12-27-2009, 10:37 PM | #1 |
low n' slo
What are you guys using to cut frames?
just wondering. i dont have a plasma, and dont plan on getting one. i was looking at a sawzall i found on craigslist for cheap. its a ryobi rj160v. i was wondering if it should work well. i dont have a shop so im not looking at going to spend a 100 bucks on a Milwaukee..this one is for 35 and i might be able to get it cheaper. im gonna use it to cut my floor out and later down the road if i need to cut my frame.
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
12-27-2009, 10:45 PM | #2 |
Re: What are you guys using to cut frames?
I would use an electric grinder with a cut off wheel. That is what I used to replace all the rust on my cab along with a die grinder.
07 Chevy classic LBZ Duramax (a few mods) '67 Chevy 1/2 ton 2wd (in pieces) '69 Chevy 1/2 ton 2wd (on hold) '71 GMC 3/4 ton 4x4 ‘71 GMC 1/2 ton 2wd suburban |
12-27-2009, 10:48 PM | #3 |
i agree with 67, a electric grinder like a makita with a cutting wheel, just make sure to invest a little into one, you get what you pay for as i always say. and make sure to buy a couple of cutting wheels
12-27-2009, 10:49 PM | #4 |
low n' slo
ive been using a cut off wheel and my grinder for the body, but the frame is waaaaaaay thicker lol. i need something different for this
12-27-2009, 10:50 PM | #5 |
low n' slo
so a cutoff wheel on my grinder is gonna cut it better and faster than a sawzall?
12-27-2009, 10:51 PM | #6 |
Look on craigs list for used/new tools. Lots of good deals out there! Sawsall and 4.5" grinder will be your best friend
12-27-2009, 10:57 PM | #7 |
THE TOY STORE
torch!!!!!!!!!!!!!! best tool in my shop. a million uses
having a badass truck and not driving it is like having a playboy model as a wife and not..... well you know. |
12-27-2009, 10:57 PM | #8 |
low n' slo
lol...a torch doesnt cut good lines though do they? this is something that it is getting cut then welded back together.
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] Last edited by kev2809; 12-27-2009 at 10:58 PM. |
12-27-2009, 11:26 PM | #9 |
THE TOY STORE
just takes practice to get good strait lines. or you can clamp a piece of metal along were u wanna cut and use as a guide. plus all it takes is a quick pass with a grinder to clean up a little slag. alot quicker and economical than burning through disks and sawzall blades.
12-27-2009, 11:47 PM | #10 |
TNT-MOTORSPORTS
I have cut a lot of frame pieces with a milwaukee saw like what you are asking about and have had good results
12-27-2009, 11:57 PM | #11 |
One day...
The only problem with a sawzall it its hard to get the lines perfect, but if your just hacking something off then it works great. A 4 1/2 grinder with a cutoff wheel blade works really good just dont let it bind up or the blade will come apart.
12-28-2009, 12:12 AM | #12 |
low n' slo
well its for a z later if i try it. now its just to cut off my floor
12-28-2009, 12:19 AM | #13 |
"something witty here"
I would go with a grinder as well, I would think a sawzall would be brutal for cutting body panels. And a small cut wheel on the grinder will cut through that frame like a hot knife through butter.
57 chevy 4x4 70 swb fleetside 4x4 68 burb 2wd: 71 burb 2wd: 350 4spd 71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear 72 lwb fleetside Cheyenne 454/th400 1991 GMC V3500 CC 4x4 |
12-28-2009, 12:33 AM | #14 |
If you already own a grinder then it would be cheaper to invest in a few cut off wheels. If you buy a sawz all then you will also need to buy some blades for it.
12-28-2009, 12:49 AM | #15 |
low n' slo
true. man that's odd. so what's the point of anyone using a sawzall over a grinder? I always thought the sawzall was the ideal tool for this...guess not.
12-28-2009, 01:16 AM | #16 |
dont get me wrong I use my sawzall all the time, for those tricky bolts that my grinder cant get to and other nameless jobs lol
12-28-2009, 01:38 AM | #17 |
same here... have had them come apart not fun.
[PROJECT] FnLow69- 69 C-10 Full frame & layin' doors [PROJECT] Laidout53 - 53' Dodge Pickup, Full Kustom Build [PROJECT] "Hot Rod" 1931 Model A Bonneville style "Dream as if you'll live forever, Live as if you'll die today" ~ James Dean |
12-28-2009, 01:46 AM | #18 |
Happy to be here
If your going to buy a Sawzall I suggest a battery powered unit. I have an 18v DeWalt that does a great job. It has tons of uses with the proper blade. I find it really handy for pruning trees.
12-28-2009, 09:00 AM | #19 | |
One day...
very true plus you can take it to a pull-a-part too |
12-28-2009, 11:26 AM | #20 | |
12-28-2009, 12:17 PM | #21 |
i use Zip cut cut off wheels with nice results.
Trueman |
12-28-2009, 12:44 PM | #22 |
low n' slo
well, i guess i can get a sawzall another time...time to buy some cutoff wheels now. are they gonna be big enough to cut through a suburban floor too?
12-28-2009, 01:29 PM | #23 |
Happy to be here
You know you can put a tile blade in your circular saw don't you? That works great for cutting large areas like your floor. You will need a smaller saw for the tight spots.
12-28-2009, 01:31 PM | #24 |
Happy to be here
I use a very aggressive blade to trim my palm trees. It's like giving a cat a bath if you use a hand saw or pruning loppers. My DeWalt cuts them like butter.
12-28-2009, 01:35 PM | #25 |
low n' slo
"your" circular saw? i dont have one of those either lol. man oh man i need to start getting some more tools instead of buying parts lol
