Old 03-16-2009, 09:23 PM   #1
tekno62
is 10 mpg normal?
my trucks is a stock 350 with a turbo 350 behind it. is 10 mpg normal? I was told and it looks like it that the motor is a chevy crate.
tekno62 is offline   Reply With Quote
Old 03-16-2009, 09:25 PM   #2
Sinister
Between Trucks...
Sinister's Avatar
Re: is 10 mpg normal?
Yes.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 03-16-2009, 09:25 PM   #3
jrdv
jrdv's Avatar
That is about average for all of mine. It does have the wind resistance of a brick!
jrdv is offline   Reply With Quote
Old 03-16-2009, 09:28 PM   #4
tekno62
LOL god I need a 700r in it
Old 03-16-2009, 09:33 PM   #5
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
wat would u get with 700r4
John
1999 Toyota Tacoma 4x4
Old 03-16-2009, 10:00 PM   #6
tekno62
the overdrive. may get 12 mpg then
Old 03-16-2009, 10:03 PM   #7
texanidiot25
Eat My Rust
texanidiot25's Avatar
Yeh, if you do any freeway driving, the 700R4 will do you good. But 10 mpg is about normal.
texanidiot25 is offline   Reply With Quote
Old 03-16-2009, 10:40 PM   #8
67_C-30
I have a radical idea!
67_C-30's Avatar
I don't know what your truck is (C-10 or C-20?) and I don't know your gear ratio, but all of the trucks I've had with 350's/TH350's and 3.08's got better than that. I get around 14 - 15 in my red '69 SWB 350/TH350 and just slightly less (oddly enough) in my blue '69 SWB 250/3OTT. I've has others that get 12 - 13, but I never had one that gets 10 unless it was 3.73 geared 1/2 ton or a 3/4 ton or bigger. I don't putt around like grandpa, but I don't drive like I did when I was younger either.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 03-16-2009, 10:48 PM   #9
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
My blazer gets about 10 and its like pushin a brick through water..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 03-16-2009, 10:51 PM   #10
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
10 - 12 is average. http://67-72chevytrucks.com/vboard/s...d.php?t=172346
Old 03-16-2009, 11:02 PM   #11
dwcsr
Hollister Road Co.
dwcsr's Avatar
I was getting 10 down hill. I put a Holley spread bore on it and jetted it back to 58's added an 1-5/8 phenolic spacer. R45ts plugs at .050 with one of those white's speed shop HEI's. I get 13 now. I have a 700r4 to put in and hoping for 16-17.
Old 03-17-2009, 05:30 AM   #12
kookykrispy
The Early Chevy Van Man
10 mpg is normal... just for comparison, my '99 silverado is not much better. its a 2500 4x4 extended long bed with the 6.0 and I get 12-13 on the highway
64 Chevy Van
65 GMC Handi-Van
99 2500 silverado 4x4 ext cab
kookykrispy is offline   Reply With Quote
Old 03-17-2009, 08:12 AM   #13
Gray Ghost
Gray Ghost's Avatar
I'll chime in with that being normal as well. I can't imagine getting more than 12 unless you drive like grandpa and never break 30mph. My best numbers with a new motor and good tuning is 11.
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
Old 03-17-2009, 08:22 AM   #14
nightmare
nightmare's Avatar
I normally get 11.75 to 12. that's with a stock 350/th400 and 3.08's posi. now if i run the a/c, i get around 10, but i'd rather go with the windows down. i'm changing to a 355 and 700r4 this weekend, so if i've done my calculations correctly, i'll be sitting at 16 or 17 mpg after the swap.
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is offline   Reply With Quote
Old 03-17-2009, 09:44 AM   #15
monte0185
monte0185's Avatar
I had a 4wd 79 blazer that my dad gave me that had a sb400 in it that was completely stock. I got 9mpg no matter if you were pulling a 16ft trailer with a 1972 chevy truck or just driving it down the road. After awhile the quadrajet started to leak and rather than buy a kit to rebuilt it i had a carter afb I threw on there cause it was laying around and it jumped up to about 15.5-16mpg. I loved that blazer. Had to much cancer to try and save though. Good ol nebraska truck.
A computer once beat me at chess, but it was no match for me at kick boxing.
Duct tape is like the force. It has a light side, a dark side, and it holds the world together.
monte0185 is offline   Reply With Quote
Old 03-17-2009, 10:39 AM   #16
samwise68
FarmBoy.
samwise68's Avatar
Maybe it's my little engine, or the gears or...something, but 10, in my opinion, is fairly low.
My truck, even as tired as it is, gets a solid 15, with jaunts up to 17-19 if the weather and gas is good, and I only drive highway with minimal hot rodding.
More info would help, but, like the other guys said, it's normal...just, not with my limited experience.
-Sam.
1969 GMC C1500. long fleet.
307. 3 on the tree. 3.07 gears.
Oliver green. Bent and bruised. Daily Driver.
Screw patina... it's a beater...Beaters are cool.
my build thread - Project Homebrew:
http://67-72chevytrucks.com/vboard/s...d.php?t=242993
samwise68 is offline   Reply With Quote
Old 03-17-2009, 10:42 AM   #17
Senator350
Senator350's Avatar
X2
I got up to 13 with a Edel carb #1404 on a 327/th350
The 1404 is sized for a 305 and rated for milage, not performance.
It's an easy swap for a long trip.
Newer big trucks aren't doing much better. My old boss' '02 2500 quad cab longbed SRW gets around 12 on the highway.
RN U OVR
Senator350 is offline   Reply With Quote
Old 03-17-2009, 10:59 AM   #18
americanmusc1e
americanmusc1e's Avatar
I have a Holley 600 vacuum secondary with the black secondary spring(keeps the secondarys closed 90 percent of the time) and the best i got was 12.5 Highway, but i stopped checking my mileage when gas prices went down
P.S. i got 9.8 with the A/C on
-- Josh
Instagram: @americanmusc1e
OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread
FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread
1999 4wd OBS Tahoe - daily.
DM me if you can't see photos i posted
americanmusc1e is offline   Reply With Quote
Old 03-17-2009, 01:35 PM   #19
El Jay
Gone to greener pastures
I have a 350 in my Chevy and a 402 in my GMC; both with 4.11 gears.
Both of them get around 10 MPG combination city/freeway driving, & about 13 MPG cruising the freeway & staying out of the secondaries.
Having the aerodynamics of a barn doesn't help a whole lot, to be sure.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 03-17-2009, 03:07 PM   #20
tekno62
there an easy way to find the gear ratio for my rearend?
Old 03-17-2009, 03:18 PM   #21
Woody
The quickest way to check your gear ratio is to jack up both rear tires, then turn the drive shaft and count the turns it takes to rotate the tires one full turn. make sure both tires are turning. So then 3 - 3/4 turns of hte drive shaft for 1 rotations of the the tires is a 3.73 gear. a little over 4 is probably a 4.11, a little over 3 is probably 3.08.
You also can look at the glove box sticker, it may have it listed if it is still there and the rearend hasn't been swapped out.
Oh! I have a 350 / 400t w/ 3.73 gear and it only got 12mpg. I installed a 305 (from a 86 chevy) with HEI and the best I could ever get was 13-13.5 on the highway running 65-70. Like everyone else it really does not matter if it was loaded or not....
Woody is offline   Reply With Quote
Old 03-17-2009, 03:21 PM   #22
tekno62
the spid just says positraction rr axle
Old 03-17-2009, 03:45 PM   #23
Longhorn Man
Assuming the info you provided is as it was built originally, (350/TH350) and nothing has been chainged, then it'll be a 3.07 gear out back. That was standard with that eng/trans combo.
Old 03-17-2009, 04:33 PM   #24
67ChevyRedneck
67ChevyRedneck's Avatar
I have a 350/700R/3.73 and I'm getting a consistent 12.5-ish mpg with all of the "city driving" I do. It see's OD only about 25% of the time. On the highway I can squeeze out 14.5-16mpg, completely dependent on speed. I try to have a light foot, but there may be a few spirited romps per tank
For comparison, my silverado with the 5.3/4l60E/3.73 gets 14/18 under the same conditions.
Here's the average economy I got over quite a few tanks when I first installed the 700R. The 14.36 was a mix of lots of highway and some city, I rarely do highway trips, so I don't have those written down, but I do check them.
12.65
12.46
12.79
12.79
14.36
11.93
12.46
13.01
12.53
11.96
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 03-17-2009, 06:01 PM   #25
tekno62
No idea really - I'll jack up the truck toniht and do the wheel spin.
I got this truck to do some camping in so any pointer on upping the mileage would be great.
