07-14-2009, 11:15 AM | #1 |
Between Trucks...
Gear Vendors Question
To those few guys who are running Gear Vendors overdives, how much rpm drop do you get in OD? I'm looking at some GV units on Fleabay and they're saying 400-500 rpm drop.
Beat it to fit, Paint it to match... |
07-14-2009, 11:59 AM | #2 |
Re: Gear Vendors Question
It is a .78 overdrive. So here's the formula:
RPM= MPH x Gear Ratio x 336, divided by tire diameter. So if you're running 31/32" tires and a 4.10 rear end, this is where you'd be at when doing 70 MPH: Top gear 1:1, non O/D: 3050 rpm Top gear 1:1, with O/D: 2350 rpm The other advantage that they seldome talk about is that you can split all the other gears, too. So on the highway, you could have 3 gears, instead of one like I do. You'd have 3rd O/D, 4th, 4th O/D. |
07-14-2009, 12:04 PM | #3 |
Between Trucks...
That's the kind of drop in rpm I need. I just don't know what the OD ratio is on the Fleabay ones. Listing says it's a P type of Gear Vendors.
07-14-2009, 12:14 PM | #4 |
In talking with Gear Vendors, they are all .78. I guess someone could probably find a way to mess with it and change the gearing, but I don't know why you'd want to.
A little history on my truck: I actually ordered a Gear Vendors and started installing it. That is when I realized I had an NP435 trans instead of an SM465. The adaptor didn't fit. GV had never heard of a GM version of the NP435 and could not provide me with an adaptor that would work. So here I sit, with the pistons swapping holes at 70 MPH, burning gas like there was no tomorrow. |
07-14-2009, 12:17 PM | #5 |
Between Trucks...
Some of the e-bay vendors say they have aftermarket adapters. Might want to ask if they have what you need.
Beat it to fit, Paint it to match... Last edited by Sinister; 07-14-2009 at 12:18 PM. |
07-14-2009, 03:16 PM | #6 |
Yeah, not a bad idea, but I've pretty much written it off at this point. Money's been spent on vacations and house projects.
08-17-2009, 01:32 PM | #7 |
So Longhorn,
Is your adapter being used as a door stop or did they take it back? If you're using the door stop option and decided to sell, what would you be asking for it? Thanks, daz
--------------------------------------------------------- I'm not crazy, I'm chosen, there's a difference. ---------------------------- '72 K10 SWB, 350, sm465/np205 ---- ---- |
08-17-2009, 02:00 PM | #8 |
newly minted old timer
im starting to REALLY think about one of these units.....wish i could find a deal on one. the 3k price tag is a bit much.
i think i would pull the trigger right now, if the unit would give me 1/2 gear UNDER first. it really isnt an underdrive imho.
____________________________________________ 72 c20 longhorn 65k org miles and counting! 69 k10 Suburban |
08-19-2009, 08:35 AM | #9 |
to the guys who have installed one of these, did you leave the drive line carrier or just make on long drive shaft? once the unit is on the front shaft will be only a foot or so long... why bother?
08-19-2009, 09:45 AM | #10 |
A .78 overdrive will make your RPMs .78 of what they were before regardless of tire size etc.
Unless I'm missing something. Hey Sinister,What rear gears/tires you running now?
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme. Last edited by WorkinLonghorn; 08-19-2009 at 09:51 AM. |
08-19-2009, 10:00 AM | #11 | |
I have a cousin with a 3/4 ton F**D with a 460, O/D tranny and a gear vendors. Tires are average, about 31/32". He's taching about 1800 RPM at 70 MPH, which is fine when empty. He runs one gear lower when he's towing his fifth wheel. He said the ability to split the gears is awesome when he starts up a hill... There's no point where he has to wrap it out or lug it. He can ALWAYS keep it in the torque band. Even though I never got mine installed, I would think anybody who can swing the price would not be disappoiinted in adding one of these to their truck. |
08-19-2009, 10:27 AM | #12 |
I used to drive a 16' flatbed from Hollywood to Fontana and it had a 4spd with a 2-spd rear and it was really nice splitting the gears going up that grade.
I imagine that GV would be just the ticket for towing. For regilar driving maybe a higher rear ratio would do.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme. |
08-19-2009, 11:07 AM | #13 |
I thought about buying a used one, but I've heard that GV is less than helpful if you didn't purchase from them directly.
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
08-19-2009, 11:45 AM | #14 |
Between Trucks...
4:10, 265/70R16. I'm right around 3000 rpm doing 65/70 mph.
08-19-2009, 12:25 PM | #15 |
DO IT, man, do it!!! Let us know how it goes. The install actually looks to be really straightforward. I'm about half stupid and I am pretty sure I would have had it running in a couple days.
BTW, for you LA boys, I'll probably be at the Early Rodders meet in Montrose this Saturday morning. Hope to see some trucks there! |
08-19-2009, 12:37 PM | #16 |
Sounds like you need to lose that 4.10 and get a 3.07. Or a 3.54. I've got 3.73 with 31" tires and still turn 3000 at 72MPH.
How much is a used GV? I wonder if any ever slip by the guys at Pick-your part and make it into the yard.
08-19-2009, 01:08 PM | #17 |
Most likely Sinister has the same rear end that my truck had, which is an Eaton. You can't get anything higher (numerically lower) than 4.10's for it. Trust me; I'd have gone that route on mine if possible.
08-19-2009, 01:54 PM | #18 |
You guys are right there with those voices in my head... "go ahead do it.. it's already torn down... nows the time... think of the fuel savings... it's only numbers on a credit card!"
I do think I can justify it, after all it will be my dd. Currently I'm running 31's with a 3.07p rear, about 2600@70mph with a 350/sm465/np205. So, is it just a bolt on with the drive shaft needing to be shortened? What about the speedo gearing?
--------------------------------------------------------- I'm not crazy, I'm chosen, there's a difference. ---------------------------- '72 K10 SWB, 350, sm465/np205 ---- ---- Last edited by dazza; 08-19-2009 at 01:56 PM. |
08-19-2009, 01:55 PM | #19 |
Between Trucks...
69GMCLonghorn is right I have an Eaton. I've seen used Gear Vendors units on Fleabay for around $1600 with adapter and electronics. Rebuilt ones slightly more.
08-19-2009, 03:18 PM | #20 | ||||
That doesn't compute unless I svrewed up. In my notes I figured a 3.07 with 31" tires would be 2500= 75.1 MPH Quote:
08-19-2009, 05:45 PM | #21 | |
08-19-2009, 05:46 PM | #22 |
I can only relate my personal experience with Gear Vendors. I had one installed in my 82 Suburban, with a 6.2 diesel,w/ Gale Banks turbo. I bought the unit from a GV dealer, who installed it with a 2 piece driveshaft. Had vibration on takeoff, which they tried to remedy by shimming the rearend, to change driveshaft angle. After multiple attempts, they said I would have to get used to it. I drove directly to Gear Vendors (only 100 mi. from my house), and asked them to check it out. They said the installers should have gone with a one piece driveshaft, and if I wanted them to build one, I could pick the burb up the next day. I was pissed, because I had paid for two driveshafts on the initial installation, and now I have to pay for another? I just wanted it fixed, so I said go ahead. I pick up the truck the next day, vibration is gone-good, where`s my bill? NO CHARGE. I could not believe it. I fully expected to pay for another driveshaft, always assuming you don`t get something for nothing. After that, I always drove the 100 mi to Gear Vendors to get the OD unit serviced. After installing the OD, my mileage was 18-20mpg, in a 3/4 Suburban, with 4.10 gears. Sold the burb to a friend, who replaced the diesel with a 350, but kept the turbo 400 and OD- probably 80,000 mi on GV now, with no problems whatsoever.
08-19-2009, 05:53 PM | #23 | |
The oddest Todd around
It is one HELL of a long piece of metal, but it runs smooth.
"The greatest pleasure is to vanquish your enemies and chase them before you, to rob them of their wealth and see those dear to them bathed in tears, to ride their horses and clasp to your bosom their wives and daughters." Ghengis Khan IIOY??? |
08-19-2009, 09:51 PM | #24 |
i,d find me a sm465 if i was you. there cheap
I BELIEVE IN JOHN 3:16 |
08-19-2009, 09:58 PM | #25 |
its all about the +6 inches
dazza, your MPG will probably drop if you do it
