09-20-2009, 11:10 AM | #1 |
Choke? What is this in the pic?!
Ok. So, I know very little about engines, but am trying to learn! Yesterday, me and a friend put on some ceramic coated long tube headers ($186 from Summit!!) Anyways, I noticed this linkage, its in the pic. I can pull on it a little bit. What is this??!? I have trouble with starting when cold, takes a long time to get it to turn over. I bought an Edelbrock 60 w/ elec choke from a board member and hope it fixes the start problem. BUT WHAT IS THIS THING?!?!
09-20-2009, 11:12 AM | #2 |
Roadtrip!
Re: Choke? What is this in the pic?!
Looks like the kickdown for an auto trans.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
09-20-2009, 11:33 AM | #3 |
Firefighter
Transmission kick down cable, it hooks up on the drivers side of the carb.
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA |
09-20-2009, 11:36 AM | #4 |
It is the kick down cable from your T-350 transmission. It originally hooked to your caeb linkage and the slotted portion bolted to a bracket that bolted to your intake. You could adjust it to where the trans would down shift when you stepped on the throttle. You can still adjust it now, just pull it out a little and put a wire tie or something to hold it in place. It should be pulled out some anyway, it provides extra pressure to the clutch packs. If pulled out all of the way it may not shift into 3rd until 40-50 mph or so.
09-20-2009, 11:47 AM | #5 | |
09-20-2009, 12:21 PM | #6 |
Who's got steelies?
If it is the trans cable for a 700R4 then it is not just a kick-down cable, it is THE cable that controls the whole transmission and how and when it shifts. Not having it hooked up or adjusted right will seriously shorten the life of the transmission!!
If you don't know which transmission it is, go under the truck and loock at the oil pan on the transmission. The 350 trans. has a square oil pan with a corner angled off, while the 700R4 has a funky shaped pan. If its been working for a while you probably got a 350, but you better double check and look at the pan.
1969 C10 LWB W/ 250 I6 & 3spd 1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver. 1975 Chevelle Malibu Classic Coupe 350/th350 mint green 1970 C20 Suburban 350/700R4 4.10 gearing green & white 1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver 1983 GMC 1500 Sierra 305/SM465 2.73 rear end How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel |
09-20-2009, 12:46 PM | #7 | |
If it is the TV cable it needs to be properly adjusted here's a link
http://www.tciauto.com/Products/Inst...ble_adjust.htm
1965 GMC shortwide big window 1969 Chevy C20 long (for now) 2005 Silverado 2500HD Crew Cab Quote:
09-20-2009, 12:49 PM | #8 | |
Also, I looked at the carb and noticed the engine guy put a sizp tie around a floaty looking thing (like that term?!?) |
09-20-2009, 01:44 PM | #9 |
Kid's Mechanic
this may help
09-20-2009, 02:00 PM | #10 | |
Who's got steelies?
Here are some picks:
09-21-2009, 09:23 PM | #11 | |
How much should this be pulled out? I pushed it in some, but it still doesn't shift to 3rd until about 35, seems late doesn't it? |
09-22-2009, 10:50 PM | #12 |
425hp409
To adjust the detent cable for your TH350 transmission, with the throttle wide open, pull the cable all the way out and connect it in that position. Your transmission then will have proper pressure and should have detent, or passing gear when throttle is depressed to the floor. The transmission also has a vacuum line from the intake manifold to the vacuum modulator that controls the speed when it upshifts and the relative firmness of the shift. The vacuum line from the modulator must be connected to manifold vacuum (full vacuum at idle). If the transmssion shifts too late or soon, the vacuum modulator may be bad. If trans fluid is present where the vacuum hose connects to it, it is bad. Unless you have an original large diameter vacuum modulator, it is adjustable to fine tune the shifts. To adjust the shifts, remove the vacuum hose from the modulator, with a small screwdriver, turn the screw inside the vacuum port. To raise the points and firmness, turn the screw in (clockwise). To lower and soften the shifts, turn the screw out (counterclockwise). Test drive after each adjustment. I would do a half turn at a time until you have it where you want it.
Charles 68 SWB, Dad bought new, now 396 & factory ac 64 Impala SS, 409 425HP, 4 speed AC 64 Bel Air Wagon, 400 Small Block 57 Bel Air all original 283 w/Factory Air 77 GMC Sprint, 454/425HP 67 Olds 442, all original 90 ZR1 Corvette |
09-22-2009, 11:01 PM | #13 | |
I don't have a kick down cable though. Just a switch mounted beside the gas pedal. |
09-23-2009, 09:46 AM | #14 |
425hp409
On a TH400 transmission, there is no cable. The TH400 uses an electric kickdown, hence the switch on the gas pedal and a wire running down to the left side of the transmission. The vacuum modulator is responsible for upshift timing and feel, and part throttle downshifts, whereas the electric solenoid is responsible for full throttle downshifts. the modulator can be adjusted just like one on a TH 350. If adjusting it doesn't do what you want, you may have to have a transmission shop look at it for a repair or adjustment in the valve body or servo.
09-23-2009, 02:41 PM | #15 |
Ok, thx
11-05-2009, 12:54 AM | #16 |
can some plz post a pic of the switch on the gas pedal for the TH 400 transmission.Where is the electric switch located.......
11-05-2009, 01:39 AM | #17 |
I broke my camera last week but I'll see if my phone can take a good enough pic tomorrow.
11-05-2009, 02:29 AM | #18 |
thanx
11-05-2009, 12:15 PM | #19 |
I dun gradjiated collij!!!
"can some plz post a pic of the switch on the gas pedal for the TH 400 transmission.Where is the electric switch located....... "
This is the setup on my 67, 327 4jet TH400.....Hope it helps
Built NOT Bought. Viper Red 1971 LWB C10 355 Vortec W/700R4 4/5 drop AKA Screamin' You are missed!
2006 F150 XLT 5.4L Triton Rollin' on 22s the "F1" 67 C20 PS/AC/327/TH400 we call 'er "Bessie" 67 Malibu PS/ZR1-LS1 Brakes/350 Vortec/700R4 2/2 drop on 18" 338s - Tracy's "Boo" Boosted '67 Cougar EFI 5.0 HO roller motor/T5/8.8 Tracloc/ 4 wheel disks - "Project Panther" 79 Honda Z50 - stretched, cafe'd and hotrodded 125CC Lifan/5spd FEAR THE MONKEY! Last edited by screamin_c10; 11-05-2009 at 03:04 PM. |
11-05-2009, 12:30 PM | #20 |
If I set mine up with the throttle wide open it wants to shift down at odd times. If I pull on the cable it moves all the way out but then if I pull a little harder it move another 1/4" or so. Do I set it so I have it completely out or just before the extra movement. BTW my 350 was just rebuilt so eveything should be working correctly. I just switched from and Edelbrock to a Q-jet so the length of the linkage to the carb is different. It had a small extention on the linkage to make it work for the Edelbrock but it is to tight if I hook it up directly to the Q-jet.
11-05-2009, 01:56 PM | #21 |
here is how mine is setup can someone plz help identify switch
11-05-2009, 02:06 PM | #22 |
No switch that I can see in those pictures. If you have a TH400 the switch should be on the gas pedal.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
11-05-2009, 02:07 PM | #23 |
Between Trucks...
Some had the switch at the carb.
Beat it to fit, Paint it to match... |
11-05-2009, 02:32 PM | #24 | |
it's the switch with the orange and yellow wire in screamin's post. That sw wont work on an Edelbrock carb you can use a Lokar kick down switch or a nitrous wide open throttle switch.
http://www.summitracing.com/parts/LOK-KD2400HT/ http://www.summitracing.com/parts/EDL-72280
11-05-2009, 04:19 PM | #25 |
does anyone happen to know where this connects to on the tranny ? I was under the impression that the 400 only used vacum.
Mike K Friend of Bill W |
