Old 04-08-2003, 09:23 PM   #1
chevy2racr
So Many Ideas, So Little Money
chevy2racr's Avatar
What is needed to installv-8 in I-6 loc?
do I need I-6 stands or my v-8 stands work?drill holes? what?
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors
71 C10 with 454
99 S-10 5.1L SBC 700R4
09 Malibu
Marshalltown, Iowa
chevy2racr is offline   Reply With Quote
Old 04-08-2003, 09:26 PM   #2
passthebuck
Sisyphus was my mentor!
passthebuck's Avatar
good question - I'll EVENTUALLY be making the same swap in my '67 GMC.
passthebuck
#5642
-TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4.
-a 2013 Honda Civic as my "sensible" car
passthebuck is offline   Reply With Quote
Old 04-08-2003, 09:28 PM   #3
oldsub86
What do you mean "stands"? Are we taling motor mounts?
1968 Chevy - 292 with a powerglide
oldsub86 is offline   Reply With Quote
Old 04-08-2003, 09:32 PM   #4
Blackhawkdc
440 american Horses
Blackhawkdc's Avatar
So, if I read you right, you've got a V8 in it right now, but wanna move it back to the I6 position. Your stands and everything stay the same, you'll just need to move them back to the I6 set of holes in the frame, they should already be drilled there. AS far as the tranny cross member, it will need to be moved back. But as for that, I'm at a loss.
Seth Petro
1969 Chev Short Step
425hp 350, TH400, big tires, fast truck
1979 Pontiac Trans Am
1991 Saturn SL1 - gas mileage! (and free)
1977 Buick LeSabre - for sale
May America bless God, and may God bless America
Blackhawkdc is offline   Reply With Quote
Old 04-08-2003, 09:54 PM   #5
chevy2racr
chevy2racr's Avatar
it looks to me that I have no lower holes for it. anyone have a pic of the lower motor tower holes??
71 C10 with 454
09 Malibu
Marshalltown, Iowa
Old 04-08-2003, 10:13 PM   #6
Blackhawkdc
440 american Horses
For the lower holes, you'll probably have to set the stands and engine down inthere, get everything lined up straight, then mark the holes, pull the engine, drill and install.
Seth Petro
Old 04-08-2003, 10:16 PM   #7
gmc67swb
gmc67swb's Avatar
hey chevy2racer, mine was originally an i-6. I now have a v-8. at the time i knew nothing of 2 different mounting locations. when i look at mine i can only see on hole in front my existing mount. so either there is only 3 holes and they share the center or one of the two holes for the v-8 location is completely covered by the mount.
GM 330HP/350, Magnuson 122HH, Tremec TKO 5spd
gmc67swb is offline   Reply With Quote
Old 04-08-2003, 11:04 PM   #8
crazy longhorn
Fabricate till you "puke"
the 6 & v8 stands are different. On the top of the frame, the 6 stands bolt to the rear 2 holes(v8 stands to the front 2 holes). You will find exactly 2 1/2 " cent to cent on the top bolt holes on the frame.......however, due to the shape of the stands, i 6 position gives 3 1/2" of set back from sb v8 position. At the bottom, the 6 stands bolt to the rear of the crossmember(you will see the boltholes, in a slightly recessed area). i have done 3 of them this way......trust me , you dont have to drill anything if you use the 6 /250 stands. If you are running a stick, toss the bell crossmember, & use an auto crossmember under the trans......the bell crossmembers are also different 3 times.....BB stick, sb stick, & I 6 stick. they all position differently, & are on a slope on the rails, so they cant be moved to use in a different position. Sorry, no pics of the bottom at this time, but the 383 is in i 6 position, with a 6 spd Richmond behind it( on a modified auto crossmember). good luck, crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 04-08-2003, 11:54 PM   #9
Slammed67
Progress = 0%
Slammed67's Avatar
I agree with Crazy.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 04-09-2003, 08:29 AM   #10
chevy2racr
chevy2racr's Avatar
so Jay and Crazy, you both used I-6 stands? will my v-8 stands set then engine lower in the frame than a standard I-6 stand with a v-8? thanks
Bryce
71 C10 with 454
09 Malibu
Marshalltown, Iowa
Old 04-09-2003, 08:42 AM   #11
crazy longhorn
I couldnt find a measurable difference on nose height with either position. If I had to give a number, i would say the v8 sits approx 1/4" lower in I 6 position( with I 6 stands & crossmember) than it does in factory V8 position. I used a 73 up long waterpump, & didnt have any issues with centering the fan in the stock sb shroud. crazyL
Old 04-09-2003, 10:30 AM   #12
dubie
dubie's Avatar
Here is a pic of the different mounting holes
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 04-09-2003, 12:37 PM   #13
1971Stepside
Almost Satisfied
1971Stepside's Avatar
here is a pic
of I-6 stands mounted on my frame (swapping them out for BB stands). You can see that they use the back hole in the cross member and are shaped differently than the v-8 stands. They will use the same motor mount though.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 04-09-2003, 02:37 PM   #14
crazy longhorn
Stepside, that frame is too pretty to cover up! crazyL
Old 04-09-2003, 02:53 PM   #15
dubie
dubie's Avatar
I agree, that is the SWEETEST rolling chassis I have ever seen!!!
Old 04-09-2003, 03:49 PM   #16
1971Stepside
Almost Satisfied
LOL, thanks guys. Maybe instead of new patch panels in the floor I could go with plexiglass!!
Old 04-09-2003, 04:32 PM   #17
Shane
Shane's Avatar
I also agree with Crazy Longhorn .... i have both types of stands (I-6 & V-8) and plan on putting my V-8 back in the I-6 position to move the engine towards the cab. They are NOT the same peices ...
Shane is offline   Reply With Quote
Old 04-09-2003, 05:07 PM   #18
72MARIO
72MARIO's Avatar
How close is the HEI to the firewall ?
Does it still come out easily. any other down sides ?
Thanks.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 04-09-2003, 05:38 PM   #19
crazy longhorn
The HEI fits, with about 1 finger clearance tween the firewall & the cap(pretty snug). It will go in/out of the eng with the cap & rotor off. it hasnt been a problem, but when I upgrade Im going small cap MSD.........crazyL one upside, the oil pan will come off with the eng mounts in place
Old 04-09-2003, 06:39 PM   #20
adamls
Gotta Startem Early
adamls's Avatar
You could always go with a crank trigger instead of the HEI
67 SWB In Progress, one piece at a time, maybe 3 years I will be finished
adamls is offline   Reply With Quote
Old 04-09-2003, 08:30 PM   #21
Shane
Shane's Avatar
i dunno on the HEI ... i am running a Mallory Unilite.
Old 04-09-2003, 09:14 PM   #22
gmc67swb
gmc67swb's Avatar
here chevy2racer. this is mine with the 6 stands. finger points to the front v-8 hole
Old 04-09-2003, 11:22 PM   #23
chevy2racr
chevy2racr's Avatar
I know the holes on the top, I've known those for quite some time, its the lower hole on a v-8 stand. it doesn't line with any predrilled holes. thats where a i-6 stand would line up with a lower hole as well I assume. Jay, if you can get me a pic of how you shortend yours(where I can see the cut part) it may help man
Bryce
71 C10 with 454
09 Malibu
Marshalltown, Iowa
Old 04-09-2003, 11:25 PM   #24
chevy2racr
chevy2racr's Avatar
71step- I just noticed something too, anyreason you didn't remove the z-bar mount beofre you had that beast powder coated?
71 C10 with 454
09 Malibu
Marshalltown, Iowa
Old 04-10-2003, 09:45 AM   #25
1971Stepside
Almost Satisfied
At the time I wasn't sure what I wanted to do there so I left it. I kinda wish I would have removed it now, but once we are put back together you won't see it. The 502 will hopefully distract your attention from that!!
