Old 02-10-2009, 11:16 AM   #1
PBFAB.COM
PBFAB.COM's Avatar
Porterbuilt replacement trailing arm Xmember
Here's some pics of the version that is NOT set-up with the trailing arm tabs. This version is designed to bolt into the factory holes and has a mount for the carrier bearing. The version that employs the trailing arm tabs is almost identical. The obvious difference is that it has tabs for the trailing arms, and it's frame mounting plates are a bit longer and have more mounting holes allowing the user to adjust the location of the crossmember and center the wheels when compressed.
I have zero feedback if this crossmember will work with a one-piece drive-shaft. I designed it to meet the neeeds of those wanting to sit extremely low and NOT cut into the cab floor for driveshaft clearance, to achieve this, a two-piece drive-shaft is a must.
As I recieve more information/feedback on this product I will continue to update.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 02-10-2009, 11:33 AM   #2
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Re: Porterbuilt replacement trailing arm Xmember
Super cool
Is that a 88-98 carrier bearing ???
What will the price be for one of these for trailing arms ???
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 02-10-2009, 12:05 PM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
From another thread Nate says...
Originally Posted by porterbuilt View Post
The non-trailing arm version runs $199.
The trailing arm version runs $249.
Availabilty will depend on my work load at the time, but worst case would be 3-5 business days until it shipped.
Keep in mind, this unit is designed to use a two-piece drive-shaft... don't think there will be enough room with a one-piece.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-10-2009, 12:44 PM   #4
jlaird
jlaird's Avatar
Will this work with the "horse-shoe" style carrier bearing? If not, are the two carrier bearings interchangeable?
Also, I know that when I set up my 2 piece driveshaft, with the amount of drop I have, I had to alter the location of the carrier bearing to get the proper driveline angles. Is there adjustability in bearing placement? (in regards to vertical mounting height?) Looks like the carrier bearing could easily be shimmed, but would there be a need for it?
jlaird is offline   Reply With Quote
Old 02-10-2009, 04:09 PM   #5
gringoloco
A guy with a truck
gringoloco's Avatar
Mang, you are stayin' busy! I like your transition to tubular- your future products will benefit greatly in the looks dept. Almost makes me wish I was staying with trailing arms...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 02-10-2009, 04:14 PM   #6
sddwtcb
Guest
Posts: n/a
yes in deed!
Old 02-10-2009, 05:22 PM   #7
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Are you making the trailing arms too?
(Before I order my set-up from CPP)
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 02-10-2009, 05:28 PM   #8
n2billet
Village Idiot....
n2billet's Avatar
Yummy! what's the thickness of the tubes?
http://www.hubgarage.com/mygarage/n2billet
-67 SWB Custom Porterbuilt Front and rear 20/22's Hazel Sold
-71 StepSide Porterbuilt Stage 2 with 20/22's Stella Mae Sold
n2billet is offline   Reply With Quote
Old 02-10-2009, 06:23 PM   #9
fixit-p
fixit-p's Avatar
Thats awesome is there just as much room for the exhaust with the trailing arm version
fixit-p is offline   Reply With Quote
Old 02-10-2009, 09:14 PM   #10
stunna
does this bolt into the factory mounting holes or we drill new ones?
stunna is offline   Reply With Quote
Old 02-10-2009, 10:17 PM   #11
scotts62
One day...
scotts62's Avatar
Thats cool i like that!
Scott
93 crew cab build
Project 62
Old 02-10-2009, 10:45 PM   #12
Wild83C10
Wild83C10's Avatar
Read the second sentence of Nate's post. This isn't a picture book.
Nice work! Maybe you will be able to build one for a one piece driveshaft but for the 73-87 trucks. I still have plans to install trailing arms on my truck. The crossmember would be the only thing I would need to fab. After I get the C4 DP though.
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 02-11-2009, 01:23 AM   #13
PBFAB.COM
PBFAB.COM's Avatar
Originally Posted by jlaird View Post
Will this work with the shoe-horn style carrier bearing? If not, are the two carrier bearings interchangeable?
I fit this up with the motor and tranny installed to find the best location to weld the carrier bearing mounting tab. There is room to shim it up IF necessary.
I will have to locate the part number for this particular carrier bearing. If you could provide me with the measurements of the carrier you are referring to I would gladly check and see if it would work.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 02-11-2009, 01:25 AM   #14
PBFAB.COM
PBFAB.COM's Avatar
Wish.... WHATEVER! I think I like the round tube fabrication... maybe I can build something cool for you one day?
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 02-11-2009, 01:25 AM   #15
PBFAB.COM
PBFAB.COM's Avatar
Not yet... PM me.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 02-11-2009, 01:27 AM   #16
PBFAB.COM
PBFAB.COM's Avatar
The trailing arm version will have a little less space for the exhaust. But there will still be enough for 3" exhaust.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 02-11-2009, 01:27 AM   #17
PBFAB.COM
PBFAB.COM's Avatar
1.5 x.120 wall
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 02-11-2009, 01:28 AM   #18
PBFAB.COM
PBFAB.COM's Avatar
Factory mounting holes! It may be necessary to open them up a little. The three factory trailing arm x-members I measured varied by as much as .125".
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 02-11-2009, 01:32 AM   #19
jasonb72
PorterBuilt Man Crush
So when will the UPS man show up at my door?
The 72 will live again
jasonb72 is offline   Reply With Quote
Old 02-11-2009, 01:34 AM   #20
PBFAB.COM
PBFAB.COM's Avatar
Next week!
I wanted you to get your other box first!
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 02-11-2009, 02:01 AM   #21
jasonb72
And I was lovin it......
Old 02-11-2009, 09:29 AM   #22
jlaird
jlaird's Avatar
this is the carrier bearing style I was talking about. What year truck is the one your using?
Old 02-11-2009, 09:49 AM   #23
dieselarmy13
Phone's ringin Dude.
dieselarmy13's Avatar
Nice work, as always!
I pitty the fool with only two headlights!!
2003 SILVERADO SS--THE NEW GIRL
1972 GMC--THE OLD GIRL
dieselarmy13 is offline   Reply With Quote
Old 02-11-2009, 10:03 AM   #24
SCOTI
SCOTI's Avatar
Not yet... PM me.
??????????? PM the details brother.......
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-11-2009, 10:58 AM   #25
PBFAB.COM
PBFAB.COM's Avatar
Here's the specs on the carrier bearing:
It's out of a 95 Chevy 3500 with a 454.
The Carquest part# HB88107A.
The bore is 1.378.
JLaird- I don't know if the original style bearing will work... but this one does!
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
