12-04-2009, 01:45 AM | #1 |
Size Matters
Code Blue! She's down! 911!
Well I went to get the Christmas tree tonight and made it about 1/2 mile from the house when the motor made this funny noise and that was all she wrote. My best guess is that the timing chain slipped. It was running good and then it wasn't running at all. The carb still squirts fuel and there is still spark at the wires. That funny noise is what makes me think timing chain. At least I wasn't far from home. My neigbor pulled me home so she is back in the yard. Looks like the engine rebuild is gonna happen sooner rather than later.
"Reading the owners manual is only for quitters." Jason Harper, Bloomberg News. ...WOOOO HOOOO!!!! |
12-04-2009, 02:17 AM | #2 |
Re: Code Blue! She's down! 911!
take off your dist cap and see if the cap is turning when you crank it.. it turns while your cranking it, its NOT the timing chain...
12-04-2009, 03:44 AM | #3 |
70 Chevrolet=Obsession
Megabummer!
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke! IT'S NOT EASY BEING GREEN! -Kermit the frog 1970 Chevrolet C-10 Longbed Stepside : 350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes) 1996 Toyota Corolla (Parts runner) |
12-04-2009, 04:48 AM | #4 |
Old member
Man Dewayne that stinks. If you need anything hollar.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 12-04-2009 at 05:01 AM. |
12-04-2009, 10:32 AM | #5 |
Size Matters
I did take the dizzy cap off and it is turning. I also mentioned that I am getting spark. Yeah, I know the chain is not broken but I think it may have slipped.
12-04-2009, 11:15 AM | #6 |
...just another truck junkie..
Did you experience a massive power loss at the same time as the noise right before it quit? I had a similar thing happen on a '68 I had, the chain slipped and I had a power loss and then it died for good.
Mike "Bear" Shea |
12-04-2009, 11:21 AM | #7 |
Size Matters
Yes/No? No noticable power loss prior to BIG power loss when it shut off. It was like it was pulling and then it wasn't pulling (coasting) and there was this ratcheting noise that sorta wound down and then quit. Cranking sounds normal, dizzy turns, the one rocker I can see via the oil filler is moving.
12-04-2009, 11:51 AM | #8 |
That was kind of what I meant. When the chain slipped on my '68 it instantly acted like you put it in neutral until the engine finally quit a few seconds later. It was the same experience, fuel good, spark present, cranking sounded normal, but it wouldn't fire. I think you may be right on the chain having slipped.
Mike "Bear" Shea |
12-04-2009, 11:52 AM | #9 |
thats a serious mind-bender. you'l have to let us know what it is when you get it apart. if it slipped and the locked up again it wouldn't run but it would spin everything normally just out-of-time....
- Jason If you can turn, Youre not going fast enough. Favorite caption: first car to 200 mph in the 1/4 mile, no parachute, drum brakes all the way around.. ..back when men were men. |
12-04-2009, 11:55 AM | #10 | |
Size Matters
12-04-2009, 12:15 PM | #11 |
The engine was warmed up and I was accelerating up to highway speed. Medium acceleration, not getting on it, and it just went kaput.
Mike "Bear" Shea |
12-04-2009, 12:19 PM | #12 |
Size Matters
OK, Thanks.
12-04-2009, 01:30 PM | #13 |
Here's a frightening story: About 5 years ago, I was hauling a Christmas tree to my buddy's house. The original engine was still in the truck and one lifter had been making some hellacious noise. What better time to DRAG RACE MY BUDDY up to about 95 MPH!! Believe it or not, it didn't blow up. BUT! When I left his house, the last thing he said is, "Well, if it blows up, at least it mostly downhill back to your house!" 3 blocks later, I turned onto the onramp, started accelerating, and CLANG CLANG BOOM BACKFIRE BANG BANG... and a RAINBOW of smoke came out both pipes...
The lifter/push rod broke, valve into the piston, piston into the cylinder wall, then pushed the valve back into the head... It was AWESOME! |
12-04-2009, 01:36 PM | #14 |
That sucks Dwayne.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
12-04-2009, 01:45 PM | #15 | |
Size Matters
12-04-2009, 07:57 PM | #16 |
hmm.. run #1 up on TDC and pop the valve cover to see if there is a valve open that shouldnt be???
if it jumped time. would you be able to see it if it was only a tooth or two out? just tryin to help. |
12-05-2009, 12:11 AM | #17 |
Every time I have removed a t-chain cover have found a fiber material gear - maybe plastic - so this must have been OE on SBs - and maybe BBs. So, I always replace with a steel gear. Have heard that the fiber gears eventually wear/break and that a problem like yours may occur. If so, and the chain slipped a couple of teeth or even if the gear stated to disintegrate, it may not be a disaster - as long as it did not do any off-time pushing of valve rods, etc. I would do the TDC check with #1 valves as noted by someone here - that should tell if it is in the chain/cam/valve train. If it is, the job is not too bad (if it is not a cam issue) - radiator out, fan and belts off, puller for the balancer. Be sure to use a new seal in the pan. Good luck,
CCCC
CCCC 67 Sting Ray Coupe 327 4sp; 68 K10 Suburban 327 4sp; 69 K20 Lifted 383 4sp; 69 C80 Fire Truck 478 V6 5sp/2sp; 69 C20 Longhorn 327 4sp; 70 C30 Wrecker 350 4sp; 70 C30 Flat Bed 350 4sp; 71 C20 LWB 350 4sp; 72 K5 Blazer 350 4sp; 72 C30 Flat Bed Gooseneck Hauler with sleeper 350/TH400; 72 C20 Longhorn 402 4sp; 52 Mack LTL Supercharged Cummins 5sp x 3sp; 01 Dodge 5.9 HO Cummins 6spd; 02 Safari Trek 2430 8.1 Vortec on Workhorse Chassis; 03 Silverado 2500 HD 4wd Duramax/Allison Moved but still in the family 70 C20 Custom Camper 350/TH350; 72 K5 Blazer CST Highlander 350/TH350 Recently sent to new homes 72 C30 MoHome 402 4sp; 72 K5 Blazer Conv 350 4sp; 75 GMC 6000 Aerial 350 w Allison; 72 GMC 3500 Utility 350 4sp; 70 GMC 3500, 350 4sp |
12-05-2009, 12:16 AM | #18 |
next thing is do a compression test of all cylinders. Take your plugs out and get a free tester from Auto Zone or something... Do you have HEI or standard ign? If it is something in your valvetrain, like a broken rocker it would still start but you would hear a bad sound... It should start on seven cylinders, just wont sound good.... did you check all plugs for fire or just 1 or 2? Sounds like a broken crank to me...
12-05-2009, 12:30 AM | #19 |
There's no way it's a broken crank if the distributor is still turning.
12-05-2009, 12:39 AM | #20 |
12-05-2009, 12:49 AM | #21 |
Dwayne, are you planning on an actual rebuild, or crate engine? Is it a 350? Just curious.
12-05-2009, 01:40 AM | #22 | |
I would pull the timing chain cover before I pulled the engine out though. There is a mark on each timing gear. If they line up then the chain did not jump (the mark on the crank gear will be at the top while the mark on the cam gear is at the bottom). They have to line up dead center though. |
12-05-2009, 03:09 AM | #23 |
That just happened to me this fall as I was going to put it away for winter in the shed. It was idling and then it just suddenly stopped like right now.
Has spark, blows fuel back up the carb like yours too, sounds "different" when cranking it over, won't pop off or run. Me thinks timing chain too. Disgusted we pushed it in the shed and I'll deal with it in the spring. Just got done putting in new radiator and water pump. Ugh. If you get to yours, please post what you find. Thanks.
72 Chev C-10 90% restored (former AZ truck) ... 71 Chev K-20 Cheyenne my vacation crusier... 72 Chev C-10 Now retired and striped after many faithful miles... 72 GMC 1500 Retired to the junk yard after bought new in '71... |
12-05-2009, 06:03 AM | #24 |
RIP Mr Ron
Sorry to hear that Dwayne. Hope it is a simple fix so you can keep driving that Longhorn.
Ron (Mr Round Tuit) Be kinder than necessary, for everyone you meet is fighting some kind of battle TN Message Forum TN Facebook Group SETN Truck Show My Photobucket |
12-07-2009, 01:05 AM | #25 | ||||
Size Matters
Yep. I hope it's simple too but I think it's gonna wind up being a rebuild cuz it's smoking anyway.
