Old 11-01-2009, 11:19 AM   #1
-T-
-T-'s Avatar
The 'Other Woman'
Starting a build thread on my new purchase! I have had a '71swb project truck for over a year now, but found a running/driving '69 last Tues. Bought it on Wed. and have been driving the pi$$ out of it. The '69 has a 350 w/small cam/Th350 and lowered a little already.
-T- is offline   Reply With Quote
Old 11-01-2009, 11:30 AM   #2
-T-
-T-'s Avatar
Re: The 'Other Woman'
Notice the 'Dirt track racing' rims and tires, those will the first to go Looking at a set of Boss 338 either crome or w/gray centers. Opinions? I also got tubular A-arms with 5lug disc brakes for the front, and will convert the rear with the rearend from my other truck or go the u-pull-it yard and get some axles from a later model truck and just slide into my rear. The engine actually runs very well, just needs an over drive trans, she likes the go juice It also already has a '68 front end which is more to my liking
Old 11-01-2009, 12:14 PM   #3
chevy88
chevy88's Avatar
Sharp looking truck! I like the 68 front end also. It think it was probably cheaper to buy than restore anyways.
Kerry
My build thread.
http://67-72chevytrucks.com/vboard/s....php?p=3657823
1971 Chev SWB with 68 nose, 6.2 diesel th350, and 3.73 rear gears
1988 Chev Extendacab
2010 Honda VT1300CS Sabre
2005 Buick Rendezvous wife's ride
chevy88 is offline   Reply With Quote
Old 11-01-2009, 08:19 PM   #4
-T-
-T-'s Avatar
Thanks chevy88, im pretty sure it will have to be a little cheaper this way, and a whole lot faster!! Tackled one of the first projects tonight. It was lowered in the rear with heated stock springs and an aluminum hollow block that was homemade. The '71 came with lowering springs so i took the rear springs and replaced them and the blocks. The pinion angle is much better now, and it rides better. Next on the list is to get rid of those 31x10.50's on the back with something a little smaller.
And to explain the title of my build, my wife is in school and very busy, so i told her that I had 'another women' that i was spending time with.
Old 11-01-2009, 09:02 PM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
The chance of finding "later model axles", that fit,... is very slim.
You have the narrower 63-70 6-lug axle housing.
You will either need to purchase 5-lug "conversion" axles (from companies like ECE or Moser)
or swap the entire rearend out to the slightly wider 71-72 version.
Looks like you got a very nice truck to start with.
Keep those pictures coming!
Keith
Convert to disc brakes.
lolife99 is online now   Reply With Quote
Old 11-02-2009, 11:33 AM   #6
Slick67
Sofa King Crazy!!
Slick67's Avatar
^ Or have the axles redrilled for 5 lugs.
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline   Reply With Quote
Old 11-02-2009, 11:44 AM   #7
kev2809
low n' slo
kev2809's Avatar
bag it! that trucks looks like its in great condition
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 11-02-2009, 05:59 PM   #8
Shon
Cant wait to see where this truck ends up!!
THANKS!! for all your help with mine!
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
Old 11-02-2009, 08:44 PM   #9
-T-
-T-'s Avatar
Hey bro, post up some pics of the swap, ya know, to keep me motivated!!
I think i will look into just re drilling the shafts that i have now or change the rearend to a later model disc brake rear and just cut the perches off of the 6 lug rear and weld them onto the new one. If you can't tell, I like a project!!
Old 11-02-2009, 08:59 PM   #10
Shon
like this one
Old 11-02-2009, 09:53 PM   #11
-T-
-T-'s Avatar
well, i guess that will do for now!! LOL Now lets see some real pics, burnouts, something. I didn't take it to the exhaust shop today for you to pull it back into the garage
Old 11-02-2009, 10:53 PM   #12
Shon
that's where it sits
Old 11-04-2009, 08:58 PM   #13
-T-
-T-'s Avatar
Its on, I ordered my rims and tires today and should have them on by friday Should have some pics of the wheels tomorrow and pics of them on the truck Fri. We have a small carshow to go to in Greer on sat. Its amazing what you will make yourself do for one show!!! Hoping that the 22's fit in the rear and the 20" up front Trying to decide on the motor swap now. I have done half a dozen 5.3 swaps, so I'm leaning that way with a 700R4 behind it. Any thoughts?
Old 11-06-2009, 12:43 AM   #14
-T-
-T-'s Avatar
so, i got the rims today!! No pics though. Will get some tomorrow!! Swapped rear ends out of my parts truck to get my 5 lug, and everything doesn't exactly 'swap' between the years. Brake lines aren't the same, drive shaft isn't the same, but hey, the rims did bolt on and thats a plus. I am trying to make a small car show on sat. and still have all that to do on the rear plus swapping everything for the front. We will see if it all comes together.
Old 11-08-2009, 10:30 AM   #15
-T-
-T-'s Avatar
I got the 5 lug swap complete within my 2 day dead line. Lets just say that my back was killing me from working on it on jack stands None the less, its done and I got it together in time to drive to the car show Sat afternoon. Not before I had to take die grinder to my brand new rims The bore size on the front was too small, and there was an 1/8" lip on the inside of the rim that had to be removed. Anyway, we all made it and here are a few pics.
Old 11-08-2009, 10:33 AM   #16
-T-
-T-'s Avatar
and a few more
Old 11-19-2009, 08:33 PM   #17
-T-
-T-'s Avatar
I have made some progress in the last few days. Not being able to work has helped alot I sold the old motor last sunday, picked the 6.0/4L80 on Monday. I got it stripped Monday night and all cleaned up on Tues. Thats when things slowed down. There were 2 manifold bolts broke off flush in the head...got one out...not the other. So, i pulled the head and took it to the local machine shop and it is now out Unfortunately, in this case, noone stocks 1 head gasket for a 6.0. Guess that means that there aren't too many of these blowing head gaskets, which is good for the future. I will have the head gasket and bolts Friday morning and should have the motor back together this weekend. Motor mount/trans mount should be here Fri or monday.
Old 11-19-2009, 10:26 PM   #18
Shon
looking decent!
Old 11-30-2009, 11:00 PM   #19
chevy88
chevy88's Avatar
What is your truck lowered to on the front and back as the stance looks better than before?
Kerry
My build thread.
Old 11-30-2009, 11:06 PM   #20
-T-
-T-'s Avatar
well, before the rims and tires, the springs had been heated. I had gotten a set of lowering springs with the other truck that i had bought a while back. I don't really know what the drop is on the springs. I think that for the most part, it is about the same as before, but the rims fill up the wheel well a little better.
Old 12-02-2009, 04:31 PM   #21
*Dylan
Mean Buzzin' Half Dozen
*Dylan's Avatar
Looks great! Did you buy a 5-lug conversion kit from someone? If so, who did you get it from and did you have any problems installing it?
"War is an ugly thing, but not the ugliest of things. The decayed and degraded state of moral and patriotic feeling which thinks that nothing is worth war is much worse. The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself."
MY TRUCK (Now for sale)
1967 C10 SWB
Dylan
*Dylan is offline   Reply With Quote
Old 12-02-2009, 04:34 PM   #22
Shon
I believe he used parts from the other truck he has that had the 5lug stuff-stock.
Old 01-23-2010, 10:19 AM   #23
chevy88
chevy88's Avatar
How's the motor swap coming?
Kerry
My build thread.
Old 01-23-2010, 11:39 AM   #24
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Is she runnin yet??
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 01-23-2010, 11:59 AM   #25
Shon
Yep, and he has swapped from 4l80 to a 400. I got to do some 'stuff' in the tune since no VSS but that is pretty simple.
