Old 02-05-2009, 02:09 AM   #1
Twisted Minis
Twisted Minis's Avatar
Not so budget 3-link build
I have been asked by a few people to share more pictures of some of the stuff I am working on, so I figured I would start a thread. Not sure if this is out of place or not so let me know?
This is a higher than average budget build. More detail than normal, more TIG than normal, but these are the ones I like best. I wanted a semi desert style feel to this one, as far as fab goes.
Starting the notches.
Starting main cross member.
If you can find it cheaper, I can fix it!
Twisted Minis is offline   Reply With Quote
Old 02-05-2009, 02:10 AM   #2
Twisted Minis
Re: Not so budget 3-link build
Cross member mostly finished.
Of course this one had to be on the bottom..
Old 02-05-2009, 02:13 AM   #3
Twisted Minis
Relocating stock tank.
Added dimpled gussets to the upper link mount.
Tank mount/compressor tray.
Old 02-05-2009, 02:16 AM   #4
Twisted Minis
Cross member installed.
Lower link bars.
The pattern I used on the compressor tray was brought back for the wishbone, and will be used again later.
Old 02-05-2009, 02:17 AM   #5
Twisted Minis
Made a bracket to move the rear brake T back away from the link tabs.
Links attached permanently.
Old 02-05-2009, 02:19 AM   #6
Twisted Minis
Last one. Bag mounts meant to carry on the look of the wishbone in an asymmetrical way.
The side gusset connecting the bag cup to the frame is dimpled 1/8" plate. May as well be 1/4" at this point.
Old 02-05-2009, 02:37 AM   #7
FnLow69
FnLow69's Avatar
WOW.. looks very nice
FnLow69 is offline   Reply With Quote
Old 02-05-2009, 03:00 AM   #8
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Sweet
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 02-05-2009, 09:56 AM   #9
p8ntballer1911
Bodydropped71
p8ntballer1911's Avatar
Wow! looks great! I'm glad your building my wishbone
p8ntballer1911 is offline   Reply With Quote
Old 02-05-2009, 08:42 PM   #10
Sweet 85 C10
OG
Sweet 85 C10's Avatar
Killer build!!!!!
Sweet 85 C10 is offline   Reply With Quote
Old 02-05-2009, 09:07 PM   #11
p8ntballer1911
Bodydropped71
Originally Posted by Twisted Minis View Post
What are you using to get those indented holes in the sheet metal?
Old 02-05-2009, 11:41 PM   #12
Twisted Minis
The tool I use is called a dimple die. They are more common in Desert style fab than anything else. They are used because you can cut a hole in your material, making it lighter. And then you can dimple that hole, and create rigidity. This means you can use a lighter gauge material to achieve the same strength. Plus it looks cool while doing it. It's similar to bead rolling your floor boards.
I built mounts for the shocks as well as the limiting straps today.
I had to add just 2 more dimples to make the number a nice 25. I wasn't really feeling 23.
Shocks will be replaced. It's easier to mock up with old ones than it is to mask off new ones.
Old 02-06-2009, 12:30 AM   #13
gixxerpymp
wow.... Amazing work!
gixxerpymp is offline   Reply With Quote
Old 02-06-2009, 12:43 AM   #14
Walts_restoration
Real Projects never die
Walts_restoration's Avatar
give me a second... ive got to find where my jaw landed on the floor.
great job man.
Ill put it this way, ive got a few lawn ornaments
My name tag says Ryan
KansasTwister On other forums
Walts_restoration is offline   Reply With Quote
Old 02-06-2009, 01:51 AM   #15
evenmadderdawg
Dimples!!!!!!!!
evenmadderdawg is offline   Reply With Quote
Old 02-06-2009, 11:05 AM   #16
Sweet 85 C10
OG
Im still like wow!!! Great work!!!!! Makes me jealous!!!! Kinda makes me want to redo my whole project!!! Lol j/k
Old 02-06-2009, 11:22 PM   #17
'71 Surf Wagon
That is art, my dude.
'71 Surf Wagon is offline   Reply With Quote
Old 02-07-2009, 12:38 AM   #18
Frizzle Fry
Frizzle Fry's Avatar
Sick
Frizzle Fry is offline   Reply With Quote
Old 02-07-2009, 02:02 AM   #19
Twisted Minis
Thanks.
Pulled everything apart to paint it, and got it mostly reassembled. Started a little wiring too. Need to run fuel and power lines, and air lines. Last shot shows the limit strap and the bag compressed nicely.
Old 02-07-2009, 05:59 PM   #20
p8ntballer1911
Bodydropped71
Is there a need for a limit strap?
Old 02-07-2009, 06:07 PM   #21
Twisted Minis
Keeps the bags from overextending or "hanging the axle" when the truck is on a lift. Also ensures the drive shaft can never come in contact with the cross member below it. And it goes with the desert fab theme.
Old 02-07-2009, 08:07 PM   #22
OrangeAnimal
OrangeAnimal's Avatar
That is truly awesome. I am still trying to decide how I want to build my bag setup.
OrangeAnimal is offline   Reply With Quote
Old 02-08-2009, 08:47 PM   #23
nuke1
nuke1's Avatar
That is some really nice fab work you did there, i have wanted some dimple dies for a long time, but for now i have other things to spend my money on.
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 02-08-2009, 09:30 PM   #24
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
That's a sweet set up man, How much lift can you get using that joint on the wishbone? I've just never seen one done that way, but it looks killer man!
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 02-08-2009, 09:44 PM   #25
slimneverdies
slimneverdies's Avatar
Ah man! You should have left all that pretty metal bare and put some protectant over it. That thing should not have a bed put on it. Badd a$$
Long live SLIM
At least try to buy American
slimneverdies is offline   Reply With Quote
