Old 01-12-2010, 06:30 PM   #1
76gmc
76gmc's Avatar
76 GMC build
project "old yeller"
here's a few photos of my truck. I dont have many photos of what I have done yet. but I will get some.
the truck is a 76 2 wheel drive short bed. 350 with th350 trans.
the old truck looks solid in the first photo but it's not rotten floors, rockers, cab coners, fenders, inner fender, etc. all of these are about the same.
I have new doors, fenders, inner fenders, 2 1/2 cowl hood, and bed, well used bed.
here's a few of the rear end before and after.
76gmc is offline   Reply With Quote
Old 01-12-2010, 06:37 PM   #2
76gmc
76gmc's Avatar
Re: 76 GMC build
few more photos of the rear end
and coresupport before and after
and a few of engine and trans before
Old 01-12-2010, 06:54 PM   #3
76gmc
76gmc's Avatar
Re: 76 GMC build
and a photo of the trans before paint after rebuild
engine is being built by Jody Ridley the 6 time all pro champion and 1980 NASCAR rookie of the year. engine should be ready in a week or 2.
and a few of the frame before paint ,
Old 01-12-2010, 06:57 PM   #4
76gmc
76gmc's Avatar
Re: 76 GMC build
I know these photos dont show alot , i will get some of the frame paint in a few days.
Old 01-13-2010, 06:43 PM   #5
Conundrum
Conundrum's Avatar
Re: 76 GMC build
Nice project, looks good. Are you going with a stockish build?
I am also a fan of the GMCs!
74 GMC SWB Project "Sin-thia" Static Dropped 8"f/10"r
http://67-72chevytrucks.com/vboard/s...d.php?t=460030
97 GMC reg cab short bed, 4.3V6 / 5spd, daily driver
220,000 miles, all stock for now
Conundrum is offline   Reply With Quote
Old 01-13-2010, 07:00 PM   #6
76gmc
76gmc's Avatar
Re: 76 GMC build
yes, just a stock rebuild. the only changes is the engine, but just the common changes made headers, intake, carb, cam, etc. It was my grandpaws truck so I'm building the truck in memory of him.
Old 01-31-2010, 07:05 PM   #7
76gmc
76gmc's Avatar
Re: 76 GMC build
heres a few more photos I found of the frame.
I had more with the engine and trans in the frame post I phone went crazy and I lost them. But I will get some more.
Old 01-31-2010, 07:09 PM   #8
76gmc
76gmc's Avatar
Re: 76 GMC build
more photos
Old 01-31-2010, 07:11 PM   #9
76gmc
76gmc's Avatar
Re: 76 GMC build
Old 01-31-2010, 07:18 PM   #10
76gmc
76gmc's Avatar
Re: 76 GMC build
here's a few more photos of other parts.
I looked for a year for a set of rally wheels 8 inch for my truck I found some saturday. there sandblasted and ready to paint.
let me know how you think me truck is going.
Old 01-31-2010, 07:21 PM   #11
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: 76 GMC build
Nice build!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 01-31-2010, 07:23 PM   #12
76gmc
76gmc's Avatar
Re: 76 GMC build
As you can see in the photos of the frame I had to sand the frame down to metal. Some one in the past sprayed undercoat on the frame, and that stuff was hard to get off.
the photo of the spring is before and after sand blasting.
I will udate with more photos this week thanks for looking hope every enjoys my post.
Old 01-31-2010, 07:25 PM   #13
76gmc
76gmc's Avatar
Re: 76 GMC build
thanks alot for the comment 72Blckbuty.
Old 02-01-2010, 07:47 AM   #14
Conundrum
Conundrum's Avatar
Re: 76 GMC build
Lookin good, keep it up!
Old 02-04-2010, 11:57 AM   #15
76gmc
76gmc's Avatar
Re: 76 GMC build
has anyone replaced the studs that's pressed in the crossmember, these studs holds the upper crossmember on. I got mine from LMC and they dont look correct. I can add photos this afternoon.
Thanks for any help.
Old 02-04-2010, 12:35 PM   #16
silvereagle07
silvereagle07's Avatar
Re: 76 GMC build
Nice build! How did you get that harness so clean? Alot of time invested I suppose.
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 02-04-2010, 12:52 PM   #17
76gmc
76gmc's Avatar
Re: 76 GMC build
took the harness 100% apart and clean and replaced what need to be replaced.
yes alot of time.
Old 02-04-2010, 04:08 PM   #18
jitteryguy
GoatLube Experss
jitteryguy's Avatar
Re: 76 GMC build
look'n good !
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 02-05-2010, 09:38 PM   #19
67-72crazy
67-72crazy's Avatar
Re: 76 GMC build
keep up the good work everything looks great.
1991 1500 longbed: my daily driver
1937 chevy 2dr sedan. dads project
67-72crazy is offline   Reply With Quote
Old 02-13-2010, 11:53 AM   #20
76gmc
76gmc's Avatar
Re: 76 GMC build
few more shots of the front end
Old 02-13-2010, 11:56 AM   #21
76gmc
76gmc's Avatar
Re: 76 GMC build
Old 02-13-2010, 11:59 AM   #22
76gmc
76gmc's Avatar
Re: 76 GMC build
a few photos of the engine parts, everything is new
Old 02-13-2010, 12:02 PM   #23
76gmc
76gmc's Avatar
Re: 76 GMC build
photos
Old 02-13-2010, 12:15 PM   #24
76gmc
76gmc's Avatar
Re: 76 GMC build
replaced all bushings in control arms , ball joints , tie rod ends , new motor mounts and trans mount. every bolt has been replaced with a grade 8 bolt. I did not paint the bolts but every bolt head and nut has been clear coated.
the motor should be done with in a week its getting all new parts
pistons flat top .030 over , new stock rods , found a 10 / 20 crank at advane auto ,
cam is a engine works cam 480 480 duration @ .050 231 /231
weiand intake square bore dual plane
Old 02-16-2010, 09:51 AM   #25
76gmc
76gmc's Avatar
Re: 76 GMC build
put some old wheels and tires on the frame so I can roll it around. now ready for engine and trans.
