03-22-2010, 11:22 AM | #1 |
Re: 52 GMC Envoy Burb meld/build
Are you thinking rear truck fenders would be too wide ?
"just curious" Something in between sounds right have never really seen truck fenders on a panel or burb. (except for a wild custom) Low and wide sounds pretty cool !
"I feel the need for speed!"... as soon as I am done with my nap. |
03-22-2010, 11:24 AM | #2 |
Junior Member
Rear pickup fenders would be too wide. They are 6-9 inches wider. I am only going to widen them 1-2, depending upon what I do to the front.
48 GMC Panel Sold 12-14-15 52 White/Chevrolet School Bus 52 GMC Burb/Envoy Meld 61 Impala Wagon SOLD BARRETT JACKSON SCOTTSDALE 1-18-13 67 c/10 SOLD 2012 71 SS454 77 c/20 Sold 11-11-15 08 TBSS The Wife's car!! 50 GMC School Bus SOLD 11-7-10 29 F**D Delivery (Chevy powered) SOLD 11-4-11 53 GMC 630 Firetruck/Ramp Truck |
03-22-2010, 01:15 PM | #3 |
Don't the big truck (front) fenders also have a larger wheel opening? That might be your solution for the front right there. Also for the rear, if you're widening and welding the rear fenders to the body pickup fenders may be the best way to go there too, just trim to fit where you want it.
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
03-24-2010, 09:58 AM | #4 |
COOL! me liking it, looks good, but why not leave it as an open wheel racer!!!!!! Now that would be cool. just kidding.
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
03-24-2010, 11:40 AM | #5 |
VA72C10
cool project!
Looking for a 67-72 swb or blazer project in or around VA. |
03-24-2010, 11:58 AM | #6 |
AD Addict
What are you doing with the grille in the end? Widening it or shrinking the opening. I have a 2 ton front end sitting on my 1 ton panel right now to keep things dry. Looks right other than the wheel opening. I'd leave it but the truck will be for my son and he doesn't like it!!
03-24-2010, 12:28 PM | #7 | |
Junior Member
Will add the same two inches to the inside edge of the fender. I want to use most of the stock grill. Gotta keep some plans a secret for a while though !! (Suffice to say there will continue to be some 'melding' of the Envoy)
48 GMC Panel Sold 12-14-15 52 White/Chevrolet School Bus 52 GMC Burb/Envoy Meld 61 Impala Wagon SOLD BARRETT JACKSON SCOTTSDALE 1-18-13 67 c/10 SOLD 2012 71 SS454 77 c/20 Sold 11-11-15 08 TBSS The Wife's car!! 50 GMC School Bus SOLD 11-7-10 29 F**D Delivery (Chevy powered) SOLD 11-4-11 53 GMC 630 Firetruck/Ramp Truck Last edited by BBEEP; 03-24-2010 at 12:29 PM. |
03-24-2010, 02:33 PM | #8 |
AD Addict
Goody goody gumdrops, I like surprizes!!
03-24-2010, 02:47 PM | #9 |
Junior Member
My grandma used to say that!
03-24-2010, 03:11 PM | #10 |
Thanks 'til you're better paid
Suspense is killing me...
-Luke 1950 Chevy AD 3100 pickup 2000 GMC Sierra 1970 Jeepster Commando |
03-24-2010, 07:36 PM | #11 |
Just remember, on this build there is no such thing as too many pictures.
03-25-2010, 08:31 AM | #12 |
BBEEP... I first saw info about this build on TRAILVOY.COM. I believe you posted under "1952 ENVOY". I know members there would love to see some pics of the progress. Keep up the great work.
03-25-2010, 04:25 PM | #13 |
Junior Member
O.K., so I tried widening the fenders 2 inches on by 52 Envoy/Burb and it didn't do the job. The tires still rub front and rear. I know I could radius those fenders, but I would like to try some 1-ton front fenders. Does anyone have a pair of GMC or Chevy truck fenders out there?
Also, does anyone know what the difference is between the Chevy and GMC fenders? My truck is a GMC and I will keep it that way regardless of what I find, just curious.
03-25-2010, 04:38 PM | #14 |
From what I've read, the difference between chevy and GMC fenders involves the running light, and some of the inner fender holes being different. That's nothing for you.
Also, although you'll hear conflicting reports on this, but I believe what you're looking for are 1.5 ton and up fenders, as my 1949 3800 1 ton (single wheel, had 9' stepside bed) has the exact same wheel openings as a 1/2 ton. Post up pictures of the clearances with the widened fenders, so we can help you brainstorm.
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler Last edited by BlueJeep; 03-25-2010 at 04:39 PM. |
03-30-2010, 02:33 PM | #15 |
Junior Member
Test fitting the passenger fender after widening 2 inches. I can turn the front of the 28 inch tall tire out, and it hits the top of the tread about 75% out. Turning it in, the back of the tire hits almost immediately. If I put a shorter tire on it, that will help some, but then it is really low. (still completely stock AWD chassis & suspension) I'm going to get some measurements off of my 50 School Bus to see if the 1 1/2 ton fenders will work better. Any other ideas?
Obviously I haven't straightened the frame yet. I want to get things mocked up, then send it out while I am dipping the parts that I will use.
03-30-2010, 04:12 PM | #16 |
Try a different backspacing on the rim? Not sure how much more you could move the wheel in without it looking goofy though.
07 Chevy classic LBZ Duramax (a few mods) '67 Chevy 1/2 ton 2wd (in pieces) '69 Chevy 1/2 ton 2wd (on hold) '71 GMC 3/4 ton 4x4 ‘71 GMC 1/2 ton 2wd suburban |
03-30-2010, 04:14 PM | #17 |
AD Addict
As a daily Trialblazer driver, 268k miles, while you have it down, get into the splined disconnect, clean it up good, and put improved grease in it! Lots of discussion on Trailvoy.com but I suspect you know this. Mine took a dump this winter and still waiting to get it fixed. Also, get a good look at your exhaust manifold. I've just had my second one go bad. Other than that...drive the double-toothpicks out of it!!
On the fenders...hmmmm...big bolt is one way to go but just not sure what else to do. |
03-30-2010, 04:46 PM | #18 |
It looks like you need one of about two things. Either you need the body to sit higher so that you can use your existing setup, or you need larger wheel openings in the front. I don't imagine different backspacing is an option, looking at the wheels that are on it now. Since it's AWD, narrowed control arms aren't an option. I think what I'd do is section the front fenders and use the existing wheel openings, just make them larger and higher.
I think you ultimately may need to take the same approach as these guys:
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler Last edited by BlueJeep; 03-30-2010 at 05:03 PM. |
03-30-2010, 08:30 PM | #19 |
AD Addict
Bluejeep has something there...the first COE looks like he's radiused the wheel wells AND flared them out. You might be getting some style points there!!
03-30-2010, 08:48 PM | #20 |
Junior Member
Yup Dan, very cool. The fender does go back into the doors, being a coe, but very nice. Would be cool if I could snub nose it, too.
I printed the pic, I'll take it to the shop tomorrow.
03-31-2010, 01:59 AM | #21 |
You probably already know this but with the envoy awd you need to keep all 4 tires close in size or the transfer case module gets confused. Seriously though, you got the body on that far. making the tires clear isnt that big of a deal compared to what you have accomplished so far. Keep it up.
Nick |
04-01-2010, 12:30 AM | #22 | |
Junior Member
04-01-2010, 07:31 AM | #23 |
GEARHEAD
I said it once before, but about a 2" body lift might help a lot.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff |
04-01-2010, 08:16 AM | #24 |
Also the base trailblazers and envoys came with 16 inch wheels so that may be an option also.
Nick |
04-01-2010, 08:25 AM | #25 | |
BBEEP... If your using an XL envoy you will have to stay with atleast the 17" wheels. The LWB Envoy(XL) and Trailblazer(EXT) must use the 17" because the front brakes are larger than the SWB versions. I didnt notice what model Envoy your using, if its the SWB you can use 16"+. |
Tags |
suburban |
