60-66 Nut
Impala SS Rear Disc Brake Brackets
Here is my latest design of the Impala SS rear disc brake brackets. These are laser cut out of 1/4" with 1/4" spacers stitch welded on and then tapped M12 x 1.25 for the caliper cage attachment bolts. These brackets will bolt onto the truck 12 bolt rear differentials from '64-'82 and the 10 bolt truck differentials from '79-'87. The price on these is $115.00 plus a flat rate shipping of $9.20. This pricing is always current and up to date. PayPal is preferred, but I will also accept money orders. The package includes one pair of brackets plus grade 8 fasteners to attach the brackets to the axle tube flange and the metric bolts to attach the caliper cages to the brackets. This setup is for the 5 x 5 bolt pattern.
If you would like a set, post in this thread, send me a PM or send an email to captainfab454@hotmail.com, and I will give you the ordering and payment instructions and current lead time.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 10-08-2021 at 09:42 PM. Reason: Shipping cost increase |
Re: Impala SS Rear Disc Brake Brackets
Another nice product
![]() What did the impalas use for e-brakes? will the impala rotor fit the axle with out any modification?
60-66 Nut
The Impala e-brake was a shoe setup inside the rotor which would be a little difficult to adapt to a 12 bolt truck diff. The Impala rotor fits over the axle flange with nothing more than slightly opening up the center hole to slide over the step on the axle flange. A die grinder and a flap drum will do it is 5 minutes or less.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 04-16-2009 at 12:48 AM. |
![]() Join Date: Dec 2006
I'll take a set. Paypal on the way.
![]() Join Date: Nov 2007
Do you use the truck rotor or impala rotor?
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
Uses Impala SS or Caprice/Roadmaster rear rotors.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
60-66 Nut
I haven't received it yet.....as soon as I do I will send a set out to you. Thanks
Thanks for replying Josh. I see you got yours today, have you put them on yet? I'm not aware of any 5 X 5 truck rotors that would work on the rear.
They're on there buddy. Fit and quality is perfect. Couldn't ask for a better product or better service. Thank you.
#9 | |
60-66 Nut
Thanks for the compliment Josh.....and for the purchase too ![]()
If you have spares put me down for a set. Do you have the part numbers for the brake set-up?
'84 swb chevy '69 swb chevy '68 swb chevy '95 Impala ss-sold '89 chevy crew cab dually 3+3 |
hey cap... do you also make them for the ten bolt rearends?
payment sent. Cant wait to see how this app. fits and look on my truck. My brother might want a set too so Ill let you know.
60-66 Nut
What year of 10 bolt? Are you referring to a 8.5 truck 10 bolt? If so I'm pretty sure the ddistance from the axle tube flange to the axle flange is the same as a 12 bolt. So they should work but I would need to verify that, unless someone here can.
I'm working on putting together a list of parts and part numbers. You basically need rotors, calipers, factory caliper brackets, pads, and hoses for a '95 Impala SS. You will also need a brake line adapter to go from metric to SAE.
What do you recommend for the prop valve when adding the Impala rear discs?
#15 | |
60-66 Nut
With that said,as for the Impala rear brake conversion, I think I might recommend seriously looking at the components that GM used on the Impala for a start. Although the weight bias of a pickup is likely to be a bit different than an Impala. Also the weight bias from one pickup to another will be different in how the truck was built. This is mainly why I believe an adjustable proportion valve is beneficial to the brake system. BTW Scot, how did that booster bracket work out for you?
#16 |
It looks great . . ... sitting on a shelf full of parts (Vette MC, Malibu booster, Porterbuilt Dropmember, 350/700R4, van tilt, blah, blah. blah.... Also should have a couple of steelies on the way
![]() The parts are waiting to come together but I've gotten behind on building the frame for my retroRod project so everything else is delayed as well. Should make for a busy summer. There will be a thread w/details soon.
#17 |
Hello Captinfab,
what did the impala use for an e-brake? is everyone using a rear disc with out an e-brake? chas
"I'll Procrastinate Tomorrow" quote by LEEVON 71 K10 long fleet (sons truck) new 370hp 355, sm465 np205, 3.73's 33's 70 K20 long fleet 98 G3500 work van |
#18 |
60-66 Nut
The Impala SS used a shoe setup inside the rotor for an e-brake. So using These brackets on your truck won't give you an e-brake. If you need to have an e-brake, you'll have to buy the Camaro caliper brackets that glock35ipsc is making. Thanks for inquiring.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 05-03-2009 at 11:04 PM. |
#19 |
![]() Join Date: Apr 2009
What front set up matches the ss caliper?
#20 | |
60-66 Nut
[quote=Dahawk;3299044]
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 05-07-2009 at 11:41 PM. |
#21 |
60-66 Nut
I have one set of these brackets left......I'll throw in a pair of Metric to SAE line adapters for free with this last set.
#22 |
Hay Team!!
![]() Join Date: Jun 2003
Capt....please check your PM's as I am interested.
I'm also curious to know what the diameter of the impala rotor is? Can you get me a measurement from the center of the axle to the highest point on the caliper? My wheel has a 7 inch backspacing so fitment is going to be close depending on the dimensions. Thanks in advance
1972 Chevrolet Cheyenne LWB "Orange and White" 8) |
#23 |
#24 | ||
60-66 Nut
#25 |
hey captinfab
just so you know i would like to buy two sets thats not a problem. let me know either way |
