Old 10-05-2009, 03:35 PM   #1
daverod
SSN 706
daverod's Avatar
Re: Daverods project 66
Originally Posted by joe231 View Post
Hard to tell by the pics, but it looks like the rear diff is shifted to the passenger side
It is.
daverod is offline   Reply With Quote
Old 10-05-2009, 03:37 PM   #2
daverod
SSN 706
daverod's Avatar
I welded the tabs on by measureing from the diff housing and the flange ends where it hooks to the wheel. It's got to be normal. I hope? I just don't know for sure? It's a 73 rear end. The axle is sitting straight. I measured from holes in the frame and from the stuff I bolted on.
Old 10-05-2009, 03:46 PM   #3
daverod
SSN 706
daverod's Avatar
Most times when you do an engine swap, the engine will be offset to the passenger side by some amount. . . the amount depending on the size of the replacement engine. Most people don't realize that many factory engines are also offset. Another thing people don't realize is that the pinion center line in hardly ever on the center line of the frame. They, also are offset to the passenger side. It doesn't matter that the two U-joints are not on the same centerline from the front of the frame to the back (my engine is set right 2" and the pinion is 1-1/2" right.) It only matters that their individual centerlines are parallel.. Answered my own question I think. Just freaked me out for a few.
Old 10-05-2009, 04:37 PM   #4
MacAttack
283 Drama Queen
MacAttack's Avatar
Exactly. Didn't somebody post an example of the geometry recently?
For about 12 years of my adult life I had a severe speech impediment.
My ex-wife never let me get a word in edgewise.
MacAttack is offline   Reply With Quote
Old 10-05-2009, 04:47 PM   #5
joe231
joe231's Avatar
It is.
I'm not referring to the center section, but the whole diff. Did you measure from the backing plates to the frame on each side?
and I totally agree with the factory off-set thing,
guess I'm not sure what exactly you are asking.
the off set would also aid in the u-joints being properly lubricated through-out suspension travel.
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 10-05-2009, 04:50 PM   #6
MacAttack
283 Drama Queen
MacAttack's Avatar
http://jniolon.clubfte.com/driveline...nephasing.html
Mac.
Old 10-05-2009, 08:57 PM   #7
Strodder
Daring to be Different
Strodder's Avatar
Originally Posted by MacAttack View Post
Good find Mac.
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
Old 10-05-2009, 05:00 PM   #8
daverod
SSN 706
daverod's Avatar
The diff. is centered. I guess I was just suprised the drive line does'nt come out of the center of the diff. It comes out off to one side. I just thought it would be centered. Now I know better.
Old 10-05-2009, 03:31 PM   #9
watahyahknow
watahyahknow's Avatar
de diffhousing usually isnt simmetric cause the stuff inside is too the side too
did you measure from the centre of the diff or from the ends of the axle
they might've done it to give more room to the driverseat wish isnt as strainge as it sounds
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 10-05-2009, 04:57 PM   #10
joe231
joe231's Avatar
Ok, now I see that you were quoting......geez talk about hard to follow
CHEVY ONLY
Old 10-05-2009, 04:59 PM   #11
MacAttack
283 Drama Queen
MacAttack's Avatar
Joe and his picture fixation.
Old 10-05-2009, 05:04 PM   #12
daverod
SSN 706
daverod's Avatar
Oh ya I forgot these" " I could'nt get the picture to copy. Sorry for being a plagiarist
Old 10-05-2009, 05:04 PM   #13
joe231
joe231's Avatar
cool, guess i was having a blond moment
CHEVY ONLY
Old 10-05-2009, 05:10 PM   #14
MacAttack
283 Drama Queen
MacAttack's Avatar
Mac.
Old 10-07-2009, 04:59 AM   #15
watahyahknow
another thing about having one rebuild is that you can have them make it a little stronger
i agree with tiggamonster that you dont know wat a tranny from a junkyard been trough it might just be that the rebuild one on an exchange basis aspecially a 3 speed wont differ so mush with a yard one
Old 10-07-2009, 11:04 AM   #16
MacAttack
283 Drama Queen
MacAttack's Avatar
Yeah - bite the bullet and rebuilt the tranny with heavier stuff inside - then you can tromp on it without worrying.
On Ron's description - I kind of get it.
3 degrees maximum drive-line angle, I'm assuming - in any plane.
Tail shaft of transmission to pinion of rear end. Piece of string from centerline of each component - from one to the other: Maximum angle can't exceed 3 degrees.
These components must point directly (parallel) down the centerline of the vehicle however even if they're offset - if they don't, that will create a situation that increases possible vibration.
Mac.
Old 10-07-2009, 11:26 AM   #17
padresag
sorry, the driveshaft can run at a greater angle. the 0-3 degree variance is the alignment between the centreline of the engine and pinion or in other words the variance of the parallel lines
eg. look at the difference in d/shaft angle between a 4 x 4 and a 2 wheel dr. quite a difference. the alignment of the eng and pinion between both remain the same
ron
padresag is offline   Reply With Quote
Old 10-07-2009, 11:31 AM   #18
MacAttack
283 Drama Queen
MacAttack's Avatar
Ah, now I get it - in the vertical more than 3 degrees is okay.
Old 10-07-2009, 12:26 PM   #19
padresag
yes and it can be offset to the side at the same time, as in the pinion being offset to one side. the ujoints should be sync also with one another for it to work properly.
the same if you have bag suspension and you can raise and lower the car at a whim. the d/shaft compensates through the ujoints
simple things can be quite complex at times even if the same theory has been used now for over 100 years
ron
Old 10-10-2009, 12:25 AM   #20
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
If you cant get it to clear the mount, take the mount out.
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 10-10-2009, 12:27 AM   #21
daverod
SSN 706
daverod's Avatar
I guess its not the mount it the cross member and its studded in not bolted. That would be to easy.
Old 10-10-2009, 09:44 AM   #22
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
take out the crossmember i think thats what ruffrida was saying
just get an air chisel and pop the rivets off then replace them with grade 8 bolts
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline   Reply With Quote
Old 10-10-2009, 01:38 PM   #23
watahyahknow
eeehmm maibe loosen the cab and raise it of the mounts a little
Old 10-10-2009, 02:03 PM   #24
daverod
SSN 706
daverod's Avatar
I was thinking that too.We'll see I think I just have to turn it just right.
Old 10-10-2009, 03:18 PM   #25
ruffrida2005
Dave while you have a chance now I would take it out like Gage said and put grade 8 bolts back in it. I would do that to every crossmember. Makes it a lot easier to work on when you need to. Just make sure you use loctite and lock washers.
Paul
