Crossbred, 454 into an '85 Ram
Well, now that i fell comfortable here, i'll dispaly my project. Why am i doing this---well, because i can, it'll pI$$ some people off, and i have always wanted to tinker with other "cheaper" engines. So with that, the victim became our '85 Ram. Out came the second 360 that had let me down and a new beginning was had.
The goal for this build, brutal low and midrange torque, stay somewhat in a budget, and drive the wheels off the thing anywhere at anytime, and on 89 or cheaper octane. Here is the truck as pictured last year, i dont plan to change anything here. ![]() Back last Nov '08, i approched my machinest about building a Chevy motor for my truck. We decided at that time to do a 383 because of the price and big block stuff around here isnt cheap--usually. So with that, in went a 305 while i gathered parts. It fit like a glove after i made mounts and it all bolted in---even the headers went in from the top. Mounts and isolators---all bolt in stuff, even used existing holes in the truck. ![]() 305 mocked up in truck, the fit is great! ![]() Well, as most of my projects go, they snowball. I picked up a set of reconditioned peanut port big block heads for $40 when a guy switched to Edelbrocks. And then i thought and sought about looking for a motor to put them on. So fast foward to a couple weaks ago, i find a whole 454 from a early 70's truck, realativly cheap. ![]() After some research, i find out it will simply bolt in place of the small block, same mounts, same isolators, no moving anything---how easy could this be---i wondered. After the engine was disassembled (another long story initself being it was locked up), everything was taken to work and degreased with out huge steam pressure washer, and other smaller parts were dunked for a day in our huge cleaning tank. Then, it was time to see if it fit. Putting an engine in---even an empty block and heads like i did, is an act in fustration if your doing it by yourself like i did. But i managed to get it done. It fits, i slid the stock exhaust manifolds on and its tighter, but still good. Things i took note of, headers are going to be tight, the fan is going to have to be changed to a regular fan with a short spacer, or change everything to a short waterpump setup. It all just barely fits with a long pump but i do have some interference on the fan blade tips and radiator bottom tank. I want tall valve covers, but i am going to have to notch the drivers side for brake booster clearance also. ![]() So this is where i am at now, im a little out of money at the moment, if i can unload the 383 stuff, i can continue on a bit. I also at this point failed to mention, that the trans is a New Process 833 overdrive--3 speed with fourth being overdrive--found mostly in chrysler products, but some GM trucks from the early 80's have them too which is where mine came from. It has ratios very close to a 700r4, which are not really ideal, but a big block should have plenty of torque to pull through the wide spreads. I have a TH350 i could rebuild if i need too and also have the trans mount setup to run a regular style non overdrive 833 four speed--which is a chrysler trans, and i have an adapter plate to use on the GM bellhousing. So i have plenty of choices in the transmission department.
. 454/4 speed, '85 Dodge Ram hybrid build in progress 454, PP heads, Dual 500 CFM cabs, 'Vette manifolds. First time out---spinning for half track ![]() Slooowww build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=348050 Engine build thread at: http://www.chevelles.com/forums/showthread.php?t=326289 Last edited by 383Ram; 06-11-2009 at 06:10 PM. |
![]() ![]() Join Date: Jul 2002
Re: Crossbred, 454 into an '85 Ram
Interesting Build. Can't wait to see how this turns out.
blood type; Retumbo
any chance you can throw in some Ford stuff?
if you decide to go with the TH350 I may be interested in the NP a833. it would be perfect behind my 472 caddy. |
#4 | |
As far as the trans, the TH350 is a back up, i dont plan on selling the 833, its nice having it all just bolt together. A 472 Caddy? Any pics? That sounds cool. I thought about that swap too, but things like that are even harder to find around here than a BB Chevy for decent prices.
. 454/4 speed, '85 Dodge Ram hybrid build in progress 454, PP heads, Dual 500 CFM cabs, 'Vette manifolds. First time out---spinning for half track ![]() Slooowww build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=348050 Engine build thread at: http://www.chevelles.com/forums/showthread.php?t=326289 |
blood type; Retumbo
there's a few guys here with big caddy's in their trucks. LonghornMan is the most known and he has a web page on how to do it. I got my 68 472 for free and if I hadn't bought the boat I would have got another from a salvage yard for $150. some guys say they can get up to 22 MPG with the swap.
I am putting one in my 67 stepper project and may even put one in my work truck. I would like to go overdrive but my 700R4 is a little questionable as to it's ability to handle over 5oo ftlbs of torque. besides I do my builds the same way guys did back in the 50's, mix and match with used parts from whatever I can find while fabricating it all together. you should look at my 68 work truck. it's chock full of different stuff. |
Where can i view your truck at?
Up to 22MPG!? is this just due to the massive torque? This is the premiss of my build, big torque, whatever HP it makes secondary, and hope for some decent milage with the OD trans. If i could get it to do 13-15 around town and 18-19 or so on the highway, i would smile from ear to ear. I had concerns that the big engine was going to suck gas big time---to the point i was thinking i may forget the 496 crank and just keep it a 454. Now i am on the fence again. Decisions, decisions---appearently you can get mileage out of a big motor according to what your saying. So from what little searches i did so far, it seems these guys are running stock intakes also. At first i was dead set on a performer RPM, but the more i have put thought into the entire combo, i think a regular performer would suit me better as its suited for idle to 5000 where the rpm is 1500 to 6000. I dont plan to turn this thing much past 5000 at all. I want all the torque i can possibly make down low. Most driving is done idle to 3500.
. 454/4 speed, '85 Dodge Ram hybrid build in progress 454, PP heads, Dual 500 CFM cabs, 'Vette manifolds. First time out---spinning for half track ![]() Slooowww build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=348050 Engine build thread at: http://www.chevelles.com/forums/showthread.php?t=326289 Last edited by 383Ram; 06-14-2009 at 01:30 PM. |
Sunburst C10!!!
subscribed this is an awesome build
Gage 1967 C10 Shortbed Stepside |
cool build, will the weight of the 454 require new front springs?
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
Thanks guys.
No new front springs needed here, Dodge didnt seem to get into all that stuff like GM did. My current springs were torched to lower it about 2" sometime in its life, i have some 2" drop spindles and i need to get new springs to make it right. Be patient, unfortunatly this is going to be a slow post due to finances and the crappy economy, which makes me afraid to spend anything---not to mention i never know whats going to happen at work, but i should be alright there. I have some tall valve covers coming--i fully expect to have to notch the drivers side for booster clearance. I also have to see if the headers i have are going to fit too. I just need to finish up some side work, and clean the garage to get the truck back inside.
I am not a fan of chrome--well i am if used sparingly in the right application. Do you know how hard it is to find things like budget priced valve covers that are not chrome for a chevy? Well, you could buy aluminum stuff i guess, but its usually got a hefty price tag.
And lets face it, Tall valve covers go a long way on the visual impact of making an engine look bigger---and to me, anything but a tall valve cover on a BB chevy (unless its a resto) just doesn't look right. And i like the look of how big this engine looks stuffed in the engine bay. So, with those thoughts i searched my parts friend, Ebay. I found these particular ones, stamped steel and painted (will strip later), and new too---$29 shipped to my door. I like the look of them, with the slightly raised area like a small block has (this is a good area for logos and such) I assumed right off the bat before i even got them that the drivers side was going to interfere with the brake booster---well, i was wrong---sort of. While i had no trouble getting them on over the stock rockers that are still on the mock up heads, and just missing the brake booster, there is going to be an issue when the gaskets go in--i only have about a 1/4" gap. So you have to figure, with a head gasket on and valve cover gasket on, its going to be real tight or just flat out hit. So, the solution is going to be either notch the valve cover (initially when i bought them that was my first thought), go to manual brakes, or see if i can find a smaller booster---which is a available, but a little harder to find. Thinking about this more, if i can find a smaller booster, i think this is how i will go---although the manual brakes would be just as easy. More to come........ ![]() ![]() ![]()
. 454/4 speed, '85 Dodge Ram hybrid build in progress 454, PP heads, Dual 500 CFM cabs, 'Vette manifolds. First time out---spinning for half track ![]() Slooowww build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=348050 Engine build thread at: http://www.chevelles.com/forums/showthread.php?t=326289 Last edited by 383Ram; 06-27-2009 at 07:09 AM. |
Sunburst C10!!!
what are your plans for the engine performance wise
Same as before with the small block--lots and gobs of torque. Small docile cam, performer intake, my freshened peanutport heads i pickup cheap. It'll be around 9 to 1 on the compression ratio, so it will be able to drive anywhere, any time. Just a good solid dependable motor--with a ton of torque.
Now---if i win the lottery, a 496 kit will be in order. But right now i just would like to drive it again---something that probably wont happen for awhile. I am trying to base it off these guys with the Caddy swaps, But with more readily available chevy parts. Caddy parts availability and price aren't the greatest around here, and parts are more available at local stores for the chevy. I just want to be able to go anywhere and not be stuck or stranded while having to wait for that odd Caddy part to come in---i guess i am just paranoid a little, LOL.
. 454/4 speed, '85 Dodge Ram hybrid build in progress 454, PP heads, Dual 500 CFM cabs, 'Vette manifolds. First time out---spinning for half track ![]() Slooowww build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=348050 Engine build thread at: http://www.chevelles.com/forums/showthread.php?t=326289 Last edited by 383Ram; 06-27-2009 at 02:26 PM. |
Sunburst C10!!!
i dont think you can find much caddy parts anywhere without them being ordered
So i picked up these headers at a swapmeet a month or so back. $50, brand new, but no gaskets or hardware---pretty good deal i thought. I cant find any info on them, just you basic 1 3/4" big block street header. They look just like or similar too truck headers so i bought them--The guy seemed to think they were fo a Chevelle, maybe an early one from what i can tell, but im still thinking they are truck headers.
Today i got a chance to get the drivers side to fit. Pretty easy to do, just had to slightly notch the top of the rail about 3/4" to get it in. They basically went right in after that, no dinging tubes or whatnot--, just bolt 'em up. The holes seem a little to tight from the front of the head to the rear, so i will have to drill them to the next size when i remove them. Now, on to the pass side....... ![]() ![]()
. 454/4 speed, '85 Dodge Ram hybrid build in progress 454, PP heads, Dual 500 CFM cabs, 'Vette manifolds. First time out---spinning for half track ![]() Slooowww build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=348050 Engine build thread at: http://www.chevelles.com/forums/showthread.php?t=326289 Last edited by 383Ram; 07-03-2009 at 04:12 PM. |
#15 |
great southern land
looks like a sweet build, i like them old dodge trucks.
rod ![]() 86 chevy c10 silverado |
#16 |
Last night i picked up a used Edelbrock performer intake for my 454 from a local Craigslist ad. It was already beadblasted and someone did put heli-coils in the wider Holley flange---which is fine with me as they are stronger---and it looks like they actually put them in right too. Soooo for less than half of a new one, i picked it up--$75
I decided to sneak out to the garage before work and slap it on to the mock up motor, i noted that compared to the stock truck intake, it sits about 2 1/4" taller. I also noted as i had heard on the net the ports are closer to the peanut ports rather than the large ovals. I dont know for sure yet if they are indeed the same as the peanuts, but they are certianly closer to that side of things---just in case anyone was wondering. So here are a few pics, hopefully next up is the install of the right side header, i just havent had time since my last posting to do so. ![]() ![]()
#17 |
Sunburst C10!!!
looks good are you going to paint it chrysler orange
thats what color mine is i thin k it looks better than chevrolet orange
#18 | |
So i am desperatly looking for ideas. I never painted using body colored paints, and the best i could do there is out of a spray can---because i thought about doing green like the truck. Black would be a choice too---orange is still a thought--but again a lighter high maintence color and doesnt really go. So what would you guys do and what items would you paint what colors? (i.e. would you paint the intake natural aluminum or engine color? valve covers? etc...)
. 454/4 speed, '85 Dodge Ram hybrid build in progress 454, PP heads, Dual 500 CFM cabs, 'Vette manifolds. First time out---spinning for half track ![]() Slooowww build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=348050 Engine build thread at: http://www.chevelles.com/forums/showthread.php?t=326289 Last edited by 383Ram; 08-04-2009 at 09:48 PM. |
#19 |
Sunburst C10!!!
i would say black and green
you can use body color paint spray it just like you would a car primer base and clear just make sure its clean and wipe it down with prep all
#20 |
blood type; Retumbo
I kinda like the simple easy stealthy semi-gloss black.
#21 |
I think gloss black with body color valve covers, and cast aluminum painted intake (so it keeps that fresh out of the box intake look) is what i am going to do. But one issue i have to solve is the clearence between the drivers cover and brake booster.
Also, untill i can sell my 383 stroker parts, i am basically on hold as far as buying some more parts. I still have plenty to do in the mean time, but as far as it running anytime soon, its just not going to happen.
. 454/4 speed, '85 Dodge Ram hybrid build in progress 454, PP heads, Dual 500 CFM cabs, 'Vette manifolds. First time out---spinning for half track ![]() Slooowww build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=348050 Engine build thread at: http://www.chevelles.com/forums/showthread.php?t=326289 Last edited by 383Ram; 08-08-2009 at 01:39 PM. |
#22 |
Well, it took me a bit to get to this, but the right header is now installed. It was not anywhere near as easy as the left side. After starting with some similar cuts on the top of the frame rail as i had done to the left side, and it still did not drop in--Uh-Oh.
Well, i spent the better part of an hour messing with it only to discover the only way it was going to fit was to cut the top of the rail to half its width. My feeling is that even without any reinforcement it would be fine, but once i pull the mock up engine out, i will box the frame in anyhow. It still needs to be trimmed up nicer, but its in, now onto whatever part needs to be done next.... ![]() ![]() ![]()
#23 |
Sunburst C10!!!
have you ever put headers on a 98-02 chevrolet f-body (camaro-transam)
i did it for the first time yesterday and it sucked
#24 |
Phone's ringin Dude.
![]() Join Date: Mar 2007
Sweet looking build. I like them ol Dodges
![]() ![]() 2003 SILVERADO SS--THE NEW GIRL 1972 GMC--THE OLD GIRL |
#25 |
So while i tried to over complicate the GM alternator to the Dodge truck wiring, i thought...... why do i need to used the GM alternator, i can just use the Dodge one.
With that came the mounting. I hate the ugly look of an alternator sticking high in the air--as it does on most GM stuff. So i decided to lower it some. First step, see what worked as to where i could mount it. I found a lower bolt boss in the head to be suitable for the lower mount. Problem was it was a 7/16" hole and the alternator had a 3/8" hole inside the steel bushing pressed into the alternator. I didnt want to chance drilling the bushing as i feared it would get to thin. So i took a 7/16" bolt, and a long 3/8 bolt and welded the heads together carefully. Problem solved. Now for the top mount. I found an old adjuster bracket in the garage. Bolted that to the alternator and looked to see what was closest around i could bolt to. I found another 7/16" boss on the intake side of the front of the head. So i used some threaded 7/16"rod as a stud, a piece of 1/2" steel pipe, and found some copper tubing to slide inside to bush the inside to the right size of 7/16" I trimed the adjuster bracket to size, and tacked it to the tubing, then removed and fully welded and ground smooth--and added the lightening holes, just because i can. All thats left to do is add a front support onto the stud, this will go from a boss on the waterpump to the stud itself, its just a piece of steel flatstock with two holes in it, i made one already but its a bit off on my hole spacing so i have to make another. Enjoy the pics. ![]() ![]() ![]()
