Old 02-28-2009, 06:31 PM   #1
weav1
weav1's Avatar
Impala disk brake brackets
HERE ARE THE FIRST ONES I WILL HAVE THEM PERFECTED BY THE END OF THE WEEK AND READY TO SELL IM GOING TO CUT SOME OFF THE CORNERS TO MATCH THE MOUNTING SURFACE AND CLEAN EM UP A LITTLE I CAN MAKE THEM IN STEEL, STAINLESS STEEL, OR TITANIUM IM GOING TO PUT TOGETHER A COMPLETE KIT WITH EVERYTHING YOU WILL NEED TO INSTALL THEM PRICES ARE UP IN THE AIR RITE NOW BUT THEY WILL BE FAIR LET ME KNOW IF YOU ARE INTERESTED THANKS:chevy
UPDATE THE WILL BE READY TO SHIP ON SATURDAY THEY WILL BE $65 SHIPPED IN THE US THANKS GUYS
weav1 is offline   Reply With Quote
Old 02-28-2009, 07:00 PM   #2
badboy007
badboy007's Avatar
Re: Impala disk brake brackets
Count me in. Just let me know how much and when.
badboy007 is offline   Reply With Quote
Old 02-28-2009, 10:24 PM   #3
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
I am very interested. Thanks for keeping me in the loop through all this. I would like a price on the steel ones with shipping to Apex NC, 27523. Any pics installed. Just wanting to make sure the pad contact is centered on the rotor. Thanks again.
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 02-28-2009, 10:58 PM   #4
lks dcvn
lks dcvn's Avatar
Also curious to see how this turns out...
lks dcvn is offline   Reply With Quote
Old 02-28-2009, 11:05 PM   #5
Gray Ghost
Gray Ghost's Avatar
Count me in for the news when you get it. I know I want discs at some point.
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
Old 02-28-2009, 11:35 PM   #6
STOCKISH
STOCKISH's Avatar
Forgot to ask, how thick is the material you're using?
--Josh
Old 03-01-2009, 01:28 AM   #7
yellowGT
yellowGT's Avatar
im in
'84 swb chevy
'69 swb chevy
'68 swb chevy
'95 Impala ss-sold
'89 chevy crew cab dually 3+3
yellowGT is offline   Reply With Quote
Old 03-01-2009, 06:36 AM   #8
jbristo67
resident oilfield trash
jbristo67's Avatar
Does anyone have a parts list so I can figure out how much this would cost to do.
1967 SWB C10 396/400 factory air
factory tach (sadly had to send to a new home)
1986 Honda 70 Fourtrax
1991 Chevrolet K5 blazer 2wd
1982 Mastercraft Pro Star 190 Stars and Stripes
2002 Chevrolet Tahoe
2011 Nissan Armada
jbristo67 is offline   Reply With Quote
Old 03-01-2009, 10:54 AM   #9
STOCKISH
STOCKISH's Avatar
You will need calipers and rotors from a 94-96 Impala SS. Also the rear brake hoses for the same car. Then theres an adapter to adapt your trucks brake hard lines to the Impala brake hose. They are the same as the Caprice or Roadmaster rear discs. I made a template and drilled my rotors myself. They look great and have never had an issue with any of the ones I drilled myself. And lots cheaper than buying them drilled.
--Josh
Old 03-01-2009, 11:38 AM   #10
weav1
weav1's Avatar
72 super i am using the impala rotors also they fit right on i had to clean off the center of the axle real good but no drilling
Old 03-01-2009, 03:11 PM   #11
STOCKISH
STOCKISH's Avatar
Sorry I should have clarified. I meant cross drilled the rotors. The rotors fit on the axle flange perfectly, no modifications were needed. Didn't mean to confuse anyone.
--Josh
Old 03-01-2009, 03:39 PM   #12
weav1
weav1's Avatar
wow how long did that take i just bought the baer decela rotors
Old 03-01-2009, 04:35 PM   #13
jbristo67
jbristo67's Avatar
How much do you want for your brackets. Does 250 sound about right for the whole setup to you guys
2011 Nissan Armada
Old 03-01-2009, 04:39 PM   #14
STOCKISH
STOCKISH's Avatar
It took ~20 minutes per rotor. I did all 4 on my drill press. Thay turned out perfect. The rotors cost me $15 each and the calipers were$25 each. I have a wholesale account though so that helps. I have more time than money so I wind up making alot of my own suff rather than buying it.
--Josh
Old 03-01-2009, 06:33 PM   #15
chuckmc8
It's alsways something.....
chuckmc8's Avatar
subbin in
chuckmc8 is offline   Reply With Quote
Old 03-01-2009, 06:54 PM   #16
jbristo67
jbristo67's Avatar
Hook a brother up with that whole sale stuff
2011 Nissan Armada
Old 03-01-2009, 07:05 PM   #17
STOCKISH
STOCKISH's Avatar
By the time I shipped it to you it would cost the same as buying it @ your local auto parts store.
--Josh
Old 03-01-2009, 07:21 PM   #18
weav1
weav1's Avatar
im sure it will be less then 250 i havent got all the prices back yet the big down fall is most places want a core on the calipers and brackets napa the kit is $78 and the core is $82 wtf and i guess it depends on what rotors you want i might just sell the brackets and list the part #s for you guys for the rest of the pieces then you can get whatever you want
Old 03-01-2009, 07:38 PM   #19
jbristo67
jbristo67's Avatar
How hard are these axels to get out??? I have to take them out to put on that bracket right?? HOw much do you want for your brackets??
2011 Nissan Armada
Old 03-01-2009, 07:38 PM   #20
Gray Ghost
Gray Ghost's Avatar
If I were you that'd be what I did. You should be too busy to do much else once you get them ready to market...
Kelly
Old 03-01-2009, 07:56 PM   #21
weav1
weav1's Avatar
well you can get the axle out in about 5 min i just did it tonight to test fit the brackets you could cut the brackets to slide over the axle and cut off the old backing plates but its not really a big deal some brackets i have seen on here were cut out anyway i will be able to give you guys a price tomorrow night after i get my brackets and calipers i think i willl weld some nuts on on im going to make the hole in the center a little bigger mine wouldnt go on due to the powder coating on the rear end and i dont want to grind it off i dont think it needs to be tight there the four bolts will hold it where it needs to be im thinking around $40-$50 depending on how much i have to do after they are cut how does that sound
Old 03-01-2009, 08:09 PM   #22
weav1
weav1's Avatar
i am up for some trades also let me know what you got i need a good set of ram horn manifolds edelbrock intake 2401 for later model sm block with center bolt valve covers need chrome center bolt valve covers just let me know i basicly have a complete rolling chassy and a good cab everything else i need
Old 03-01-2009, 08:12 PM   #23
jbristo67
jbristo67's Avatar
I was thinking about cutting them any way. Glad to hear some one else say it first though lol
2011 Nissan Armada
Old 03-01-2009, 08:14 PM   #24
jbristo67
jbristo67's Avatar
Thats a good looking frame
2011 Nissan Armada
Old 03-01-2009, 10:02 PM   #25
STOCKISH
STOCKISH's Avatar
I would love to have a set of the brackets without a nut welded on the back. And you dont need to worry about opening the hole up further on mine either. I dont mind doing all that. I will gladly send you the money through PayPal as soon as you give me the word. Thanks again.
--Josh
