Re: Lets see your gauge panel!
Here's mine.
Turning Wrenches Daily
Very nice!!!
Sean
Work! Play! Work work work! Money to play with. 64 GMC, 66 burb 4x4, and now 64 1ton money pits......ahhh life is good. Upcoming move back to Texas Dallas bound we are this september!!! 1964 GMC I1500 2wd (my baby) 8.1 allison 6 spd conversion Aka Smurf http://67-72chevytrucks.com/vboard/s...d.php?t=438342 2016 Ram Big Horn 4WD parts hauler 2010 Chevy HHR wife new car after the circled problem blew up!!! 1981 Ram D150 /6 auto Wife's sunday driver Living outside Gladewater Texas now working in Longview at the hospital there future project toys: 1966 Chevy K14 carryall aka Smurfette future project ![]() |
It's Better With Nitro
Turn signal circuit test:
Final gauge panel lighting test:
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
Robert that's suweeetttt!!!!!
Sean
This is the one redlineg.com restored for me. He converted the amp gauge to volts and installed a vacuum gauge and 6-cylinder tachometer.
#8 | |
Did you already have that cluster or did redline provide it? I have the "idiot-light" cluster in my '63, and really want to upgrade to the factory style gauge cluster like yours...but having a hard time finding one. |
#9 | |
If you add the search to your Saved Search List on e-bay it will email you when one is listed. You should be able to get one for about $100 if your patience. |
Ken,
Thanks for the info....out of sheer morbid curiosity...what did you search for on ebay? Seems like I can never quite get the search words right for what I'm looking for. Last edited by lonestar308; 08-09-2018 at 11:07 AM. Reason: typo |
#11 | |
If you copy and paste that it will bring up the ones that use 1963 in the description. I would also change the 3 to a 2 and then 1 and then 0. and do a search on each incase someone pulled it from one of those years and only listed it that way. You can also click on SOLD Items to see what has been listed and sold in the last few months. I just looked and there is nothing right now but two or three were sold for around $100 in the last few months. There was one that went for $45 with the shipping. Don't forget to save the search and let it email you when something new is listed |
Just finished installing mine. In process of making a wiring harness for it.
Thanks Ken!
I'll try that and see what turns up. |
I went back and redid my gmc cluster much happier with it now lol
#15 |
Mine is mostly stock....
#16 |
my 66
Denver/Big Island -- Instagram: Slammed66c10 '46 Fleetmaster Coupe '64 C10 on Ridetech Air Ride '66 C10 on GSI Bagged Chassis - in progress '12 FLHR '11 Custom Homebuilt Chop/Softail |
#17 |
#18 |
![]() Join Date: Oct 2013
Here's the one from my dads 64 LWB C10.
This is after I "Freshened it up".
1972 C/10 LWB - Mine 1964 C/10 LWB - My Dad's Instagram: Mike_The_Grad |
#19 |
These were in the 65 I recently picked up.
#20 |
Looks old but white instead of black. Any info or is it aftermarket?
#21 |
changed up mine made a little morebetter
#22 |
60-66 Nut
That looks nice! The colors go well together.
#23 |
definitely a sweet setup sir. currently getting an am/fm/gps antenna for my truck to combine everything into one with my speedhut gauges
![]() ![]() Sean
#24 |
Here is the one I did for my truck months ago...almost ready to install it. Also with LEDs...
#25 |
Never Ending Projects
Here is my Dakota Digital installed
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
