Old 10-11-2009, 05:56 PM   #1
coloradosean2009
coloradosean2009's Avatar
Lets See Some Winter Traction Solution Photos
Here are a few pictures of my solution to 2wd in Colorado winter.
My goal is to add weight that will (1) remain in place (2)is not very expensive (3) will not make a mess, and (4) reusable in the future.
The "tube sand" that is sold across this country is the biggest ripoff ever. You get 40# in a "tube" for ~ $3-4. The best part about the tube sand is when it breaks all over the back of your bed. Even worse, when you do get stuck, you end up breaking into the bag early.
I have used this method in the past with great success. I have a couple of 4x4 and some 2x6 hem/fir. Three 25 gal rubbermaid bins (make sure you buy the soft plastic bins, harder plastic will crack in the cold).
The old gal weighs # 4,620 before, #5,220 after. That is # 600 of "squeege" mix (sand and irregular fines < 3/16"). The bins are nice because I will have a supply of dry traction sand, when I need it. I am also going to add some small plywood covers to hide my chains from thieving eyes.
Total Cost:
3 bins $ 22.00
Wood/screws $ 35.00
Sand $ 7.41
Total. $64.41
Equivalent Weight in Tubesand @ 3.50/lb = $52.50
I think I have accomplished my goals. Of course, the real savings will come years down the road when I don't have to invest in the hardware.
Lets see what your solutions are
__________________________________________
Sean
1972 C20
2005 4Runner
coloradosean2009 is offline   Reply With Quote
Old 10-11-2009, 06:33 PM   #2
nbrfd007
nbrfd007's Avatar
Re: Lets See Some Winter Traction Solution Photos
Great idea! We don't get snow like you, but when we do, I take my tractor with a front-end loader and load my bed with snow. When it warms up, the weight melts away. Not for truck in garages, bad mess.
nbrfd007 is offline   Reply With Quote
Old 10-11-2009, 06:35 PM   #3
mikey531
mikey531's Avatar
This is mine ...
mikey531 is offline   Reply With Quote
Old 10-11-2009, 06:53 PM   #4
haysonj
haysonj's Avatar
My solution is to stay in California
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 10-11-2009, 07:01 PM   #5
BAGNDRAGIT
Just Not Low Enough!
BAGNDRAGIT's Avatar
for me its arizona. snow....whats that?
NEED ELECTRICAL HELP? ASK ME!
67-72 Full Wiring Diagrams
Lots Of Info, TAKE A LOOK
1967 Chevy C-10 Shortbox Bagged 327 4spd
Previous:
1971 Chevy C-10 Short Sep I6 Auto (Traded)
1973 Chevy C-20 *THE REDNECK BATTLE TRUCK*
2001 Chevy Silverado 2Dr 5.3L Shortbox. R.I.P.
1969 Volkswagen Bug
This is my first meeting, I have a horsepower problem.
BAGNDRAGIT is offline   Reply With Quote
Old 10-11-2009, 07:05 PM   #6
silverstreak
Good idea with the sand. I have 4 old tractor trailer tires mounted on rims I put in the bed as needed. They even fit under my bed cover. Even though it's a non posi rear, it usually does the trick.
silverstreak is offline   Reply With Quote
Old 10-11-2009, 07:20 PM   #7
big mike71
big mike71's Avatar
I just put a load of fire wood in the back.
I'm not as good as I once was, But I'm as good once as I ever was.
big mike71 is offline   Reply With Quote
Old 10-11-2009, 07:27 PM   #8
d4xycrq
For traction, I sling one or two of my three-point implements into the back of this snow-mover. Another option is logs - they are free. I know people that use lead shot. Or five gallon buckets of wheel weights from the local tire store. Weight, coupled with chains on all four wheels, means I keep moving. My Chevy C10? It stays safe and sound in the garage until spring!
Although this is a Willys product, it came with a Buick 350 that runs like a top - and is still working, after all these years.
Best regards
Ray
d4xycrq is offline   Reply With Quote
Old 10-11-2009, 07:45 PM   #9
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
the tube idea is a great one just wrong material here how you fix it for CHEAP
get a truck tube cut it across ( look you have a long tube) roll a 2x4 in one end of it then nail or screw anther though the tube into the other 2x4..( look it's sealed at one end)
guess whats next?? fill it with sand DUH!!! tie the other end off and your done...you can adjust the weight by filing it more or less.and if you get stuck untie the end grab the coffee can you threw in before you tied it off and sand your tires... works in cars or truck and is clean.......
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 10-11-2009, 08:20 PM   #10
americanmusc1e
americanmusc1e's Avatar
when you live in South Texas.... Winter= rainy season..........so....
-- Josh
Instagram: @americanmusc1e
OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread
FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread
1999 4wd OBS Tahoe - daily.
DM me if you can't see photos i posted
americanmusc1e is offline   Reply With Quote
Old 10-11-2009, 08:53 PM   #11
big_al_71
big_al_71's Avatar
For me is Fort Lauderdale Florida!!! the only snow we get is the one people snore up in their nose....
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 10-11-2009, 09:40 PM   #12
BAGNDRAGIT
BAGNDRAGIT's Avatar
ewwwwwwwww
Previous:
1969 Volkswagen Bug
Old 10-11-2009, 09:44 PM   #13
ryhan87
Ok. I see a little more snow than most of you guys up in Canada. Im gonna need something for weight in my truck here in a little bit. The containers of sand is a good idea, but i still want to be able to throw a snowmobile or atv in the back when need be. I was thinking about trying to find some heavy rubber mats and cut them too fit. There pretty heavy and that way i can just drive what ever on top of them. I might throw a container of sand in there too. Like the traction as needed idea. Any other ideas
ryhan87 is offline   Reply With Quote
Old 10-11-2009, 10:03 PM   #14
ERASER5
ERASER5's Avatar
Originally Posted by mikey531 View Post
This is mine ...
This pic should be in the Volvo thread in Alternate Tinkerings!
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 10-11-2009, 10:47 PM   #15
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Doesn't work well at the other end of California...
My solution is to engage the front axle.
If that's not enough, shovel snow into the bed.
If that's still not enough, stay home and stoke the fire. Nobody else will be out either.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 10-12-2009, 12:40 AM   #16
Average Joe
Average Joe's Avatar
I've got (2) 14" tires that I filled with leftover concrete from a pour. I added a half round piece of #4 rebar for a handle on each. Each tire weighs around 150#'s.
1967 C10 Suburban 454/TH400/3.07's
An Average Joe and His 'Burb:
http://67-72chevytrucks.com/vboard/s...d.php?t=775843
Average Joe is offline   Reply With Quote
Old 10-12-2009, 08:09 AM   #17
Those tubs all framed in are the best solution.Weight is easy to add.The problem is having it stay put.Around here,you shovel your bed full of snow and you might be hauling a glacier for a couple months.I clean it all out before it does the refreeze.
It snows in California and Arizona,just not on you flatlanders.
Old 10-12-2009, 10:58 AM   #18
kwmech
Big innertube in the back . I have an adaptor that allows you to put water into the tube. (tractor supply). Or I just drive my subaru
kwmech is online now   Reply With Quote
Old 10-12-2009, 11:34 AM   #19
GMC406
Professional Grade
GMC406's Avatar
around here a fairly common fix is just iron weights like tractor wheel weights, tractor front end weights or weights off an oilfeild pumping unit. They are small enough to keep your bed useable. Keeping them in place can be tricky, I either find a simple solution(varries by truck) or just drive nice wich is easier said than done lol
61 GMC 9' Step
Someday it will be a build http://67-72chevytrucks.com/vboard/s...=1#post3356828
67 C-30 Red Dale motorhome http://67-72chevytrucks.com/vboard/s...31#post3845531
71 GMC Street performer in the works
Waiting for warm weather
http://67-72chevytrucks.com/vboard/s...d.php?t=341946
1990 GMC Sierra GT-sold
1983 chevy 4x4-project on hold maybe sell
1969 Triuph GT 6- sold
1996 Ford I-6 5 Speed 4x4
2004 Dodge Intrepid- milage maker
1959 Ford Fairlaine, factory a/c 292Yblock- sold
1982 Honda XL500R
Always lookin for other old trucks!
GMC406 is offline   Reply With Quote
Old 10-12-2009, 12:46 PM   #20
69GMCLonghorn
69GMCLonghorn's Avatar
I know they're a bit of money, but I've never found anything better than a camper shell! Weight is evenly distributed, and doesn't move (if you're lucky!). Then you can add bricks, etc as needed.
And about the California snow thing: It definitely snows around here, just not right in the LA basin. The fun thing when I was in high school was to ditch class and drive my '69 3/4 ton up Angeles Crest Hwy and load it with snow. We could be back in town before it melted and drive around wingin' snow balls at unsuspecting idiots...
69GMCLonghorn is offline   Reply With Quote
Old 10-12-2009, 01:01 PM   #21
gangforward
Hootis is as Hootis does...
gangforward's Avatar
Yes indeed - main reason I moved from Idaho (Eastern, near Jackson Hole) to Florida.
67 C10 LWB Fleet, 383, TH400, PS, 4BL-Holley, Headers & 3" Exhaust, 3" drop front, 4" rear springs, ECI shock relocate, Panhard Bar kit, wheels & tires
1995 Z28 Convertible - Borla, K&N, Lingenfelter Motor, C6 Wheels & Tires
1990 2500 4x4 Suburban 3" Catbac System, K&N, 2" Lift, Wheels, Tires
gangforward is offline   Reply With Quote
Old 10-12-2009, 03:07 PM   #22
coloradosean2009
I like the idea. I wonder how it does in the below zero temps though.
Sean
1972 C20
2005 4Runner
Old 10-12-2009, 03:37 PM   #23
rwolf9653
more ideas than money
rwolf9653's Avatar
I did the snow in the bed thing when I was 16. The snow ended up packed tight and like a ball of ice. Three weeks later I ended up losing my axle seals from the extra wieght that refused to melt. From now on I will find another kind of ballast first LONG before I use snow again.
Randy
1948 Chevy 3100 5 window
1966 Chevy C30 Dually
1967 Chevy K10
1972 Chevy K20
1972 Chevy C10
1972 Chevy K5 Blazer
1987 Chevy V10
2003 Chevy Suburban
rwolf9653 is offline   Reply With Quote
Old 10-12-2009, 09:54 PM   #24
Hottrucks
Hottrucks's Avatar
thats funny I made a snow man in New Hampshire loaded it in the back of my other truck and covered it with a sleeping bag to insuate it and keep the wind off it drove non stop to Tampa Fla ( 21 hours )and set it on the lawn for Xams day...every kid inthe neighborhood wanna to touch it they had never seen a real snow man
Old 01-08-2010, 11:22 PM   #25
gmc1971harwich
gmc1971harwich's Avatar
colorado sean what size were the bins you used?
gmc1971harwich is offline   Reply With Quote
