09-13-2013, 09:45 AM | #1 | |
Re: 69 GMC "Ol' Blue"
The company is called "Blueprint Engines" which is where I was looking at picking up a fully dressed 383 for $3,600 shipped. That seemed like a really good deal at the time, but I'm just not willing to roll the dice on whether they built mine correctly. They use all remanufactured parts to keep the costs down, which would be fine if it were a local shop that I could just tow it to and tell them it broke. I'm now on the path of determining what I'm going to build. I'm back to finishing my 400, or build a 383. The only real advantage I have with the 400 is that the block has already been bored 30 over and I have the pistons and rods. I'm still unsure about the crank, as the journals have surface rust that I'm not sure can be polished out. I still plan on calling my local shop to get their opinion, but I've been spending weeks researching so that I know what questions I should ask. |
09-13-2013, 07:33 PM | #2 |
I couldn't find the spindle prevailing loc nuts, 3/8 NF, 6 per side.... But that's ok because i found them at my local hardware store for $0.40 each today.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
09-13-2013, 08:36 PM | #3 |
Awesome! I'm glad you found what you needed.
09-15-2013, 07:07 PM | #4 |
Got a little done today. Engine and Tranny are back in. Engine will need to come out again, but the trans is good to go.
09-15-2013, 10:29 PM | #5 |
Cool!
BTW: You didn't say what brand the splitter is in your prior post, i'd like to look it up. http://67-72chevytrucks.com/vboard/s...&postcount=243
09-15-2013, 10:33 PM | #6 | |
Posted via Mobile Device |
09-15-2013, 10:44 PM | #7 |
Well, I decided to mount the transfer case...when I was tightening up around the input shaft...crack went the rear bearing plate. Not cool! Apparently with the new input shaft bearing, I should have double checked that.
09-15-2013, 11:50 PM | #8 |
Man Mike, that is not cool at all. Things just go wrong sometimes don't they.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
09-15-2013, 11:19 PM | #9 | |
If i remember correct it went like this: start in 1 low clutch and shift browning to high, clutch and downshift the browning back to low then up shift to 2nd and let out clutch, clutch up shift the browning to high, clutch and downshift the browning to low and up shift to 3rd..ect.. .
09-15-2013, 11:22 PM | #10 |
That's what this one is going to be lol! It ought to be fun to drive :-)
09-16-2013, 12:02 AM | #11 |
Just curious, when you posted that it moved the tranny back 7" did you check clearance of your shift lever at the bench seat before you took the cab and seat off? it was my first thought so figured i'd throw it your way. There is always a torch to bend the lever if need be.
09-16-2013, 10:19 PM | #12 | ||
09-16-2013, 10:39 PM | #13 |
Like a custom frame notch in the seat? Yea moving the engine forward helps, i didn't realize you did that.
09-16-2013, 10:42 PM | #14 |
Ha...I don't quite know what the solution is going to be yet. I'm hoping that's something I get to worry about in the spring (I hope I get that much done this winter)
09-17-2013, 12:01 AM | #15 |
Might just have to stare at it and think for a while, I solve a lot of my problems in my sleep, funny but works for me.
09-17-2013, 08:11 AM | #16 |
But for some odd reason, sitting and staring at it while drinking beer doesn't seem to spur any actual good ideas, at least for me To bad on that t-case, but hopefully not too tough to find a replacement part.
Rick 78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel 71 GMC C25 350/TH400 - Project Angie 59 Chevy SWB Stepside (next in line? Not sure now ) 2001 GMC Sierra K2500 |
09-17-2013, 12:02 PM | #17 | |
09-22-2013, 06:19 PM | #18 |
Didn't do a ton this weekend. Got the tie rod hooked back up, and started the rebuild of my steering gear. I'm going to file that one under too stupid to be scared
Well, if it doesn't work, at least it will be pretty |
09-22-2013, 06:24 PM | #19 |
Lol!
09-22-2013, 10:02 PM | #20 |
I'm impressed that you got it apart I haven't even tried yet - too scared I guess!
09-22-2013, 11:54 PM | #21 |
I rebuilt a steering box once a few years back, a lot more to it than a person would first think. Nice job.
09-23-2013, 10:16 AM | #22 |
Well, tearing apart is one thing...putting it back together and having it work will be a true accomplishment
09-23-2013, 10:17 AM | #23 |
Yeah, there are definitely some tricks one should be aware of Thanks!
10-06-2013, 01:57 PM | #24 |
I made some very minor progress this weekend. I got my steering gear reassembled, but I rushed the paint prep, so most of the paint flaked off. What's that saying about if you don't have time to do it right the first time...
I also mounted my 4wd lever so I could see how it fits. I'm definitely going to need to find a way to move it forward. I can't wait to drive this beast! |
10-06-2013, 06:22 PM | #25 |
Ok, recovered from my paint issues on the steering gear and got it mounted up. One more piece done, 352 million left
