I'm just glad to be here!
Re: 67 cheby's Dropmember build thread (CLOUD 9)
I really liked the overall look at quality of work that those guys do for the chassis. Great choice!
That Pullmax will be a game changer for you!
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
#2 | |
67cheby
![]() Join Date: Sep 2008
i think so also!
gracias it is exceptional! I cant wait to start using it, i need to rob a bank first so i can buy some dies for it......pretty expensive! |
6>8 Plugless........
![]() Join Date: Sep 2007
That frame is so nice! That pullmax is nice too! Now you have a good donor engine so the next sema build should be a crew cab dually.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
Nice frame! I wish I had the space to do a full frame swap.
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
67cheby
How about a few updates on Cloud 9.5. I have been working on running all the 3 inch Flowmaster stainless exhaust, using Deeds Eng billet exhaust hangers, we also got the Currie 9 inch in with 35 spline axles, Wave Trac locker, 3:50 gears (since we are going 5 speed this time) I test fit the cab on that beautiful GSI Chassis this weekend! I also stripped all the wiring out of the cab to do it over and do it right this time....I did it myself last time and this time I am getting help, we will be using the new Painless Pro-Series wiring and my friend Brock will be in charge!
Are u going to have to change your bed floor with new chassis.
check out SANFORD build thread http://67-72chevytrucks.com/vboard/s...d.php?t=522019 |
67cheby
Yes i believe i will have to, i plan on test fitting the bed this week
67cheby
I could not get away from drive line vibration with my old two piece so i decided on this go around i would do whatever it takes to go to a 1 Piece (QA1 carbon fiber) driveshaft......so i started cutting and bending metal....heres where we are at
Looking good Mike! Been following on IG. Looks like you've been busy these last few months.
67cheby
Thank you, we are finally picking up a little steam!
67cheby
I test fit my mock up engine and TK0 600 5speed, and set the LSA blower on....its going to fill up that engine compartment very nice!
I went through several sets of headers trying to find some that fit, these are from Ultimate Headers and man are they SICK they sent them to me tacked together so we could test fit them then i will send them back and get them finish welded and fully polished...they look like jewelry when they are polished out! |
![]() Join Date: Mar 2011
Nice looking stuff...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
67cheby
I picked up a couple new tools off of Craigslist this week to add to the arsenal....i am slowly building my shop with a lot of the metal tools that i have always wanted.
67cheby
#15 |
Following along on the upgrades to C9.5
#16 |
67cheby
#17 |
67cheby
I started a kind of step by step install of the Altman Easy Latches from Trique Mfg, i was so sick of slamming my doors, i cant wait to get these finished up!
Very easy and detailed directions for the install. I couldnt finish this up just yet i need the truck off of the lift to easier access the door jamb. |
#18 |
How long will the driveshaft be?
#19 |
Latche looks nice, so what are you bringing to the GitDown ? 9.5 or sloshtubs
#20 |
67cheby
TONs and TONS of TUBZ!
#21 |
67cheby
First time setting the bed back on the frame, now to build some mounts and get it all fitting correctly!
#22 |
67cheby
#23 |
A guy with a truck
Raising the floor higher or bigger notch cover?
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
#24 |
67cheby
i am not much of a fan of the super shallow beds so i will just build a bigger notch cover
#25 |
67cheby
last night i started working on another of Cloud 9's problem areas. The self leveling Evercoat drip rail sealer that we used had started cracking, it made me worried that some rust had came up from underneath. I had personally cleaned it out the first time and i knew that the metal was perfect underneath. Turns out it is still perfect so i have no idea why it cracked out. I also had a couple bubbles come up in the cab corner area, i guess there must be some tiny pinholes in some of the weld spots?
Tags |
fiberglass inner fenders, pb hood hinges ", w/pb 4 link |
