LFD's upper door seal idea!
Ok so we all have out pet peeves and one of mine is wind noise when I am driving my truck. So for some time now I have been looking into ways to quiet things down and I have found (like a lot of you have I'm sure) that with our truck doors set so they line up with the body correct they still don't seal the best. Most people say well it's just an old truck what do you expect! Well what I expect is to find a better way that works and is an easy fix. In the past I have gone in and re-worked the inner jambs of the doors to allow a better fit but it is still a gamble to get it just right by adding metal to the steps in the jam to put just enough psi in the right areas but not too much so it causes the doors to shut hard or the alignment to be pushed out. I have also tried different door seals from different years and models with some success but I think I finally got it!
I have been dealing with different rubber company's over the years for different builds and finally found some profiles that worked real well and are self adhered so install is a 10 minute job. So now the only wind noise I have is the slight sound as the wind travels over the vent windows. So basically what I noticed is the main wind noise is coming from the wind hitting the front edge of the window jamb and the rear edge where the drip rail comes down. The wind hits these areas and is forced into the jamb were it blows past or into the door seal. I have also noticed on all the newer cars on the market they all have a double door seal. The main one goes all the way around the door like our trucks have but the second one is just around the window jamb area. So this got me looking into different ways to deal with this and here it is. With just the right profile of seals I have installed one on the door and a different profile on the jamb so they seal up the gaps and add a second line of defense to help minimize or eliminate the wind noise in this area. So my question to all of you is this something you would like to see in a simple kit with the right profiles and pre cut to do both doors? For the profiles and density of the seals I bought it was around $85 because when you buy it is small quantities the price is much more per foot. So what I am thinking about doing is contacting the manufacturer of this certain brand of seal and see if I can buy in bulk through my business license. I would hope to be able to get it down to about $65 per kit (enough for two doors) shipped. I personally think it has a nice factory newer car look and at 75 mph it sure made things quiet and I have a lot of money in sound mat and zero rattles in my truck so it easy to hear the difference! PayPal is set up and ready for ordering just click here or the link in my sig! Shipping is roughly 3 weeks from 11-18-09 for this batch of orders. $65 delivered for 2 truck doors. Suburban link is in the bottom of my Sig. $90 for burbs delivered and this will do both front doors and the 3rd door. Everything is pre-cut for each door. Kevin LFD Inc. [IMG] ![]() [IMG] ![]() Last edited by Rokcrln; 11-19-2009 at 10:12 PM. |
![]() Join Date: Apr 2005
Re: LFD's upper door seal idea!
I'll let you know as soon as I can see the pictures (stupid firewalls...),
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
I would be intersted in this kit. Would it just include the upper seals in the picture or a full kit including the original style seal as well?
67cheby
![]() Join Date: Sep 2008
is it self adhevsive ?? if so it sounds like a no brainer to me 55 for a more quite ride, what brand door seals have you found work best and what to glue them on with ??
I would be interested when the time comes for new door seals and I like the $65.00 price over the $85.00. If you find out the manufacturer isn't willing to work with you, could you post where you got them? I would like a good seal as well. both sets, please
Luv the Crewcabs
Look's to be 2 pc per door Install, So that would be a Total of 4 Strips per Kit, If So , I think the Price point is Right on................
As Alway's, Many Thanks for making the 67-72 Line all that it Can Be....... Rick
55 Nomad 52 Willys Truck 67 Stepper 67 Fleet 68 Wrecker 68 Suburban 76 Crewcab 79 Gmc Dumptruck 84 Blazer 86 Crewcab Stepside 87 Iroc 89 GMC Plow Truck 91 Camaro Vert 96 Z71 Stepsde |
I have been thinking of the same thing. You are just making it like a newer car?truck.. double sealed. looks good, 65 not a bad price.
This kit would just be the 4 piece kit that does the upper door and jamb. I believe the dealer who I got this from my offer the factory door seal but you can get that from several of the site venders already.
Yes it is a peal and stick (very good adhesive) and it is just the right size to fit the contours of the window rail around the door and the jamb. I have been looking and trying different set ups since before LowBuck was painted so it so it has not been a simple thing to get it just right. I have some more testing to do but things look good so far. Kevin LFD Inc. |
Count me in for a kit!
very nice. price is right on as well. i will be needing some seals soon myself so if you need to get a list together put me down for a set.
69 4wd V6 20k orig miles!! ![]() 05 ccsb 2wd Diesel 500hp bagged and soon to be stock floored. ![]() 01 rcsb chevy 2wd 6bt cummins :devil:> build xtremediesel.com |
![]() ![]() Join Date: Dec 1999
Will it be sold per foot? Or as a per vehicle kit? I have a 69 burb that is noisy as heck.
2008 Chevy HHR 1/2 panel. 1949 Chevy Panel truck(just sittin, waiting) Board member #6 |
#12 | |
![]() Kevin LFD inc. Last edited by Rokcrln; 11-16-2009 at 06:50 PM. |
![]() Join Date: Nov 2004
...interesting...
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
6>8 Plugless........
![]() Join Date: Sep 2007
This is a great idea. I have tried something like this in the past but like you said, I could never get the wind noise eliminated. Count me in on a set.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#15 |
Great idea and improvement....count me in
#16 |
pics of door closed, or can you not see it when the door is closed?
instrested, non the less tho |
#17 |
Well, Whoop-dee-do!
![]() Join Date: Mar 2003
Cool. I might have to try that on my '68 when I can afford it. My '72 is soo much quieter... because of the squared off hood.
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD ![]() '72 K20 500 Cad/TH400/NP205 SOLD ![]() '92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver '72 Monte Carlo... sweet low mile toy '11 Dodge Challenger IE 392 6spd... midlife car ![]() |
#18 |
We sell all kinds of auto moulding styles in bulk if interested in 50 or 100 for rolls. Just in case your mfg. does not want to knock the price down low enough. Pm us for wholesale price if you want to
#19 |
Well, Whoop-dee-do!
You know, now that I look at your pic with the piece of weatherstripping on the seat, I think we have that at work. If it is the same stuff, we buy it in rediculously huge quantities. I'll grab a piece tomorrow so you can see if it is the same stuff. If it is, I might be able to get it crazy cheap!
#20 |
Fat Fendered Fleetside
Kevin, this is a great idea.
Years ago, I tried a number of different profiles to make that '2nd seal' around the door like you did. I also got the idea from newer vehicles, they almost all have 2 sets of weather stripping. I think a kit with the right length and dimensions would be a great idea! |M| |
#21 |
Restoring it $200 at a time...
Another interested party.
Charter member of the 'Put the dimmer switch back on the damn floor where it belongs' Society '68 5.3L-4 speed LWB C20; grandpa bought it for the farm in '71. Now LS 5.3, rather than 327. DD '09 Pilot Weekender '65 Skylark 300-4V-4 speed Wife's '07 Lexus ES350; 117 actuator motors and I can't see the engine. Son's '04 F250 SuperCab 6.0 |
#22 |
I Like Mine With No Shine!
![]() Join Date: Apr 2009
Sounds like a good idea and a good deal to me. Would it be beneficial to make the extra seals go all the way around the door and all the way around the door frame of the cab...or is it over kill? Just curious.
Michael ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/c...ct=4578&cat=17 ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=384152 |
#23 |
i'm in!
R.I.P. Killer 71 10/26/07 |
#24 | ||||
Kevin LFD Inc. |
#25 |
Trucks N Tranzams
I am in for a set.
![]() '68 Chevy LB 383 TH400/GV/373 posi '56 Chevy 4WD SWB '64 Chevy short stepside '79 Trans Am 455/TH2004R/12blt/4whldisc 95 Kia (Wifes car) 2002 S-10 extended cab pickup "God punishes small sins immediately" |
