Eating Starter Solenoids
I've just burnt out my third starter solenoid in less than 3000 miles of short drives. I'm wondering if this is heat related as the truck starts instantly on the first turn of the key in the mornings, but starts to 'click' after that. Yes, I can jump it with a screw driver and start the engine that way. When taken apart, the disc is burnt all around. The truck has a stock 350 with factory exhaust manifolds. No heat shield, but is it necessary? Thoughts on why this is happening?
1972 Cheyenne Super 10 LWB 1965 Nova SS Evening Orchid 1967 Nova Wagon Factory Disc (1 of 565), 327/PG 1964 Ford Fairlane 500 HT 1962 Nash Metropolitan Convertible (Wife's car) |
It's a catastrophic success.
![]() Join Date: Jan 2003
Re: Eating Starter Solenoids
Your windings may be shorting causing a higher amp draw on the sol. Try replacing the whole assy. Might check to see that the bat cables are good and have a good connection and that the engine is grounded, any of these can cause high amp draw and shorten the life of starter and sol.
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
The fact that you can jump the starter tells me your problem is heat soak.
It means you are losing voltage at the solenoid when the engine warms up. There are some options you can do to fix it. 1.A heat shield may do it and you can keep your starter. 2. A heat shield and a remote Ford type solenoid most likely will fix it. 3. A high torque mini-starter. IF you choose option two there are some threads here in the forums that explain the installation if you're not familiar with it.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
Thanks guys.
Haven't been driving the truck much due to having to use a screw driver every time I want to start it. I continue to eat solenoids (the discs get all welded up). On my fourth solenoid in about 5K miles.
What I've done. New battery, new batt cables, new starter, added heat shield and new solenoids. About all that is left is the purple wire from the firewall fuse block to the solenoid. I'm ready to order a new ignition wiring harness. How can I test the purple wire to see if it is still good or not? I should add that I am trying to keep it stock, thus have not gone the Ford solenoid or mini starter route.
1972 Cheyenne Super 10 LWB 1965 Nova SS Evening Orchid 1967 Nova Wagon Factory Disc (1 of 565), 327/PG 1964 Ford Fairlane 500 HT 1962 Nash Metropolitan Convertible (Wife's car) Last edited by 67L30WGN; 05-17-2011 at 02:12 AM. Reason: Clarification |
i'd clean your grounds especially the starter to block contact area and the motor to frame and both ends of each battery cable
its all about the +6 inches
Bad grounds wouldn't do this.
Where are you getting these starters? Are they the bottom of the line craptastic chainstore ones? |
The purple wire isnt supplying enough amperage to hold the solenoid closed hence the clicking. Easiest solution f$%d solenoid. Correct solution new wiring.
The TEAL GMC build thread is HERE 1972 GMC SWB 454 oval ports TH400 fastest 1/4 mile time so far 13.05 @ 104 If you think you have too much horsepower you obviously have a traction problem ! |
bad incoplete grounds can and will cause wires and solenoids to overheat nomatter what some may say
About option 3, A high torque mini-starter, there was a thread awhile back that listed the GM part number but now I can't find it. Does anyone remember?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
Member
Put a high-torgue on my truck and it's working great, much easier to install due to weight and seems to run a lot cooler since it's smaller, less steel and father away from the hot stuff stuff. It cost $145.00 , i bought it from my local starter shop so it came with real actual warrenty.
#12 | |
I think it can't hurt for me to check my grounds. Anyone know how to check that purple wire? Could the heat from the exhaust and/or regular use caused it to build up resistance over the years?
Grandpa in the rustmobile...
Mine eats them about 1 per year. Im on my 3rd one. (carquest).
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
Wires dont hardly build up resistance except at the connections. Check at the back of the ignition switch. They are known to get hot & burn the connectors, especialy the red main hotb wire. I would put the Ford type selinoid on it. You can put it down on the frame where it is not noticeable. I have solved many problems with that. It takes the load off the purple wire & the ign & neutral switch. I usually put one on every thing I restore just for reliability.
#15 | |
I used to install Ford solenoids inside my demolition derby cars on the tranny hump so I could start the cars with a screw driver on the fly. They never let me down.
#16 |
I think I may have figured out the problem with my wiring issue. I just received a new wiring harness and before tearing out the old, I compared each wire run. Based on what I'm seeing, it looks to me as though a previous owner at one time must have installed an HEI distributor, because the resistance wire had been clipped out just as it entered the wire gutter, and removed. No longer needed, they also took the yellow wire that normally runs from the (+) side of the coil to the (R) side of the starter solenoid and removed it from the solenoid end and shortened it, leaving a pigtail at the coil. They then connected the yellow pigtail at the coil with red, non-resistance wire to the clipped end of the original resistance wire back near the block.
As purchased by me the truck has the original points-type distributor in place and as I just discovered, I have no wire running between the (+) of the coil and the (R) side of the solenoid and I have no resistor wire. Interesting! ![]()
1972 Cheyenne Super 10 LWB 1965 Nova SS Evening Orchid 1967 Nova Wagon Factory Disc (1 of 565), 327/PG 1964 Ford Fairlane 500 HT 1962 Nash Metropolitan Convertible (Wife's car) Last edited by 67L30WGN; 05-23-2011 at 09:19 PM. Reason: clarification |
#17 |
Reason for solenoid failure: With a points type distributor and the resistor wire replaced by a non-resistor type, a greater proportion of electricity must have bled off to the coil when it should have been going to the solenoid. Because of this, the solenoid would not make a strong connection (pull the disk into place) in order for the battery to send voltage to the starter. The solenoid disk probably barely made contact, causing it to arc. The arcing over time would destroy the disk inside the solenoid. Sound about right?
#18 |
![]() Join Date: Feb 2009
Here is a trick I picked up from old mechanic-has solved this issue on my older GM starters....
Remove the selinoid from starter and clip 1 to 1.5 wraps off the return spring. Careful clipping this off, wear eye protection! reassemble. This reduces the spring force that must be overcome by the primary selinoid. Just make sure you have enough spring left to return the starter gear back to non-engaged position. I have had three trucks with this problem, it has fixed all three. This assumes wiring and ground are all OK... |
#19 |
That's a great idea, and simple, too. K.I.S.S. I'll try it if I continue to have problems after returning the wiring to stock.
#20 |
your wire issue would have no effect on the starter. The starter feeds the coil in the crank position via that yellow wire, not the coil feeding the starter.
The resistance wire drops the power, 8 or so volts if memory serves. This makes the points last longer. When you turn the key to start, the power goes from the ignition switch to the starter through the purple on the S terminal on the starter. This activates the starter, but also, when the starter is activated, the R terminal gets full 12 volts, and sends it up to the points. What this does is gives the coil more power for more spark for a quicker start. |
#21 |
That's true, if you have the yellow wire and if you also have the resistor wire to control the flow to the coil. I have neither. I've got a points-type distributor with HEI wiring.
If juice could only get to my coil when cranking via the purple wire, it would reach a dead end. Some juice has to be finding its way to the coil in order to start via the only route available and that is through that non-resistor wire the PO installed where the resistor wire once lay. Right?
1972 Cheyenne Super 10 LWB 1965 Nova SS Evening Orchid 1967 Nova Wagon Factory Disc (1 of 565), 327/PG 1964 Ford Fairlane 500 HT 1962 Nash Metropolitan Convertible (Wife's car) Last edited by 67L30WGN; 05-24-2011 at 12:50 AM. |
#22 |
If you havent done it already, I would suggest you run a dedicated ground wire to the starter, this fixed my hot start problem. This is easy and it cant hurt, remember K.I.S.S.
#23 |
Did you ground to the block or the frame? I'm assuming the starter makes good contact with the block already.
#24 | |
#25 | |
Either we're saying the same thing in different terms, or I'm being dense. If you are trying to tell me that it doesn't matter what wiring I have - HEI or points type - with a points type distributor, then something else is causing all these solenoids to arc, and short of adding extra ground straps and reducing the spring height as suggested above, I can't imagine what it would be.
