![]() Join Date: Mar 2013
Re: What did you do to your truck today?
Painted my 4 barrel intake today.
Realized that if I turn my a/c on then off the electric rad fan will not come on until I turn the truck off and start it again, aaaarrrggghhh. I reckon I'm taking this electric fan out and putting the mechanical one back in, only with a fan clutch this time......
If your strength is small, don't carry heavy burdens. If your words are worthless, don't give advice. Chinese Proverb ![]() |
Senior Enthusiast
Got the Comp Cams bumpstick swapped into the new engine today.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
Which comp cam did you use. I just put a Comp Extreme 4x4 270H in my 454 lately, what a huge difference.
Senior Enthusiast
I went with the High Energy 268H in a stock 350. Should be a lot more fun that the OEM cam I've been running for the last 21 years. I've got a Richmond 4 speed with 2.64 low gear and a Dana 44 in the rear with 4.10's.
Got my rear end buttoned up, installing the upper rear shock relocators, new tailights and housings, new rear wiring harness. Just waiting on the Lowes guys to bring my replacement compressor then I will install the springs and maybe the rear end tonight.
66 shorty ![]() |
#7 | |
![]() Join Date: Jan 2012
My '65 Suburban Resto build-- http://smg.photobucket.com/albums/v6...65%20Suburban/ And it's story of being 'saved' http://www.jalopyjournal.com/forum/s...d.php?t=631495 |
#8 | |
66 shorty ![]() |
Stripped the PS door, continued taking stuff off the cab...
rg |
#11 | |
66 shorty ![]() |
Just went out and put on the springs and shocks. Getting closer! I should have the rear end in Saturday and then the detail stuff starts.
66 shorty ![]() |
![]() Join Date: Sep 2011
Took off the front gas tank to my MH, it was leaking. Took it to a radiator shop for repair.
Past Master Triluminar Lodge #117 GL of WVa My 1963 4x4 Suburban build; http://67-72chevytrucks.com/vboard/s...d.php?t=531274 My Gallery, now with pics of my 1966 C30 motorhome. http://67-72chevytrucks.com/gallery/...&ppuser=103447 |
Pulled the 62's column, pedal assembly, built a dolly from scrap wood and pulled the cab off the frame.
rg |
#15 |
Picked up the Hood from the painter, the bird is mounted (safest place for now) Damn she looks good. He's got the tail gate and should get that back soon. Then the bed and she be done.
http://s1299.photobucket.com/user/jb...23904108567829 |
#16 |
One more
#17 |
![]() Join Date: May 2009
#18 |
Senior Enthusiast
#19 |
#20 |
Man bbb, I LOVE your truck... looks great!
rg |
#21 |
New fuel pump installed today on my SB350. It started and ran well so I guess I did it right.
------ 65 Chevy C10 Fleetside |
#22 |
BLAZER THIRTY!!
![]() Join Date: May 2007
not today but last thursday Holley 500!!!!!
49 chevy 5 window 20 year project (sold)😟 57 ford fairlane (dad's car never got to it before he passed away R.I.P I LOVE YOU DAD.) 62 GMC 305 V6 custom L/B 72 HIGHLANDER K5 BLAZER 2nd owner ![]() ![]() ![]() 71 K5 MAMMA'S RIDE! 63 GMC 4X4 305 V6 62 GMC SHORT BED SERVICE BODY V6 (STUMPY) 74 GMC CUSTOM 1500 L/B |
#23 |
Still working on my 73 suspension/disc brake change over. Trying to bleed the brakes was driving me crazy. Pumping the brake pedal & bleeding didn't work, gravity bleeding didn't work, using a Mighty-Vac didn't work. I've NEVER had this much trouble getting brakes to bleed. So while at work I cut up a piece of 3/8" scrap aluminum slightly bigger than my master cylinder with a rubber gasket to match. I drilled & tapped the plate to 1/8" pipe thread, installed a regulator & ball valve, topped off the master with brake fluid, chained down my contraption, cranked the air pressure to 14 lbs and bled my brakes. I now have firm pedal pressure and good brakes!!! Next, paint the motor and get it installed.
#24 | |
![]() Posted via Mobile Device Posted via Mobile Device
CURRENT & PAST CHEVY TRUCKS 60 C-10 Apache short step side 62 C-10 short step side 66 GMC Long bed fleet side 305 V-6 77 C-20 Custom Deluxe (Blue Goose) |
#25 |
Got my new AC compressor mounted.
