Old 05-04-2011, 11:28 PM   #1
Ackattack
Ackattack's Avatar
Re: Project No-buck!
Originally Posted by mcbassin View Post
Hey Ack,
Glad to hear about all the progress. This is such a cool project. I would love to tackle one like if I didn't have so many irons in my fire.
Anyway, I have rebuilt a few alternators in my time. I know you can handle it for sure. The only real kicker is the brushes. You will need a small pin to compress them and the spring from the access hole in the rear. The bearings are pretty straight forward. The ball bearing(s) on the armature will require a puller or maybe an arbor press. The needle bearing on the cover is a little tricky too, I have had to cut them out because of corrosion. If it is still charging properly, it will be a good candidate for overhaul. I bet there is a FAQ on here somewhere.
How about some pics of the progress in the new shop.......
New shop IF the bank pulls their head out of their butt. They're giving us "problems" because we haven't been in our current house for a year and we're keeping it as a rental. Even though the bank of our current house says its fine as long as we meet a few (no brainer) conditios. So its still up in the air at this point, 12 days from when we're supposed to close. Inspection is tomorrow!
Ackattack is offline   Reply With Quote
Old 05-15-2011, 07:09 PM   #2
sbc383rulz
sbc383rulz's Avatar
so how goes the battle? love the truck and cant wait to see progress!!
1969 C2500 350/np435
1983 malibu wagon vortec 350/700r4
Gillis
sbc383rulz is offline   Reply With Quote
Old 05-16-2011, 12:40 PM   #3
Ackattack
Ackattack's Avatar
It's judgement day (closing day) and the bank is winning...or at least delaying.....so we're still waiting.
Hope to get my passenger side mirror installed, new tires and an alignment before moving day.
Old 05-19-2011, 09:05 AM   #4
68 TT
Still plays with trucks
68 TT's Avatar
Good luck with the closing. I hate dealing with the banks.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 05-18-2011, 08:49 PM   #5
Ackattack
Ackattack's Avatar
Got my mirror installed.
Got new tires on (went with 235/75/15.....figure they're cheaper for now and will do good in the snow) I'm thinking I'm going to get 20" Boss 338s eventually, but for now they'll work.
Also got the alignment done.
Seems to drive around good, and the slightly shorter tires its seems better taking off in 2nd (sm 465) with the 3.08 gears.
Old 05-18-2011, 10:05 PM   #6
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
Glad to see you made it to KS. Looks like the truck is coming along!
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily.
04 Pontiac GTO
04 Ford Mustang GT
68 C20 LWB stripper truck
73 K5 Cheyenne
76 C20 Sierra Crew SRW
88 K20 Suburban
I'm not hammering on metal just to hammer, i'm creating a piece of art.
1BadSS is offline   Reply With Quote
Old 05-18-2011, 10:33 PM   #7
mcbassin
Still Learning
mcbassin's Avatar
Where's the pictures Ack?
Old 05-18-2011, 11:24 PM   #8
Ackattack
Ackattack's Avatar
no pictures.....I think all the cables to upload them are packed anyways.
Honestly, I don't like the way the rear tires look. With the rear being narrower than the front, it looks goofy to me. I ran into this same thing with my 72, so I'll probably do the same as I did there and run a set of spacers on the rear.
Old 05-19-2011, 09:09 AM   #9
68 TT
68 TT's Avatar
What about trying to retrofit a newer rear end into the truck that is wider instead of spacers?
I know the 88-up trucks rear end is a little wider than a square body and fixes their offset wheel placement issue. I wonder if one or the other would do the same for a 67-72?
It may end up being cheaper than the spacers and give you a chance to get gears you want and a posi too while you are at it.
Old 05-19-2011, 12:43 PM   #10
Ackattack
Ackattack's Avatar
I thought the 88-up trucks were 10 bolts. Might be something to look into. I'm considering buying a 88+ parts truck anyways for a TBI swap.
I got a posi
Old 05-19-2011, 02:55 PM   #11
68 TT
68 TT's Avatar
I got a posi
They are 10-bolts but have 8-1/2" ring gears and the newer ones have 30-spline axles. They are stronger than the truck 12-bolt with their larger pinion diameter and much easier to get parts for.
The square body 88-91 Suburbans did not get the 30-spline version from what I have been told so to be safe I would look for a truck as your TBI donor.
Old 05-19-2011, 09:51 PM   #12
Ackattack
Ackattack's Avatar
The house is mine!!!! No buck made its first moving run, and came back on the freeway at 65 and it rides real nice with the new tires and drives straight.
Bruiser will be going over shortly to get tucked into its new bed
Old 05-19-2011, 10:13 PM   #13
mcbassin
Still Learning
mcbassin's Avatar
Congrats on the house!
Old 05-20-2011, 01:23 PM   #14
68 TT
68 TT's Avatar
x2!!!!
Glad it worked out for you.
Old 07-05-2011, 01:02 PM   #15
Ackattack
Ackattack's Avatar
So now that we're moved in, have gotten settled in pretty good, and got my shop set up its time to get some work done on this truck.
The first thing is its looks. As it sits right now, it looks like a christmas ornament being red, green, and white. So I pulled it into the shop last night and started sanding, hammering, and mudding. I'm gonna get it all painted up finally.
I also figured out a logo to put on it for the "shop truck".
I remember going to big a auto parts when I was about 4 with my dad. They had a counter with bar stools that would spin. Being a 4 year old, I'd sit up there and spin around while my dad was ordering whatever (or BSing...I don't know...I was 4).
I think It will look pretty cool, and should be pretty easy to paint on. I even convinced my wife to do the painting of it, to get her involved a little.
I also have the clips to put the trim on the grill and head light bezels. The alignment of the hood/fenders/grill isn't right, so I think the cab is on just a little crooked. I'll loosend up some bolts and see if I can wiggle it around a little.
Old 07-05-2011, 07:49 PM   #16
Trailrider95
Trailrider95's Avatar
Lookin forward to some pictures!
Glad to hear you're able to start working on the truck, and I like that idea of the shop truck. What color are you gonna paint the truck though?
Trailrider95 is offline   Reply With Quote
Old 07-05-2011, 11:15 PM   #17
Ackattack
Ackattack's Avatar
Its going to be the flat red like the front clip is. The grill inserts (for lack of a better term) are off white to add a little contrast. And I'm going to paint the "CHEVROLET" in the tailgate the same off white.
Old 07-06-2011, 06:17 PM   #18
68 TT
68 TT's Avatar
Glad you got settled in and can now get back to working on the trucks again.
Old 07-10-2011, 10:05 AM   #19
Ackattack
Ackattack's Avatar
Some progress on the bed side
And I also removed the tailgate. It needs a few repairs too. The paint on it was flaking real bad, so I decided it would be best to strip it.
Old 07-11-2011, 11:04 AM   #20
68 TT
68 TT's Avatar
Nice to make some progress isn't it.
I'm finally able to get back to working on my trucks after seven months off for recovery from two separate accidents. It feels good.
Old 07-24-2011, 12:15 AM   #21
Ackattack
Ackattack's Avatar
A bit more progress on the body work:
I almost have the drivers side bed ready for paint. I put one last coat of high build primer on it tonight, so hopefully a little sanding and the bedside will be ready.
I also started welding up some holes in the door from various mirrors that have been installed over the years, and then the holes from the custom badge. There is just a touch of a rust hole at the bottom front corner that I'll need to do a little repair on. The door also has holes for trim, but I didn't fill them in cause I'm thinking I'm going to install the 67-68 side trim.
I also put a little bright work on the front end.
I've been sellling a few parts, so I have a little money to spend, so I ordered an ECE super track bar and shock relocator. By installing the super track bar, then I should be able to run my passenger side exhaust the rest of the way back. The rearend doesn't have the original style panhard bar mount ear, so a previous owner welded a large panhard bar mount to the rear that prevents me from routing the exhaust through there.
I"m also going to order one of the grand cherokee electric fans, but thought I'd wait to order it for when I have more things to get from summit than just that to save a little on their handling fee.
Old 07-24-2011, 10:14 AM   #22
mcbassin
Still Learning
mcbassin's Avatar
Nice work on the front clip Ack. It looks great. You sure have taken this project a long ways.
Old 07-27-2011, 04:34 PM   #23
Ackattack
Ackattack's Avatar
Just ordered a suprise for my truck.....but you all will just have to wait
Old 07-27-2011, 05:44 PM   #24
I thought the twin-turbo was going on Bruiser?
Old 07-27-2011, 09:41 PM   #25
Ackattack
Ackattack's Avatar
you may be right (read the latest issue of hot rod mag) but that's not what I'm refering to. If you tried to turbo this thing, the 350 would die immediatly, I'm pretty sure. I don't push it very hard at all.
