03-11-2009, 02:46 PM | #1 |
Mirror battle....I'm losing...
I started out with the repop 71-72 style....they vibrate too much at speed. Then I swapped over to the repop arm and round mirror [stock for a 70]....they vibrated more. Now I have a set of repop F150 mirrors on there and they vibrate out of place as well.
Does anyone out there have a set of mirrors that will stay still and let me have a clear view at 70mph? I am beginning to doubt that it's possible, but I find myself curious of the low mount tripod design [about the only one I have not tried yet].
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. |
03-11-2009, 02:48 PM | #2 |
Re: Mirror battle....I'm losing...
PS...for those with tripods...if they stay still will you post pics and tell me where you got them?
03-11-2009, 02:54 PM | #3 |
03-11-2009, 03:02 PM | #4 |
Mirrors???? What are those for? My philosophy is as long as their behind me I dont have to worry about em!!
A computer once beat me at chess, but it was no match for me at kick boxing. Duct tape is like the force. It has a light side, a dark side, and it holds the world together. |
03-11-2009, 03:10 PM | #5 |
Maybe your tires are out of balance?
03-11-2009, 03:11 PM | #6 |
do you have any polyurathane body or running gear mounts? when i got rid of mine and went back to factory rubber i could then use mirrors
your problem is not mirrors you need to find and correct the source of your vibrations
03-11-2009, 03:17 PM | #7 |
The problem seems to be something other than the mirrors. |
03-11-2009, 04:00 PM | #8 |
I agree......I've owned 5 of these trucks, some factory mirrors and some repro. None had this problem.
PS Am I the only member that calls them "repro" parts. Who came up with "repop"? Last edited by truckintexas; 03-11-2009 at 04:01 PM. |
03-11-2009, 04:02 PM | #9 |
No...all four tires [new six months ago] are balanced and mounts are all stock style and in good shape. I keep everything greased regularly. The problem is cheap mirrors.
To their credit the 71-72 style mirrors vibrated the least, but they are too small for my taste. I love the F-150 mirror's size, but both are loose inside and won't stay in the same position I put them in. I tried to open them up to get to the actual mirror mount, but couldn't get in without breaking the back plate.I may try again since I am going to replace them. I figured if I could get inside, I could cure most of the problem.
03-11-2009, 04:22 PM | #10 |
Recovering 67-72 Addict
Don't try the aftermarket tripod mirrors. They vibrate like crazy too. Also, I have rubber body mounts and new balanced tires. The problem is cheap Chinese mirrors.
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt. "Friends call me cruzer cuz I like fast cars and fast women" |
03-11-2009, 04:44 PM | #11 |
I was afraid of that. I guess I need to look for originals.
03-11-2009, 04:50 PM | #12 |
Are they mounted directly to the door? Just an idea, maybe you need a rubber isolator gasket ( like cut from a bike intertube) between the door and mirror, and possibly a rubber fused washer on the inside of the door, like they use on the metal roofs on pole buildings.
03-11-2009, 04:52 PM | #13 |
BOHICA
I have repops of the 68 round style, and I have no problems. I looked and can't find a brand name on them, sorry.
Trying to save someone from their own stupidity is like teaching a pig to dance. It is a waste of your time, and it annoys the pig! |
03-11-2009, 05:13 PM | #14 |
I have the cheap repops which actually came w/ a rubber gasket that went between the mirror and plastic trim piece. They are a PIA to adjust because they are so tight but while going down the road they stay fairly still. I have all new suspension (shocks, springs, bushings) and new tires though which could be a contributing factor.
03-11-2009, 06:19 PM | #15 |
They are on the door....I did use the plastic shoes, but I never thought about the rubber skirted screws. The housing is fairly still though...it's the actual mirrors that move.
My stalked roundies were horrible about vibrating...got 'em from Classic Parts. I esed the backing plates, factory screws and the shoes....bad vibes.
03-11-2009, 06:41 PM | #16 |
I don't know of anyone that could have more vibs than I have with 35" Super Swampers at 75 mph and mine have no visable vibrations in them. I know they are not mounted in the correct location but they work best for me like this.
03-11-2009, 06:53 PM | #17 |
I have had them and never had much trouble with them. Might be U joints or a bent drive shaft.
72 chevy 3/4 ton 4X4 |
03-11-2009, 06:58 PM | #18 |
454 MAKES IT ROAR
If it's the glass that's giving you the problem then try applying a small bead of clear silicone mastic to the outer edge where the glass is held by the frame.
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger |
03-11-2009, 10:46 PM | #19 |
OK....more stuff about the truck. The driveshaft is balanced and the u-joints and the carrier bearing are new. The tranny is recently rebuilt and the suspension is all in good shape. I do run 31x10.50 tires but you just read about 35's and no vibes.
I am telling you that the mirrors I have had on this truck suck. There's really no other vibration that is occuring.
03-11-2009, 10:54 PM | #20 |
I have the same problem with my mirrors on my '70 - I have '68 brackets with the square mirrors, and they are horrible. I have a set of '70's I'm going to try, but I don't want to put 8,000 holes in put truck if I don't have to.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD Click here to support the board Philippians 4: 6-7 |
03-12-2009, 08:19 AM | #21 |
I am a Referee of life.
Is it the movement from the vibration that is causing problems or is it that when it vibrates(normal driving vibes) that the mirrors actually move out of adjustment?
I'm guessing the latter.I had the same problem with a couple ofmirrors over the years and solved(somewhat) the problem by removing the mirror(no cover on them) and pinging the ball and socket with a small punch.It tightened the swivel adjustment enough that they were better but still not great.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
03-12-2009, 08:27 AM | #22 |
MOVE OVER
good idea, I had some aftermarket tripod mounts, and on the highway then would just fold right in, pretty much worthless. I was considering using west coast style, but some of them did the same thing.. I guess I have a lead foot?
No matter where you are..... There you are... Buckaroo Banzi |
03-12-2009, 07:47 PM | #23 |
Could the blurred mirrors be caused by wind turbulance and not vibration from the truck? I had that problem on a, forgive me for saying this...... a Ford Ranger. I installed a bug shield up front and it caused wind buffing. Once I removed it, the blurred mirrors went away.
Can you show a photo of what kind of mirrors you are using?
'72 GMC custom camper 350/350 Last edited by spinning wheels; 03-12-2009 at 07:47 PM. |
03-12-2009, 07:50 PM | #24 |
I think this is the culprit.... aftermarket mirrors are not well made at all. I decided not to try the tripods....can't find any that don't look completely stupid.
I am going to use clear caulk on one and see if it makes any difference. Since caulk is removable I got nuthin' to lose.
03-12-2009, 07:53 PM | #25 |
Here's the current mirrors....love the shape and size and the look from the driver's seat...
