my short bus
90 burb (( daily dragger))
so I sold the 87 dually and bought a 90 2wd
started off like a grampa cruiser ![]() removed a few things and dropped it a little ![]() before the drop with acessories ![]() after the drop removed most acessories
**90 burb**bagged,shaved**(about done)********* **91 burb**stock worker for now**************** *********only squares for me****************** |
my short bus
Re: 90 burb (( daily dragger))
swapped on
chrome front bumper with no rubber strips clear tails with led bulbs removed body molding, rear bumper,bug shield,vent shades truck rallies things to do : weld in rollpan clean body of trim adhesive remove all drip rail molding cut down front cups add bags in rear
what did you use to drop it? What size of tires are on it right now?
looking forward to seeing your roll-pan pics, I was sent a truck roll pan and had to make it work....its interesting! |
my short bus
front is a SD brackets w/airlift 2600 bags
3" bell tech spindles trimmed rain gutters on lca's has truck rallies on it now rear is just a 6" flip with no overload spring has about 1.5" to frame roll pan I got from sir micheal's with no tag box tires in above pics are 31x10.50x15 still had inner fender in sat on them will up date with new pic's with 235/75-15 and no inner fenders on monday
my short bus
![]() from today after a bath ![]() compared to my wifes stock explorer fun I think
Low & Fast!
Looks good man, I love the long and low look..
like a rock
![]() Join Date: Nov 2004
Looks real good sitting low. Rally's look good aswell!
Garage wrench
looks killer, very very cool. How is the ride? Do you bottom out in the rear a lot?
-Adam 90 V1500 GMC Suburban 350/700R4/NP241..... 01 Saturn SL1 stock DD..... |
huh ???
Here's a pic I took of his burb at our cruise in this past Saturday...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
my short bus
little ruff rides about 1.5" from frame
no shock or bump stops rite now ( I know) going to do a small notch this week and looking to weld dropped pockets in lca's unsure of rallies they need paint red,black or silver what do you guys think I was thinking red with some black scallops till I paint in the fall
#11 | |
Low & Fast!
nice bro! killer ride!
Fuzzy Dice Club Member 87 Crew SWB Build for the crew http://67-72chevytrucks.com/vboard/s...d.php?t=430082 http://www.cardomain.com/ride/3232925 90 burb 2wd Build Thread For The Burb! http://67-72chevytrucks.com/vboard/s...d.php?t=383055 |
nice ride. I definatly want a burban one of these days.
clean burbbun look's good on rally's.
#15 |
I have painted rally's on my Blazer. I took the rings off as there is just too much covered to make it worthwhile painting them. Especially wiht the wide 3" rings
A while back my GF's dad built her an '81 swb and put painted steeliles with the little smoothies or moon caps or whatever you call the little center hub caps. He had some real small trim rings that couldn't have been more than 1" wide. If I could find some of those that would mount to the rally's I would do that.
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) |
#16 |
Tot Roddin'
Long, low and slow.... looks good!
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
#17 |
my short bus
update friday I'm ordering some sd axle mounts the under and behind ones but I'm going to run them facing forward and use the frame as my top mount welded on axle about where the shock mount is now then going to weld in a 4" pipe as a notch so I can add my bump stops and not lose any drop
![]() drop is about done for now next step is some body work and shaving
#18 |
Low & Fast!
Sound cool, get us some pics..
#19 |
my short bus
bought another set of rally's with new tires
adding air shock for now may be a week or 2 for progress (honey do list is calling)have to paint a few rooms and fix up the yard
#20 |
Cool Burban!
82 Chevy SWB "OrangeAnimal" Lot of Goodies! Sold 93 GMC 1500 "Angry Red" 383 TBI Powered Fun! 300hp/410ft.lbs. 09 Yaris wife's daily. |
#21 |
cool bro keep us posted!
#22 |
my short bus
So I'm going to give in and buy a 10" notch for rear
going to make it all work with only raising the floor about 4"s should give me about 5-6" of drop suspension wise I going to keep the 2 longest springs and add a block if needed will be able to keep 3rd row seat on bridge cover and not lose any foot room seat will be raised about 2"s at most notch and bridge will be the only parts above the stock floor just for clearance issues
#23 |
my short bus
![]() 8" i.d. pipe 2.5" tall 1/4 " bottom plate starting on my dropped lca cups on sat
#24 |
6.0 powered square
cool burb
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
#25 |
Low & Fast!
Sweet man, post some more pics when you start
