Old 08-12-2009, 01:09 PM   #1
superflysteiny
superflysteiny's Avatar
second chance 67 chevy, project from hell
[IMG][IMG][IMG][IMG][/IMG][/IMG][/IMG][/IMG]Hello everyone my name is Eric and I am new to the forums. I have been building cars for years now. I was in the middle of building my blown 429 boss 1940 ford coupe a little over a yr ago, when I found a finished 1967 (or so I thought)chevy short bed for sale on ebay. My wife and I wanted a truck we could cruise around in and take to local shows. I called the owner worked out a deal and purchased the truck site unseen. This was my first mistake. Let me tell you a plane ticket is less expensive.
History of the deal. Truck rolls off the truck and man does it look nice. Full frame off custom painted frame and body. Hood was not on the truck and I was told it was because he did not have the time to put it on because he was to buisy. Truck was supposed to run but the guy stated he had not driven it because again he was too buisy. Back to the story. Pull the truck into the garage and charge the battery and fire the truck up. The motor (92 lt1 corvette engine)is running on 4 cylinders and is blowing water out the exhaust like a fire house. Traced down all water lines and found a water line pluged into the intake manifold. Remove the line and placed it were it is supposed to go. and check the cap and rotor. also known as optispark. Let me tell you otispark is the craps and is the biggest piece of poop gm ever came up with. Replaced it because it was bad along with all the wires and plugs. Fire the truck and it ran but was still blowing a little water. Pulled the motor and replaced the head gasket and the mains. Put the motor back in and fired the truck. It was running great. now we are 2 weeks into it and I am going to take it for a test drive. I go to back it ouyt of the drive way and the trans blows. Push the truck back into the garage and drop the trans. Take it to the trans shop and they tell me there is not even a single part in the trans that is any good including the housing. So I now have to replaced the 700r4 $1500 along with a new stall converter $500. So i call the guy and tell him he mis represented the truck and I want some money back. 2000 for the trans, he states he spent all the money and can give me 500. I tell him 1000 and he is extremely lucky that I have the ability to fix the truck. If it were someone that could not he would most likly be getting getting a letter from an attorny, long story short I decided to tear the truck down to the frame and start over to the fact that i new it was not built correctly and boy was I right. No carter pins on the steering castle nuts, no lock washers, or nylon nuts on the trailing arms. Stripped brake line connection glued back together with pipe dope. Hood was off 2 inches because sheet metal was not gaped and fitted before it was painted. Rear cross member was not welded in placed and was the cross member that the rear triangle attached too. so the rear end was moving left to right. Very dangerous as you all no. Ok so I am done with all the wrongs fast forward to were I am now.
Pull truck apart replaced all the brake lines and valves with stainless and earls fittings, removed 1000 pounds of body filler from the frame and boxed in the back half of the truck. Re welded the notch and reinforced it. Replaced the motor with a blown 427 chevy, 2 850 demon carbs and 871 bds blower. Vintage air and custom painted trans and block. Powder coated every part on the under carage and replaced all bushings and placed pins on all castle nuts. New chrome shocks and replaced all air line and fittings and switches to the air ride. Redid all of the body work and paint and replaced the brakes with wilwoods. Had Frank wallick from colorado do all new dash, seats, door and kick panels, inner bed panels and and bed tubs out of air plaine aluminum and brass. Built custom inner fenders up front. And replaced all wiring because the original wiring look like my 3 yr old daughter did it. I have done this build in the last yr and I wanted to know what you guys thought so far. The project is called second chance and was modeled after a world war 2 air plane which is a douglas 47. The color on the frame is called silver vein and the out side is painted olive drab gloss green, I will be putting photos up tonight. The moral of this build is beauty is only skin deep. It was my fault that I did not fly out and look at the truck before I bought it. I hope you guys like this project because I have worked my tail off on it it along with my father and friends.
superflysteiny is offline   Reply With Quote
Old 08-12-2009, 01:09 PM   #2
superflysteiny
Re: second chance 67 chevy, project from hell
pics posted tonight.
Old 08-12-2009, 03:19 PM   #3
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Looking forward to pics.
I agree, I never buy a vehicle, sight unseen.
Glad you didn't give up but sounds like a lot of work, time and $$$
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 08-12-2009, 04:50 PM   #4
superflysteiny
I will have them up tonight
Old 08-12-2009, 04:57 PM   #5
Byronic
The Beach Cruiser
Byronic's Avatar
Subscribed. I gotta see this. All in a year. You either have a big family or alot of friends.
1999 Silverado DD
1966 Panel Truck
2003 Harley Road Glide
1967 Schwinn Tandem Single Speed
Byronic is offline   Reply With Quote
Old 08-15-2009, 01:16 AM   #6
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 08-16-2009, 12:40 PM   #7
kev2809
low n' slo
kev2809's Avatar
wheres the pics?!?
and welcome to the forum!
kev2809 is offline   Reply With Quote
Old 08-16-2009, 12:52 PM   #8
crimespree
crimespree's Avatar
when i got my truck the oil pan was half unbolted, the hood was made from 80 % bondo, and it had wires run from the cab to every direction of the truck with no connection at the end of it. cant wait to see the pics.
1970 CST - http://67-72chevytrucks.com/vboard/s...d.php?t=350091
1979 Yamaha xs650 bobber - sold
2008 Harley Nightster
crimespree is offline   Reply With Quote
Old 08-23-2009, 11:21 PM   #9
superflysteiny
Old 08-23-2009, 11:22 PM   #10
superflysteiny
http://i1005.photobucket.com/albums/...ography005.jpg
Old 08-23-2009, 11:23 PM   #11
superflysteiny
Old 08-23-2009, 11:23 PM   #12
Richard8971
Still livin the "dream" in '54
Richard8971's Avatar
Holy crap! Nice looking project, esp the motor. Can't wait to see more progress.
D
Current build. 1954 Chevrolet 3800 "Ella" SOLD!
My '67 stepper "Tangerine Dream"
"Anything worth doing is worth doing right" James Dean
“When you have eliminated all which is impossible, then whatever remains, however improbable, must be the truth.”
Sherlock Holmes
"There is no spoon." Neo
Richard8971 is offline   Reply With Quote
Old 08-23-2009, 11:24 PM   #13
superflysteiny
More pics to come in the am
Old 08-23-2009, 11:25 PM   #14
superflysteiny
Sorry for the delay
Old 08-24-2009, 07:43 AM   #15
kev2809
low n' slo
kev2809's Avatar
man that thing looks mean!
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
Old 08-24-2009, 09:45 AM   #16
lks dcvn
lks dcvn's Avatar
I have also bought sight unseen projects - only to be super disappointed in the end.
Nice to see you stuck with it. Not sure what you paid, but I was have went after him for more than $1k - even if he already spent it - misrepresentation is still misrepresentation.
Nice truck though (now). Keep the pix coming.
lks dcvn is offline   Reply With Quote
Old 08-24-2009, 10:58 AM   #17
superflysteiny
I agree I just dont have the time. I am a single dad raising two kids building cars at night after the kids go to be and running a buisy dental practice. Just did not want to get into legal battle with a guy half way across the united states. What comes around goes around. I am uploading more pics this morning
Old 08-24-2009, 11:02 AM   #18
superflysteiny
Took the truck over to my buddies shop were we are painting it. Bed id on and doors and fenders shood be on the truck by the end of the week. I will get more pis this week with the bed on.
Old 08-24-2009, 11:10 AM   #19
OARNGESI
OARNGESI's Avatar
wow that truck looks like its going to be super nice
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 08-24-2009, 01:00 PM   #20
my67chevytruck
Under Construction
my67chevytruck's Avatar
Bad @$$ truck bro!
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 08-24-2009, 01:04 PM   #21
superflysteiny
Thanks guys glad you like it
Old 08-24-2009, 01:19 PM   #22
rockin562
rockin562's Avatar
one word. WOW!!!!
rockin562 is offline   Reply With Quote
Old 08-24-2009, 01:48 PM   #24
superflysteiny
Old 08-24-2009, 01:50 PM   #25
superflysteiny
