11-19-2013, 10:00 AM | #1 |
Re: 1969 Short Wide
Man that looks great! Soo cool how you can tint the stuff. Really like what you did on the lower bed sides too. Sharp!
'77 K30 3+3 - "The Crummy" http://67-72chevytrucks.com/vboard/s...d.php?t=640134 '67 C10 L/SWB - Soon to be daily driver! http://67-72chevytrucks.com/vboard/s...d.php?t=471776 |
11-19-2013, 10:01 AM | #2 | |
Re: 1969 Short Wide
Really diggin the raptor finish. I dont know anything about the raptor product. Ive seen it posted here and there, but since Im not to that point I havent researched it. How did you get the tint so close to the actual color of your paint?
71 swb 350/4sp manual 5/7 static drop |
11-19-2013, 11:07 AM | #3 |
Re: 1969 Short Wide
Looking awesome! I need to make sure I coat mine with some raptor also. Sometimes I get ahead of myself and skip steps.
Daniel 68 C10 Build http://67-72chevytrucks.com/vboard/s...d.php?t=503594 Romans 10:13 Everyone who calls on the name of the Lord will be saved. |
11-19-2013, 12:11 PM | #4 | ||
Still Learning
Re: 1969 Short Wide
Thanks Daniel. I'm trying to map this thing out so it all goes together smooth. At times I think I may over think things....that happens when you're going on the 4th winter working on one. |
11-19-2013, 01:00 PM | #5 |
Man of Mini-Talents
Re: 1969 Short Wide
Really smart idea coating the inside with Raptor. That and a garage will keep this puppy around for years to come.
Looking great, Mike.
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
11-19-2013, 01:32 PM | #6 |
Laid Back
Re: 1969 Short Wide
Looks great mike.. Top notch work!
72 chevy swb Direct dealers for.. Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body.. Kyle http://67-72chevytrucks.com/vboard/s...d.php?t=574629 |
11-19-2013, 05:05 PM | #7 |
6>8 Plugless........
Re: 1969 Short Wide
Mike, great work! That's what I want to do to my Longhorn's bed floor too. I probably won't go to the extent you did with the dent removal on the floor because I still want to try to use it like a truck. I know If I make it super nice, I'll never put anything in the bed.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
11-19-2013, 05:33 PM | #8 |
Re: 1969 Short Wide
Why cant you be my best buddy and neighbor.... and help me do that with my truck! That is sweet!
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
11-19-2013, 06:36 PM | #9 |
Re: 1969 Short Wide
I just found your thread. So far I've only gone back a few pages, but I've got a lot of reading to do... I'll be caught up in a few days
I like the tinted raptor liner. How hard is it to spray? What sort of air pressure are you using/need? What about the gun, did you use a special gun or just a large tip hvlp? I like what I'm seeing on the last few pages. Keep up the good work.
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
11-19-2013, 08:28 PM | #10 | ||||
Still Learning
Re: 1969 Short Wide
Thanks Kyle. You know how pictures can make everything look better. Quote:
On the Raptor liner, I bought my kits on eBay for around $120 shipped, You can buy it at TCP or Amazon or even your local Oreilly's can order it. Kit comes with the Shutz type spray gun and 4 liters of urethane. I have been spraying at around 60psi. I also reduce mine a little which seems to make lay a little less lumpy. LINK |
11-19-2013, 09:38 PM | #11 |
Junior Member
Re: 1969 Short Wide
Looking awesome! Are you going to weld the bedside to the floor at the tailgate end like the factory did?
11-19-2013, 09:51 PM | #12 |
Re: 1969 Short Wide
That Raptor looks great! Very uniform job Mike! For the Raptor tint, I've read some actually mix it up a little darker, since it shoots a little lighter. I still have some I never used after purchasing a while back, now, after seeing your work, I think I'm going to copy you and your bedside coating. Nice. Are you shooting the underside of the tubs with Raptor?
project: "my happy mess" Last edited by litew8; 11-19-2013 at 09:56 PM. |
11-19-2013, 10:30 PM | #13 | ||
Still Learning
Re: 1969 Short Wide
Yes, I will be sanding the paint off in the areas that are to be welded. Just like the factory did. I taped that area off to avoid the raptor there too. Once I get the bed assembled squared up and tailgate fitted, I will weld her up and repaint that area. Hope it goes as planned. Quote:
edit: BTW, In hindsight it would have been far easier to replace the front panel, cross braces and install a nice wood floor like you did. I don't know how much money I spent salvaging these rough metal panels? but I would have been done with the bed long time ago. These are the things we learn as we go. I'm pretty dang tight with the budget but as you can tell from the length of the build, I have plenty of time. Would I do it over? Probably
Mike "69 Short Wide" My Project 86 Silverado Landen's Project Instagram: @mcbassin My Website C/10 Club Oklahoma Facebook Group Last edited by mcbassin; 11-20-2013 at 09:46 AM. |
11-19-2013, 10:36 PM | #14 |
Still Learning
Re: 1969 Short Wide
I got the sand through fixed. Sanded the whole tub with 1000 then had to re-apply base coat in the bad spot. I let it set up over night then wet sanded that area to level it out. Next I re-shot two more coats of clear.
It looks orangy in the strange light but we all know it's RED
Mike "69 Short Wide" My Project 86 Silverado Landen's Project Instagram: @mcbassin My Website C/10 Club Oklahoma Facebook Group Last edited by mcbassin; 11-20-2013 at 09:41 AM. |
11-19-2013, 10:53 PM | #15 |
Re: 1969 Short Wide
Very cool
project: "my happy mess" |
11-19-2013, 11:18 PM | #16 |
Here kitty kitty kitty
Re: 1969 Short Wide
OK, fine....I thought I was doing good with getting the bed painted....but dang bro, this is bed is incredible!!! Great job Mike, keep it up man.
11-19-2013, 11:57 PM | #17 |
Re: 1969 Short Wide
Nice spray work!!! I'm jealous you have like no dirt or specs in there at all.
11-20-2013, 12:11 AM | #18 | ||
Still Learning
Re: 1969 Short Wide
I also think photobucket is killing the resolution on the pics when I upload them. |
11-20-2013, 12:09 AM | #19 |
Re: 1969 Short Wide
I'm envious! Any scuffin between the clear coats? Are you still going to cut and buff that?
11-20-2013, 02:54 AM | #20 |
Re: 1969 Short Wide
Hey Mike! I'm fixin' to get ready on choppin my bed sides and wondered if you could sneak me a couple photos of them square holes along the bottom (spacing). Up at #1353 there's a good view of the row in front of the wheel tubs but I can't quite make out the ones behind. I'd like to take my sections where I can cut out some crud in the skin but want them holes to wind up where they oughta be. Not that I couldn't fill any wrong ones and make new ones, but it'd sure be easier to just section it just so. Paint is really looking good man. My eyes are peeled on the assembly and final. I think you've changed my way of thinking on how to go about it.
11-20-2013, 09:32 AM | #21 | ||
Still Learning
Re: 1969 Short Wide
No scuffing between coats on the clear. "Most" activated paints and clears can be top coated up to 24 hours before scuffing is required. Quote:
11-20-2013, 02:26 PM | #22 |
Re: 1969 Short Wide
X2! Nice fab work!
What do you reduce Raptor with? Do you need to do that where you want it "pretty"?
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
11-20-2013, 02:55 PM | #23 | ||
Still Learning
Re: 1969 Short Wide
I think, and I may be wrong but it seems temperature sensitive too. The cooler temps like we have had lately make it less "pretty". It's pretty thick anyway but when it's 95 in the summer it seems to flow and lay prettier. Ya know. |
11-20-2013, 07:43 PM | #24 |
Re: 1969 Short Wide
I'm almost sure I did, but if I didn't comment back when you posted them exhaust fab photos - stellar work!
11-20-2013, 09:45 PM | #25 |
Re: 1969 Short Wide
Awesome exhaust mounting idea! Wanna come to the Houston area and do mine?
