10-13-2009, 01:01 PM | #1 |
2009 aluminum fuel tank *group buy only*
2009 Aluminum Fuel Tank Group Buy @ BOYDWELDING.COM STANDARD TANK (NON-EFI) $299.00 + 39.00 SHIPPING EFI TANKS $499.00 + 39.00 SHIPPING OVERALL DIMENSIONS ARE 26.5 X 19 X 10 TAPERING TO 8 IN THE REAR DRAWING OF THE EFI TANK WITH OPTIONAL 90 DEGREE FILL NECK 3D REPRESENTATION OF THE STANDARD (NON EFI) AND THE FITTING LOCATIONS WITH A STRAIGHT FILL PIPE W/CAP HERE IS A VIDEO OF THE STANDARD TANK WITH FILL CAP NOTE: THE SENDER AND VENT LOCATIONS HAVE MOVED. TERMS AND ALLOWABLE CHANGES GENERAL TERMS - So that i am able to offer these tanks at that price i cannot change the overall dimensions at all. - all tanks will be built from .125 mill aluminum - all tanks will have baffles (EFI tank baffles may be different) -all tanks will be programmed and cut identical with fill pipe, sending unit flange and vent fitting locations locked in FILL PIPE OPTIONS - Straight filler neck w/cap. Height is standard at 3" but can be adjusted to suit your needs please specify. -90 degree fill neck. available in 1.5" or 2" overall height on the 2" cannot be changed (I need the 1" clearance for welding) - locations of those fillers on the tank cannot be changed FITTING SIZE OPTIONS -Vent, return, draw fittings can be whatever size needed but standard is .375 if not specified. MOUNTING TABS - all mounting tabs will come undrilled - mounting tabs can be whatever location down from the top please specify. TIME FRAME I would like to get started on these around NOV 2ND but im flexible. fabrication times are normally 10-14 business days depending on the total number tanks will determine wether i can keep that schedule. PAYMENT TERMS Full payment is requred at time of purchase Nov 2nd or group decided date. if there are any questions please ask.
Dave Boyd View Our 63-72 C10 Tank options https://fueltankparts.com/collections/63-72-c10-tanks Boyd Welding Main Site : http://www.boydwelding.com/ Boyd Online Shop: https://fueltankparts.com/ E: Sales@boydwelding.com |
10-13-2009, 01:20 PM | #2 |
VA72C10
Re: 2009 aluminum fuel tank *group buy only*
I'm in
If I do the side fill on mine, have the side flange 3/4 higher so the tank fits flush, and take 1" off the bottom, would that change the pricing at all? Also, any chance of me paying today or tomorrow to get mine produced as soon as you have time? I am ready for my tank as soon as I can get it. Mine is carb setup...not EFI...
Looking for a 67-72 swb or blazer project in or around VA. Last edited by VA72C10; 10-13-2009 at 01:20 PM. |
10-13-2009, 02:01 PM | #3 | |
I can build your tank whenever you are ready, however i cannot give you the group buy price.
10-13-2009, 02:09 PM | #4 |
VA72C10
Okay, I'll stick with the standard dimensions then...what's the soonest I could have a tank?
Looking for a 67-72 swb or blazer project in or around VA. |
10-13-2009, 02:26 PM | #5 |
production times are 10-14 business days so if ordered today your tank will ship nov 3rd
10-13-2009, 04:03 PM | #6 |
what gallon tank 18 or 20
bogey5 |
10-13-2009, 04:23 PM | #7 |
10-13-2009, 09:54 PM | #8 |
VA72C10
I just got back in....I can paypal or pay by credit card...let me know what works for you. I want the carb tank with the mounts moved up 3/4", the side fill (has to be less than 3" above the top of the tank overall to fit) Thanks!
10-14-2009, 08:04 AM | #9 |
You can put another person down and I'll paypal tonight after I do a few quick measurements. Quick question, can the fill neck be made to accept a fill hose instead of using a gas cap and can its dimensions vary (looking at maybe 1 1/2" to use a boat filler).
Thanks, Jeremy |
10-14-2009, 01:29 PM | #10 | |
VA72C10
10-14-2009, 05:15 PM | #11 |
no problem...
10-14-2009, 05:21 PM | #12 |
SIDE NOTE:
Besides the gallons questions which answer is 19 gallons. all your questions for filler sizes and options have already been answered in post #1 of this thread please refer there first. If you are ready to get moving on your tank before the group buy deadline. you can purchase this tank on my website for the regular price + shipping 24/7 here is a link. http://www.boydwelding.com/products.html#C6 if you are wanting to participate in the group buy please bump this thread and e-mail me your contact info so that i can get organized on my end.... email addy is daveboyd@boydwelding.com Thanks,
10-14-2009, 07:12 PM | #13 | |
Thanks, Jeremy |
10-15-2009, 05:29 PM | #14 |
Champagne Taste on Beer Budget
Is there a sending unit and pickup included with the tanks?
Are these baffled tanks? Do they include any mounting hardware? Also could one be made with the filler tube in the center? Thanks.
Coming Soon: Project 1970 Country Truck Last edited by C20-67_N_MO; 10-15-2009 at 05:42 PM. |
10-15-2009, 06:06 PM | #15 | |
1. we do not supply sending units, we do supply the mounting flange. there is a fuel supply fitting on the pass front corner refer to the second drawing in post #1. here are 2 sending units that will work with our sender. 240-33 ohms - http://www.jcwhitney.com/UNIVERSAL_F...;N;2008885;0;0 0-90 ohm - http://www.egauges.com/vdo_indS.asp?...90ohms&PN=SN38 2.Yes they are baffled please refer to post #1 3.We do not supply bolts 4 Yes I have 2 tanks in process as we speak with center fillers. send me a sketch showing how you would like it done.
10-18-2009, 07:14 PM | #16 |
Since there are no modifications to the posted tank dimensions it looks like I am out of the group buy. My space is 27" x 17" which means the 19" dimension won't fit. Don't understand why my space is different. This sucks.
10-19-2009, 06:14 AM | #17 |
I am dropping out as well.
Coming Soon: Project 1970 Country Truck |
10-20-2009, 11:30 AM | #18 |
All of your modifications can be done for a great price. we custom build each tank to each order if these tanks dont fit your needs let me know what does and ill build it for you.
10-20-2009, 08:55 PM | #19 |
I just measured my frame also and my dimensions are 27" side to side and 17" front to back... I guess whoever came up with the 19" front to back depth doesn't have the stock crossmembers back there??? Is everyone in the group buy gonna move their crossmember?
10-22-2009, 04:02 PM | #20 |
Thanks,[/QUOTE] Just sent my email as well... Thanks, Kyle |
10-24-2009, 09:39 AM | #21 |
Dave, Would you be willing to do a separate group buy price for the stock dimensions texas67chevy and I come up with?
10-24-2009, 09:59 AM | #22 |
Yeah it looks as if the design is going to need to be modified to suit others needs. use the original designs and modify them to fit your needs.
10-24-2009, 10:18 AM | #23 |
Sweet. Thanks! I'll work with texas67chevy and come up with a design we both agree will work with a stock set-up.
10-24-2009, 06:58 PM | #24 |
10-28-2009, 10:20 AM | #25 |
Yes i got it and sent a reply.
Tags |
boydwelding, custom aluminum tank |
