02-12-2010, 02:13 PM | #1 |
Re: 1970 cst lwb project "Cheap Build"
Jeff, you sure do seem to get a fair amount done on that truck! keep it up.
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
02-12-2010, 07:34 PM | #2 | |
Redefining LowBudget
Jeff Your submission could not be processed because a security token was missing. If this occurred unexpectedly, please inform the administrator and describe the action you performed before you received this error. Last edited by Hottrucks; 02-12-2010 at 08:34 PM. |
02-14-2010, 08:42 PM | #3 |
I can't post pics here but heres my console build I couldn't post them there?? WTF??
http://67-72chevytrucks.com/vboard/s...51#post3800951 Last edited by Hottrucks; 02-14-2010 at 08:42 PM. |
02-22-2010, 10:36 AM | #4 |
CA CHING!! my low buget build just scored again!!! yep a 94 vortec 350 out of a boat 260 prop hp ...the block is cracked but the heads/intake and rest of it are all good...I'm going to throw a tire in the back of my other truck and go get in before the price changes Oh did I mention the price $$$...FREE...$$$
02-12-2010, 10:11 PM | #5 |
VA72C10
nice progress.
Looking for a 67-72 swb or blazer project in or around VA. |
02-14-2010, 12:32 PM | #6 |
By the sounds of it you've been busy too....I got called back into work this week so it will be slow going..I need to upolster the console and get it all wired I'm going to put 2 switches ( front up/down and a rear up/down) for the air and move my old 4 swtich panel and main switch to a new glove box ( thats another project) then wire up the seats I'm going to hold off a bit on the head liner and door panels..lmoa..(thats what I say now!!) but they will go pretty quick compaired to the console..by the end of the week my rear end parts will be here and the new bed need to come in to get the wheel wells removed (for the tubs) and get a coat of rustoilum on the bottom before I place it on the truck
looks like no pics I can't post them....
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. Mikes Sandwich Fair Run OCT 8th 2011
02-18-2010, 10:40 PM | #7 |
HickTown
lookin good... i'm diggin the red primer
1993 Ford Mustang Vert w/ 2.3 1969 Chevy C/10 w/350 1968 Chevy C-20 w/250 1976 Dodge Aspen W/ 225 2000 Toyota Tundra w/4.7 1987 Dodge Ram D-100 w/360 255/70-15 ___________ (oo)══╬══(oo) ‾‾‾‾‾‾‾‾‾‾‾ |
02-19-2010, 08:25 AM | #8 |
Thanx
I should finish up the inside today or tomorrow and get the door hung back on it .. I have pics and will try to post them soon....Then the fun begins new rear end on a set of Cup car trailing arms and the new wheels...which I hope will be around today so I can get them cleaned and painted Last edited by Hottrucks; 02-21-2010 at 08:21 PM. |
02-21-2010, 07:54 PM | #9 |
ok update time ( and I'll try for pics) the door is on the inside is complete it looks goo still need to do the headliner and door panels and it looks like I'm going to have some time to finish them up...
I parted my spare frame and removed the bed, rear axle,shocks that where all new..brought that in pull the cover to reviel a set of 3:73's...that makes me SO HAPPY.. it also had all new brakes and spring kits in it 1mocked up the new trailing arms had to remove the wedge spacers and the spring perch ..I built a couple 1" axle block so the bags will be in the working area a little more at ride height...the pumpkin now sits tight to the x member and is above the frame rails about 1 1/2" so it will be tight to the bed.. I'm going to finish up my inside stuff since I'm at a stand still until my rims come in this week..I dont want to set up the panard bar until I can check wheel/rim clearance...also the bar will be reversed compaired to stock since the new trailing arms have a mount on them already so I'm going to build a new hanger outside the frame ( another reason to wait till I have the wheels to measure off) this will make the panard bar almost 4 feet long so side travle will be at a min...
03-26-2010, 06:40 PM | #10 |
VA72C10
cool! I'll be following along with your progress...
03-26-2010, 11:04 PM | #11 |
03-28-2010, 09:20 PM | #12 |
you better get busy..well I should incase you sell that frame........
today I picked up the pan & pick up tube I need hopefuly this week I'll pick up the frame mounts, I need paint them and the pan..... I also got all the new belts Just not sure if I'm ready for the install ...the trans has been painted I need to pull the pan put a fresh filter in it and a couple of seals.....doing my home work and trying to save some cash for the exhaust and driveshaft so when I do it I can get it back on the road ASAP since its spring time theres lots of dump runs and bark mulch that needs hauling.... I need to hit a coulpe race car buddies for some exhaust header tape I want to wrap the exhaust back past the trans to keep things Kool under there since I want the new exhaust to be above the frame ( not sure how thats going to work with the auto trans linkage??) to keep from dragging it with the new 2" drop spindles..OH did I forget to mention those?? stay tuned I should have a pic of it al bolted together and ready to rock by the weekend |
03-28-2010, 09:23 PM | #13 |
heres the pan as I got it today
03-28-2010, 10:06 PM | #14 |
VA72C10
cool...looking forward to the updated pictures. Got my lwb all together today other than hanging the doors so it is a roller minus an engine....
03-29-2010, 12:29 PM | #15 |
Dpoesn't sound good LHM says that pan won't cut it in our style trucks..so cash flow will be te issue....by the looks of things I'll have $150 in a pan...$50 in trans seals and a filter..$200/$250 for a driveshaft and yoke...and $200 for exhaust work so it looks like Im going to fall about $600 short for awhile.......
I'm not going to take out the running 283/350 out till I can make the full swap.....I drive this almost everyday ..well unless it raining because it need a windshiled gasket $50.... DaM!! |
04-05-2010, 11:41 PM | #16 |
Did you get the widened rallies you were talking about any idea on costs to have a set widened
70 SWB STEPSIDE 70 BLAZER 09 challenger |
04-06-2010, 06:59 AM | #17 |
yep cost me under $200 for the pair on the truck with paint and the shipping was the killer the most you can go using the stock rally is to add 4" off back spacing
Sherwood Racing Wheels Prod 1074 Sulpher Springs rd Owego NY 13827 607 687 2991 |
04-06-2010, 07:04 AM | #18 |
I cut 11/2" off the stock wheel well and moved it over 1 hole ( about 4 1/2")and put a filler in it.. they look good IMO this weekend I plan to paint the tailgate and get another can of satin black and roll it out inside the bed..Ok I'll have the GF's Kid do it he loves helping me out so I try to plan projects for him...its cheap and really cleans up the inside...Now thtat the wheel wells are done I can go get bark mulch for the yard and test out my new Ag tires on the lawn and get the yard cleaned up..
04-06-2010, 07:06 AM | #19 |
on another note my oil pump is in I ned to get it painted and put on....still trying to save some $$ for the BS stuff when I do the swap..I think I need to put a windshield gasket in it first since if I get cought in the rain its going to leak all over my new carpet and insulation..NOT GOOD...
04-14-2010, 02:57 PM | #20 |
Im loving the new stance with the rear meats. Looks nasty. Then with that BBCaddy,
69 c-10 BBC 462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build. |
04-20-2010, 06:47 AM | #21 |
Eat My Rust
Oh, that is lovely.. |
04-20-2010, 05:18 PM | #22 |
Thanx I have since painted the tailgate and since I'm in Fla till tomorrow I'm kinda stuck but the roads are so nice down here its killing me.....I would love to have my truck here and show some of these bling bling trucks with 20 plus's some old school lessons!! wsith the left front about 6" in the air and the rear bumper dragging....Kids
SIZE MATTERS!!!!!!!!! |
04-20-2010, 05:20 PM | #23 |
04-23-2010, 11:50 PM | #24 |
side pice please
04-24-2010, 09:32 AM | #25 |
ok here goes.... sorry about the rubber on the rear fender guess I should have cleaned that off before the pic
