmembered with a BB
Looking for a 67-72 swb or blazer project in or around VA. |
04-01-2009, 06:08 AM | #25 |
Thats looking pretty good
70 SWB STEPSIDE 70 BLAZER 09 challenger |
