kyb shocks/ part numbers
Anyone using kyb gas a just shocks on a 4-6 or greater drop. I had them on another truck, and want to put them on again, but can't get kyb to help me out with length specs etc.. I guess they won't publish the info I need to look them up that way. So if any one has them and knows part numbers I would really appreciate it. Thanks Jared
Happy to be here
![]() Join Date: Mar 2000
Re: kyb shocks/ part numbers
Lets see if you get a better response in the Suspension forum.
Tot Roddin'
If someone has this information and posts it, are the shocks going to be different for a 67-72 setup vs. a 73-87?
If so... can someone also post up the parts numbers for the 67-72 KYB drop shocks. Thanks in advance! And, I hope that I didn't hijack your thread jared78; this is a question I've been meaning to ask but always seemed to forget. ![]()
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
no all the shocks are all the same. i prefer doetsch tech shocks for lowered trucks. although i have KYB's on my Caprice and i love them. KYB's just dont work well in the rear of trucks because trucks are so light. thats my 2 cents on shocks
Projects: 66 gmc, SWB ,BBW,76 disc brakes/PS and rearend, pancaked crossmember 2 1/2" drop spindles 1 cut coil, 6" drop coils 2 " blocks c-notch with a 350. |
Tot Roddin'
bump for KYB parts numbers...
This what ECE just sent me for my 2/4 drop on a 70. Hope it helps.
------------------------------------------------- Jim Garage fillers... 85 Chevy C10 Silverado LWB 07 Nissan Altima 2006 Mini Cooper S |
Tot Roddin'
Thanks Jim!
bump to make sure the numbers pictured above will work for jared78.
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) Last edited by 72BlckButy; 03-03-2009 at 09:45 PM. |
btw my actual drop is more like a 4.5/6 but they based the shocks on the springs which where 2/4
67-72 parts collector,…
![]() Join Date: Nov 2002
Are those ECE numbers or KYB numbers?
It looks like you can read a different number thru that sticker. (in the lower RH corner)
Good call lolife.
The 7510 number crosses to KYB #344055 The 7502 number crosess to KYB #344068
Tot Roddin'
Excellent, I was just about to come over here and post that the number didn't correspond.
According to Advance Auto Parts: KYB #344055 (rear) - $33.99 (ECE price $40.00) KYB #344068 (front) - not listed (ECE price $40.00)
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) Last edited by 72BlckButy; 03-03-2009 at 10:04 PM. |
Thanks for bringing that to my attention Blckbuty.
------------------------------------------------- Jim Garage fillers... 85 Chevy C10 Silverado LWB 07 Nissan Altima 2006 Mini Cooper S Last edited by jholley; 03-03-2009 at 10:09 PM. |
Tot Roddin'
![]() ![]() Besides usually when you order parts by calling ECE they will usually beat the price you thought they were going to charge. Stan, Mark, and the rest of the guys are great!
EDIT: I have a different number for a 6" rear drop shock for a 67-72 truck. (KYB#344067).
I'm looking for the front shock number for a 4" drop. (67-87) Anyone have this number?
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 03-04-2009 at 07:25 AM. |
#15 |
Tot Roddin'
Keith, depending on the drop will the shock be different? It seems like ECE only offers one set at least according to their site.
#16 |
lolife, is your front drop all spring or a combo of springs and spindles? My point is that the spindle drop doesn't count when computing what shock you need.
#17 |
I need a shock that will work with a 3" front spring. (I'm also running a 2.5" spindle for a total of 5.5" drop)
#18 |
are those the 67-72 part numbers or 73-87. If they are 67-72 are they for coil or leaf rearend? I know that if they are leaf spring numbers they'll work for mine too.
#19 |
jared78,... sorry your thread got hijacked.
The fronts will be the same 67-87. The rear shock numbers I posted are for 67-72 coil spring truck. I will edit my post. Maybe calling KYB would be the best bet.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 03-04-2009 at 07:26 AM. |
#20 |
Tot Roddin'
#21 |
Tot Roddin'
Here's what I determined for 1973-1987 and 1967-1972 Chevrolet C/10 pickups:
1973-1987: FRONT GR2 344068 Shock Absorber 2 RWD REAR GR2 344072 Shock Absorber 2 RWD FRONT GAS-A-JUST KG5409 Shock Absorber 2 RWD REAR GAS-A-JUST KG5415 Shock Absorber 2 RWD FRONT MONOMAX 565032 Shock Absorber 2 RWD REAR MONOMAX 565036 Shock Absorber 2 RWD 1967-1972: FRONT GR2 344068 Shock Absorber 2 w/ Coil Spring RWD FRONT GAS-A-JUST KG5409 Shock Absorber 2 w/ Coil Spring RWD REAR GAS-A-JUST KG5416 Shock Absorber 2 w/ Coil Spring RWD FRONT MONOMAX 565032 Shock Absorber 2 w/ Coil Spring RWD FRONT GR2 344068 Shock Absorber 2 w/ Leaf Spring RWD REAR GR2 344085 Shock Absorber 2 w/ Leaf Spring RWD FRONT GAS-A-JUST KG5409 Shock Absorber 2 w/ Leaf Spring RWD REAR GAS-A-JUST KG5419 Shock Absorber 2 w/ Leaf Spring RWD FRONT MONOMAX 565032 Shock Absorber 2 w/ Leaf Spring RWD REAR MONOMAX 565037 Shock Absorber 2 w/ Leaf Spring RWD For the '73-'87 trucks it mainly depends on the type of KYB shock you want to purchase. As for the '67-'72 trucks it depends on the type of KYB shock, but also the type of rear suspension. It looks like there isn't a difference on the height, or lack there of, of your suspension travel. Low and slow... ![]() KYB Shock Difference: KYB GR-2® / Excel-G® twin-tube shocks, struts, and cartridges Purpose: Restores a vehicle’s originally designed handling and control Calibrated to compensate for worn suspensions Components and valving are designed specifically for each application The best choice to restore OE performance and normal driving conditions Built with quality that matches or exceeds OE Coverage for domestic and import cars, trucks, vans, minivans, and SUVs KYB Gas-a-Just®monotube shock absorbers Purpose: Significantly increases vehicle stability, handling, and control over twin-tube designs. Gas-a-Just is the replacement for an OE monotube shock Ideal as an upgrade from an OE twin-tube The more responsive monotube design automatically adjusts to driving conditions Applications for cars, trucks, vans, and SUVs KYB MonoMax®heavy duty monotube shock absorbers Purpose: Maximum control for trucks and SUVs – stronger, more durable truck shock The right choice for hauling, towing, or plowing The best performer on harsh road conditions Perfect for diesel trucks Applications for light trucks, vans, and SUVs, including some lifted and lowered vehicles I hope this helps guys...
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) Last edited by 72BlckButy; 03-04-2009 at 09:02 AM. |
#22 |
Happy to be here
Nice research guys...
#23 |
I don't think the thread was hijacked, still some good info. I did call KYB to get some info on extended and collapsed lengths, but they said they wouldn't publish that info or give it out. So I got a lowered gr2 number that I can cross to a gas a just number. I just need a rear number for a 6" drop leaf spring truck. A 4" drop shock could work too, I'll just get lower mount relocators. Thanks again for the help guys.
#24 |
i just bought the KYB #344068 for the front from summit for like $57 shipped for both of them... i called ECE and they wouldnt give any info at all, they said KYB builds some custom shocks for them? the guy really sounded like he was full of b.s.,
1971 C-10 SWB - LS swap w/4L60e, 20x8.5front 20x12rear, 1968 C-10 SWB - 454 BB TH350 -Gone! |
#25 |
who did you get this number from? for teh 6" rear drop?
