01-11-2010, 12:44 PM | #1 |
My side marker light fuel filler idea
I've been working off and on trying to figure out a cool, but fairly simple fuel filler modification for my under the bed gas tank. I've read a lot of threads on different ways to do this and have seen some really cool stuff that people have come up with, including in the bed, tail light and side marker light. While most the ones I have seen are very functional, most of them require modifications that involve cutting and welding on the bed. Since my truck is already painted and the bed has been linered, I gave myself some pretty tight parameters on what I wanted to create, such as:
1. It should be a fairly simple mod that most people could accomplish with minimal skill and tools. 2. It should be bolt on and use the existing holes. 3. Absolutely NO cutting, welding or drilling would be done on the bed. 4. It should not take away from the lines of the truck. 5. And lastly, it needed to be fairly cheap. Well, here's what I came up with. I still have to do some fine tuning, but I'm very happy with how it's turning out. Once I go smooth with it, I'll probably do a write up on the install. What da ya think???? Parts: Cabinet hinge (home depot part #H1068C-UC-C5) Piece of 4" x 1 3/4" eighth inch steel (requires two 1" bends to form a "C") super glue side maker light marine fuel filler cap - http://www.westmarine.com/ http://www.westmarine.com/whitecap--..._209_001_500** Quote: Originally Posted by 0331grunt I like the idea. More pics? Info? Keep the ideas coming!! I'll post more once I get it fine tuned. Quote: Originally Posted by oldblue1968chevy do you have to do any kind of cutting to inside of bed.....willl gas pump fit in there even lol? looks clean do a faq asap! None, nope, nada, Zilch!! It fills up great. Quote: Originally Posted by big_al_71 Rob, that looks like a hinge from a kitchen cabinet, Is it? Probably so. I was walking down an aisle at Home Depot and picked it up. Quote: Originally Posted by sgaylord Nice set-up, I like the requirements and I'm definitely interested. I too have been thinking about something along these lines. I like all the mods I have seen (in bed, tail light, stake pocket, and marker light). I have been leaning towards the stake pocket or marker light. Some of the tail light mods I have seen look like they need more rigidity or the light could open going down the road. I can't do the bed floor because like yours my bed has a liner. How flimsy is the marker light when you open it to add gas? Are you using a cap that does not need to be removed to fill the tank? I think you would almost have to. It's not flimsy at all. It has a very strong spring coupled with an "over-center" mechanism, which spring loads the open and closed positions. They way my setup is designed, you have to glue in the screw for the front hole, but on the rear hole you have the option of gluing it in OR you can put the screw into it's original keeper. Either way, it's not coming open. Screwing it in the orignal keeper will also prevent anyone from messing with it. As far as the filler neck and cap, I'm using the boat filler gas cap that has a spring loaded "handle". It's tight, but very easy to take off and on. I don't think they make a gas cap like you are talking about that will fit down in the hole (there's only a little over 2" to work with). I added a picture of the cap I'm using. __________________
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 04-09-2014 at 03:27 PM. |
01-11-2010, 12:53 PM | #2 |
Re: My side marker light fuel filler idea
Looks pretty cool. I can't wait for the full write-up.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
01-11-2010, 12:58 PM | #3 |
Restoration Virgin!
Great Idea Rob.....subscribed!
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
01-11-2010, 01:00 PM | #4 |
Moderator
Looks great Rob! Only problem is you can't get a filler hose in there if you live in a state where there are large rubber boots on the end. Otherwise, that's the way to go....minimal parts needed, no cutting required
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
01-11-2010, 10:56 PM | #5 |
I still have some more pictures to take. I also want to do a video of the fill.
Thanks! Do you have a picture of the gas nozzle you're talking about? Any measurements?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
01-11-2010, 11:00 PM | #6 |
thats a great job Rob!!!!
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
01-11-2010, 11:12 PM | #7 |
looks sweet
1972 SWB Medium Olive South Houston Instagram: Antbish84 |
01-11-2010, 11:17 PM | #8 |
Grandpa in the rustmobile...
looks sweet! what did u do for a filler hose? gas tank to cap
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
01-11-2010, 11:22 PM | #9 |
Thanks!
Thanks! I had an exhaust shop bend me a piece of 1 3/4" of pipe. I still need to weld a couple of tabs on to permanently mount it to the bed.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 01-11-2010 at 11:23 PM. |
01-11-2010, 11:29 PM | #10 | |
The One And Only !!!
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
01-11-2010, 11:56 PM | #11 |
Under Construction
I believe they are talking more along these lines, the pump has the boot, it recycles the fumes for better greenhouse effects, and if not depressed will not dispense fuel, of course you can manually depress the boot, and fill , but it may be a tight spot on the marker light ...
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
01-12-2010, 02:57 AM | #12 | ||
Moderator
01-12-2010, 03:42 AM | #13 |
Great idea! Although from the litteral sense with just the bare mechanics of it...it is a bit of a pain in the neck. I have seen this mod done up close and personal and the angle is just super tight to get the nozzle in there with out mareing up the paint in some form or fashion. The ones I have seen completed used a modified gas door of of a S10. I wonder how well the cabinet hinge would work on the tail light? Might be able to get a better approach possibly.
- 1967 Chevy C10 shortbox - 1984 Chevy K10 "Mater"- SWB 305 manual, retired sheriffs truck, Current Frame Off Project - 1986 Chevy K10 LWB 350/350 Daily Driver/project |
01-12-2010, 05:55 AM | #14 |
Im watching this one. Looks good.
01-12-2010, 09:12 AM | #15 |
I have seen a plastic gas cap that has a hole just big enough for the nozzle and does not have to be taken off to be filled. The hole has a sping loaded closure that closes everything up tight when you remove the hose. Might work good in tight places.
01-12-2010, 09:27 AM | #16 |
Here is a picture of one from the Moultrie swap meet last November. Not very detailed picture though.
How 'Bout them Dawgs! '10 Traverse LTZ 03 Silverado Z71 ext cab 99 Yamaha Grizzly 600 72 C10 350/350 sportside bed. 68 C30 flatbed. 350 4-speed. "I've got a good memory, it's just short!" |
01-12-2010, 10:34 AM | #17 |
I like that!!!!
No specs on the bends by chance?
01-12-2010, 10:43 AM | #18 |
"THE GREEN GOBLIN"
I don't know about this one looks like it would scratch up the paint with time if you are not very very careful. Just like some door key holes that get scratched up with time after a while. Looks good though...
Petey-pablo
"THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi Sold Drive it like you stole it! Petey-pablo@sbcglobal.net |
01-12-2010, 01:18 PM | #19 | |||||
Thanks. Quote:
Two 1" bends front each end to form a "C". You want to leave approximately 2" in the middle. The middle dimension should equal the depth of the tail light pocket. I initially used an "L" bracket, but decided to go with the "C" bracket to add more support to the mounting point. Are you saying it would get scratched from the light or the fuel nozzle?
01-14-2010, 11:26 PM | #20 |
Not a bad nut after all..
Nice work!
'05 Chevy 2500HD 4x4 '72 GMC LWB 4x2 driver '72 Chevy LWB 4x4 plow truck '71 Blazer 4x4 driver '70 GMC LWB trailer |
01-18-2010, 10:05 PM | #21 |
I love it! I was wondering what you did about venting the system and it appears that the link doesn't work.
01-19-2010, 02:23 AM | #22 |
sub.
1950 Chevy 1500 1961 C-10 1969 C-10 1971 Chevelle 2008 Dodge HD3500 Tow Rig |
01-19-2010, 11:42 AM | #23 |
Looks great Rob!
Wynne 70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s. Build thread 53 Chevy shortbed 69 Camaro Click here to subscribe Chevy GMC International Truck Club Louisiana Charter Member http://www.louisianaclassictruckclub.com |
01-24-2010, 11:43 PM | #24 |
Here guys this is what I did with mine:
1972 Chevy C10 SWB 1999 GMC Sonoma Mini 2008 Yamaha R1 2007 Harley Nightster |
01-25-2010, 02:05 AM | #25 |
I like this one, However in oregon your not allowed to fill your own vehicle so allowing some minimum wage bone head that will sooner or later ding the side of my truck I think I will take part of this idea and try to figure out how to make it go behind the tail light where there is less chance he/she will hit the quarter panel.
Nice work though!
There are two kinds of people, those who finish what they start and so on. 70 GMC Longhorn (A.K.A Money Bucket) 57 Chev 3100 05 Chevy LLY Dmax. 67 Chevy Camaro Dad's Budget Build 55 My Longhorn Build |
