Old 01-24-2010, 12:24 PM   #1
bigguy69
dazed and confused
bigguy69's Avatar
security question
I have noticed that it seems like were hearing about more of these trucks being stolen. i went out this moriningand noticed somebody had the hood up one of them at the house. man that mkes me mad. i was just wondering what you guys were doing for security? locking hoods. kill switches that sort of thing. just looking for ideas. thanks
members met: redbaron69, billsbowtie,nc67
bigguy69 is offline   Reply With Quote
Old 01-24-2010, 12:38 PM   #2
powell72
powell72's Avatar
Re: security question
I know this doesn't work for everyone, but when my truck is home, it's in the garage.
As far as kill switches, when I got my truck someone had mounted an on/off style toggle switch that was wired into the power wire for the HEI. Simple enough, cut wire, hook each end to the toggle, flip the switch, truck won't start.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 01-24-2010, 12:38 PM   #3
69halfton
69halfton's Avatar
a big dog and a shotgun
the most common thing I've hear of is ignition kill switches that are simply hidden under the dash. as for the hoods, if memory serves me, there is a kit to put a hood release inside the cab like a late model. chains are obviously the cheapest and quickest to install, however if you ever have to get under the hood really fast (like a fire or other catistrophic failure) you won't be alble to get under the hood. I keep mine in the garage so i dont hve to worry about even locking the doors at night...
- Jason
If you can turn, Youre not going fast enough.
Favorite caption:
first car to 200 mph in the 1/4 mile, no parachute, drum brakes all the way around..
..back when men were men.
69halfton is offline   Reply With Quote
Old 01-24-2010, 03:01 PM   #4
68gmsee
Active Member
68gmsee's Avatar
Install an anti theft device and a picture of your dog on the window with a warning that you will let him loose if anyone is caught messing with your truck in the driveway.
Also a hidden kill switch will work. I'd place it inside the truck where they would have to break the window and set off the alarm in order to steal the truck.
68gmsee is offline   Reply With Quote
Old 01-24-2010, 03:11 PM   #5
big_al_71
big_al_71's Avatar
I have a kill switch that it is so simple that even when I showed some of my guys they still could not figure it out where it was at.......
My truck never leaves my sight and it is garaged when not in use.
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 01-24-2010, 03:16 PM   #6
meyer4589
i've got a chapman lock on my truck right now
meyer4589 is offline   Reply With Quote
Old 01-24-2010, 04:17 PM   #7
bigguy69
dazed and confused
bigguy69's Avatar
i think i will use that picture 68gmsee!!!!
Old 01-24-2010, 05:07 PM   #8
americanmusc1e
americanmusc1e's Avatar
I have a cold-natured motor and a holley carburetor with no choke, the lack of most people's knowledge of starting carbureted vehicles is appalling, but it works in my favor.
in a worse case scenario, I remove my ground wire going from the engine to the battery, not many people carry a wire large enough to replace it.
-- Josh
Instagram: @americanmusc1e
OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread
FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread
1999 4wd OBS Tahoe - daily.
DM me if you can't see photos i posted
americanmusc1e is offline   Reply With Quote
Old 01-24-2010, 05:55 PM   #9
chipflyer
chipflyer's Avatar
I've had an idea, I want to add a relay to the ignition circuit. I want to add it to the hotwire between the ignition switch and distributor (HEI). I want to add a simple push button (hidden somewhere) that I have to push that excites the relay allowing current to flow from the switch to the HEI while I crank the engine. When the engine starts and I release the push button I need current to flow until the ignition switch is turned off. I think I need what they call a hold-in style relay, Anyone done anything similar? I want to avoid a simple toggle switch mainly because I figure it will get stolen the first time I forget to flip the switch. I don't know much about relays but I think they have one that works this way. Is it a silly idea? What am I missing?
Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen.
1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets!
1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241.
chipflyer is offline   Reply With Quote
Old 01-24-2010, 06:01 PM   #10
1971gmcshortbed
1971gmcshortbed's Avatar
I used to have the Grant no wheel no steal steering column hub on mine, still got it. I'll probably keep it on when I finish my project. You use a key to take the steering wheel off when you park.
1971gmcshortbed is offline   Reply With Quote
Old 01-24-2010, 06:10 PM   #11
chevy71super
I have removable steering wheel on both my trucks. I am convinced it has saved my daily driver from being stolen. Its been broken into and the hood popped a couple of times. Cheap insurance, about a $100 for the kit. Jegs carries them (Grant). Only draw back is it places the wheel about 2 inches closer to you so you want to use a wheel with a minimal amount of dish. Here is what it looks like on my blue truck with the wheel off.
Here it is with the wheel on:
71 Cheyenne Super 4X4 SB
72 Cheyenne Super 4X4 SB
72 Cheyenne 4X4 SB
chevy71super is offline   Reply With Quote
Old 01-24-2010, 06:45 PM   #12
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
So if you park the truck at a store and go inside what do u do with the steering wheel
John
1999 Toyota Tacoma 4x4
Old 01-24-2010, 07:14 PM   #13
chevy71super
Stick it under the seat. If I leave the truck for long time I use a cable and a lock to secure the wheel.
72 Cheyenne 4X4 SB
Old 01-24-2010, 08:08 PM   #14
1971gmcshortbed
I always carried it on my shoulder, good conversation starter.
Old 01-24-2010, 08:51 PM   #15
redbaron69
redbaron69's Avatar
hate to hear this josh, man thats too close to home!!!! they didnt take anything did they?
69 short fleet 350/350 "under construction"
70 short step 307/3 speed
redbaron69 is offline   Reply With Quote
Old 01-24-2010, 09:18 PM   #16
bigguy69
dazed and confused
bigguy69's Avatar
no nothing was gone,but i came in kind of late last night. i think all this rain kept them from being out ther to long. it justs makes me mad. you will have to make more room in your garage!
Old 01-24-2010, 09:40 PM   #17
tcb-1
Nothing to see here.....
tcb-1's Avatar
my truck has a SM465 tranny in it.
in other words, a thief isn't getting anywhere quick......
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 01-24-2010, 09:55 PM   #18
nbrfd007
nbrfd007's Avatar
That's the only problem with our rides, 6 foot of 12 gauge wire and the dip stick, gone in 60 seconds!
nbrfd007 is offline   Reply With Quote
Old 01-24-2010, 09:56 PM   #19
redbaron69
redbaron69's Avatar
ill see if i can make you a spot. but i may be tempted to "help myself" for some parts on my build no man you got some nice rides,if it would have been my truck, they probaly would have felt sorry for me and and left some cash or something
Old 01-24-2010, 10:15 PM   #20
Sammy
Simple kill switch even just unplugging the HEI wire from the fuse box has to deter a thief somewhat.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 01-24-2010, 10:27 PM   #21
jrdz2120
Sorry to hear some bastard was messing with your truck. The truth is if someone wants it there gonna take it. I live in Dallas and most trucks are snatched up with wreckers. All you can really do is try to slow them down. before I wrecked mine a few weeks ago I would double club my steering and full lock the wheel so they can't steer because if you can steer you can push. If you got a garage use it, park cars behind it if you can to slow them down. The people who take these trucks number job or chop'em up and ain't joyriders so it will take more than a kill switch to turn them away when all you need is a wire and a screwdriver to jump the starter and drive off. Good luck and keep an eye out cause you can bet they will be prepared if they come back. Later.
jrdz2120 is offline   Reply With Quote
Old 01-24-2010, 10:43 PM   #22
chipflyer
chipflyer's Avatar
Here is what I may do with a couple of relays. I like the idea of putting it between the ignition switch and the HEI activating it with some sort of hidden push button or switch. If someone doesn't know to push the hidden switch first it will have no fire and just crank until the battery dies. What do you think?
Old 01-24-2010, 11:35 PM   #23
dwcsr
Hollister Road Co.
dwcsr's Avatar
this should work
Old 01-24-2010, 11:36 PM   #24
OhOneWS6
OhOneWS6's Avatar
Jeff
It's called a latching relay circuit. You just need a double pole relay to do it. Nothing special. I see no real advantage over a toggle. Honestly I don't see the advantage to a toggle. Most who steal these trucks also know all you need is a hot wire to the coil or HEI. No amount of switches or relays will stop that. Just my opinion.
OhOneWS6 is offline   Reply With Quote
Old 01-26-2010, 04:53 PM   #25
bigguy69
dazed and confused
bigguy69's Avatar
Originally Posted by dwcsr View Post
okay, the trunk monkey wins!!!
