Old 08-12-2009, 10:30 AM   #1
domsan
domsan's Avatar
domsan c10 custom
this is my c10 custom project. the dare is when he is finished as a daily driver used
domsan is offline   Reply With Quote
Old 08-12-2009, 10:32 AM   #2
domsan
domsan's Avatar
Re: domsan c10 custom
as you can see is a lot of work to the vehicle, but it remains within limits
I started last year
Old 08-12-2009, 10:36 AM   #3
domsan
domsan's Avatar
but as you see, I wanted to clean it once again have
which is why I completely disassembled the car and scratch made
Old 08-12-2009, 10:37 AM   #4
domsan
domsan's Avatar
Old 08-12-2009, 10:38 AM   #5
domsan
domsan's Avatar
Old 08-12-2009, 10:40 AM   #6
domsan
domsan's Avatar
I hope the times you here like what I show you
Old 08-12-2009, 03:22 PM   #7
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Nice work and good job. Must be harder to restore a truck on the other side of the pond.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 08-12-2009, 03:56 PM   #8
domsan
domsan's Avatar
Thank you! The advantage is if you restore a vehicle which can all be forced to share work. you can not even ebend into a load or go to a scrap new flat share to obtain
and if you need to share it no longer has or needs then ordered one in the States
Many stores like doing business with one, but there are also many that are against it with a shut operations
people at home, it is just as
Old 08-12-2009, 04:12 PM   #9
domsan
domsan's Avatar
here are more pictures
Old 08-12-2009, 04:14 PM   #10
domsan
domsan's Avatar
as you can see the light sheet metal rust
Old 08-12-2009, 04:16 PM   #11
domsan
domsan's Avatar
Old 08-12-2009, 04:18 PM   #12
domsan
domsan's Avatar
Old 08-13-2009, 01:17 PM   #13
domsan
domsan's Avatar
here are new pic`s
Old 08-13-2009, 01:18 PM   #14
domsan
domsan's Avatar
Old 08-13-2009, 01:21 PM   #15
domsan
domsan's Avatar
Old 08-13-2009, 01:52 PM   #16
lks dcvn
lks dcvn's Avatar
Looks good - plenty of welding practice I see.
Did you pick that truck up over there - if so are the prices decent or are they more?
lks dcvn is offline   Reply With Quote
Old 08-13-2009, 02:05 PM   #17
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Great looking project!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 08-13-2009, 03:30 PM   #18
Dano69c10
Dano69c10's Avatar
I like your work! Great job in saving a cab, most people would have scrapped that one over here in the states.
'69 Fleet
It ain't yours, if you didn't build it!
Dano69c10 is offline   Reply With Quote
Old 08-13-2009, 04:03 PM   #19
domsan
domsan's Avatar
yes was a lot of work on the truck
thanks !
so fast I did not give up. and I like to do it, you can always learn something new in such work
Old 08-13-2009, 04:09 PM   #20
domsan
domsan's Avatar
I am at work
The cottage after sand-blasting in the first primer
The doors have also suffered greatly
But this is nothing new in pu
Old 08-13-2009, 04:14 PM   #21
domsan
domsan's Avatar
the cab at primer
the frame will also work slightly
Once the depth test
Old 08-14-2009, 02:06 PM   #22
domsan
domsan's Avatar
the frame
and how should it be otherwise be a airride
Old 08-14-2009, 02:48 PM   #23
domsan
domsan's Avatar
the rear axle
Old 08-14-2009, 03:34 PM   #24
mcbassin
Still Learning
mcbassin's Avatar
You have some serious fab skills! keep up the good work! That will be a nice driver when you are done.
Old 08-14-2009, 04:29 PM   #25
domsan
domsan's Avatar
thanks
